Hi All
I backed this kickstarter, lots of sensors and options
also some sensors we havent used yet.
its arduino like based, with full source code (open source)
Option with extra solarpanel etc.
check
http://www.kickstarter.com/projects/acr ... onmental-m
and
http://blog.bwired.nl/?p=753
The Smart Citizen Kit is an Open-Source platform that comprises 3 technological layers: a hardware device, a website and online API, and a mobile app. Below is an overview of them, and if you're interested, all the gory details can be found on the Smart Citizen website.
Arduino-compatible hardware
The first layer is a piece of hardware comprised by two printed-circuit boards: an interchangeable daughterboard or shield, and an arduino-compatible data-processing board. We have nicknamed the shield developed for this campaign 'The Ambient Board.' As the name suggests, it carries sensors that measure air composition (CO and NO2), temperature, light intensity, sound levels, and humidity. Once it’s set up, the ambient board is able to stream data measured by the sensors over Wi-Fi using the FCC-certified, wireless module on the data-processing board. The device’s low power consumption allows for placing it on balconies and windowsills. Power to the device can be provided by a solar panel and/or battery. All the design files (schematics and PCB layout) for this Open-Source, Arduino-compatible device are available on our Github repository.
The Smart Citizen environmental monitoring Kickstarter
On this Forum we can discuss interesting Kickstarter like smartthings and gadgets
Return to “Kickstarter, Indiegogo and other crowdfunding related smartthings”
Jump to
- Forum matters
- ↳ News Forum
- Hardware Forum (English)
- ↳ Z-Wave Forum
- ↳ Fibaro
- ↳ Plugwise Forum
- ↳ Gadgets Forum
- ↳ Visonic Alarm systems
- ↳ LEDS, DMX & Lights Forum
- ↳ Opentherm Gateway Forum
- ↳ 1-Wire Forum
- ↳ PLCBUS Forum
- ↳ Smart Metering Forum
- ↳ ZigBee Forum
- ↳ Toon news and information
- ↳ Manuals/tutorials
- ↳ Toon Apps
- ↳ Toon Rooting
- ↳ Toon Hardware
- ↳ Toon Firmware
- ↳ Toon external control
- ↳ Toon miscellaneous
- ↳ Toon software development
- Software Forum (English)
- ↳ Announcements & News
- ↳ Linux Forum
- ↳ Windows Forum
- ↳ DomotiGa Forum
- ↳ OpenHAB Forum
- ↳ MQTT & Node.js
- Projects Forum (English)
- ↳ Home Automation Projects
- ↳ Bwired Forum
- ↳ Homeseer algemeen Forum
- ↳ Homeseer Scripts Forum
- ↳ Homeseer HStouch Forum
- ↳ Homeseer Plugins Forum
- Other (English)
- ↳ Off Topic
- ↳ Downloads & Links Forum
- ↳ Domoticaboek Heino Peters
- ↳ Dealers Corner
- ↳ Test
