Fibaro FGD/FGS 211 in power outlets
Posted: Thu Dec 13, 2012 4:28 pm
So, after successfully getting my Fibaro 211 Dimmer to work, I got to thinking if I couldn't use either a dimmer or a switch to work for power outlets.
I want to be able to turn devices plugged into these outlets on or off through Z-Wave. If it's a lamp, a dimmer would even be possible.
Below is how I would hook it up to outlets that do not have a switch (which they usually don't except in bathrooms (for some reason)).
FGS211: (switch)
S1:
S2:
O: connected to one socket contact
I: looped to L
L: Load
N: Neutral and connected to other socket contact
(Not sure if any of the switches need to be connected, perhaps S1 needs to be connected to Neutral, but I'm not sure)
FGD211: (dimmer)
S1: looped to SX
S2:
SX:
L: Load
(Probably also needs option 14 set to 1, which is bi-stable switches)
Can anyone evaluate these and tell me if this is how I should connect them?
Thanks!
FGS211: (switch)
S1:
S2:
I: looped to L
L: Load
FGD211: (dimmer)
S1: looped to SX
S2:
SX:
L: Load
Thanks!
