DoorBot coupon code!
Posted: Tue May 20, 2014 2:20 pm
by Noel
Just bought a DoorBot and got this coupon to share with friends and members -
DOORBOT-TEN
More info:
http://curebit.com/x/oHGKxZ
Re: DoorBot coupon code!
Posted: Tue May 20, 2014 10:11 pm
im thinking about ordering this also
there is a way to connect my current solution on it as well because it has a standard 2 wire (switch) connect
@noel i think you will use this also the same way...right?
Posted: Tue May 20, 2014 10:49 pm
by Noel
That is correct.
I'll be using the standard 2 wire's as usual.
Besides this I will now also have a "live" video feed directly pushed to my mobile phone, and have a two way voice link to it.
They are also going to release an API so this all can be accessed over the web.
Posted: Wed May 21, 2014 9:11 am
by kriz83
Interested also. Can you post a picture of your 'installation' ?
Is it a simple replace of the current door bell or does it need some re-wiring ?
Posted: Wed May 21, 2014 9:33 am
by Phaeton
How is the responstime? Since there where quit some issues in the beginning?
Does the device push you directly or does it push you through the door bot servers?
Verstuurd vanaf mijn Nexus 5 met Tapatalk
Posted: Wed May 21, 2014 9:49 am
by kriz83
Would it be possible to e.g. use the camera and 'attach' it to zoneminder, so it can in fact be used as a 'security' camera also ?
Posted: Wed May 21, 2014 11:19 am
by Noel
At the moment it needs to go through the doorbot server, but they are working on a LAN update.
The "big" delay problems are according to the developers fixed.
My doorbot is on its way and should be here before the end of this week or beginning next week. (depending on customs)
Will update when I have more info.
__
Sent from my mobile phone. Please excuse for the brevity, spelling and punctuation.
Posted: Wed May 21, 2014 11:24 am
by Phaeton
Nice, I'm very curious. I now use Skybell, but I'm not completely sattisfied. For example; when the skybell doesn't have wifi signal the analog doorbell doesn't work. When the skybell server is down, the analog doorbell doesn't ring. I find mobotix to expensive so i'm willing to try doorbot when I hear possitive reviews. thanks!
Posted: Thu May 22, 2014 5:13 pm
by Noel
Okay,
This morning I received the Doorbot, and the setup was no problem.
I've hard wired it to my original doorbell setup (8V AC), and now when pressed the original doorbell, Homeseer and the Doorbot app (on my Android phone) will ring.
Besides this the Doorbot is now also powered 24/7.
When connected to my own WiFi network with my mobile phone I get a video / audio delay of about 2 seconds (both ways).
I get the same delay with my Simyo mobile provider except that I did not manage to make an audio connection back to the Doorbot.
I'll be doing some more tuning / testing later and report back again.
Posted: Thu May 22, 2014 6:54 pm
by Noel
Small update.
I just noticed that my original doorbell is now constantly humming a bit (like it's not getting enough voltage).
As soon as the Doorbot button is pushed it does ring.
I'm seeing on the doorbot forum that a lot of users are having similar problems with it.
See:
http://e2b.org/b7
