Page 1 of 2
Notification for Iphone
Posted: Sat Sep 12, 2009 1:10 am
by TANE
Found this fun application that will deliver notification to you Iphone.
easy to use.
just send a message to your notification e-mail or...use the API/web interface
https://www.appnotifications.com/
Posted: Sat Sep 12, 2009 1:08 pm
by RdP
Any idea how to integrate this in HomeSeer ?? And what about battery usage, is it high ??
Posted: Sat Sep 12, 2009 1:48 pm
by Bjochems
I tried to create a new account. But i got the following error message:
"We're sorry, but something went wrong. We've been notified about this issue and we'll take a look at it shortly."
For integrating in homeseer you can just create an event that sends out an email. Or if you use the API, create a script. I guess it will work the same way as the prowl API. See also: http://www.domoticaforum.eu/topic.asp?TOPIC_ID=3305
Posted: Sat Sep 12, 2009 8:36 pm
by TANE
Her it's working fine.
I'm sending e-mail's from event.
When the account is created you will receive a special e-mail account (long string)
One of the best notification application's
Posted: Sun Sep 13, 2009 4:00 pm
by RdP
BEfore I dive into this. Do I have to enable push mail for the notifications. Push mail is using a lot of power and that's not acceptable for me.
Thanks,
Posted: Sun Sep 13, 2009 5:34 pm
by 8r1an
You don't need push mail enabled just Notifications
Brian
Posted: Mon Sep 14, 2009 11:33 pm
by Lennart
Hmm, I guess they are currently having some problems. E-mail I send to my account sometimes leads to a notification, but many times the Iphone remains silent. After a while (sometimes after 30 minutes or so) the notifications do show up in the Iphone app, but not as a notification on the main screen.
Also, their website is buggy: clicking my account leads to an error (to log in you have to go to the FAQ first), the PHP CURL code example doesn't work, setting the bounce e-mail notification option to off leads to not receiving any notifications at all, etc.
Sending notifications from the webpage, however, works all the time.
Any ideas? Is it just me who thinks the implementation is lacking?
Lennart
Posted: Mon Sep 14, 2009 11:45 pm
by TANE
I have done some testing.
notification will display on the iphone in less then 3 seconds...
I'm sending e-mails from Homeseer events.
Posted: Tue Sep 15, 2009 1:07 am
by Snelvuur
cant you use a http api call of some sort? i prefer those, since you normally get some sort of 200 or 404 back ;p
Posted: Tue Sep 15, 2009 9:20 am
by TANE
you can use e-mail option..the most easy one
I did not test the other options
Posted: Tue Sep 15, 2009 11:10 am
by Bjochems
I tested the HTTP API and it works really good. With the API you can choose your own sound (or silent mode). Plus you can send some extra (html) text that is displayed when you open the application on your phone. Even remote images can be loaded in here. And you can also add a link to the notification dialog, so you can for example link directly to your HA website.
More info about the API (you must login first):
https://www.appnotifications.com/account/rest_api
Posted: Tue Sep 15, 2009 8:15 pm
by RdP
Cool... Works great....
Posted: Tue Sep 15, 2009 10:04 pm
by TANE
Rien do you use the e-mail option or the API?
Posted: Wed Sep 16, 2009 11:04 pm
by Lennart
Ok, I did some more testing. Some observations:
1) The E-mail option works indeed, as long as you don't put a checkmark in the option "Check this to NOT receive a copy (bounce) of all incoming emails to the e-mail address you used for your appnotification account" (this option is under MailNotifications and then advanced settings). In other words: you have to forward all e-mail notifications to your e-mail address or the notifications won't be delivered. As I already get too much mail, I'd rather check the checkbox...
2) I couldn't get the PHP CURL example to work, as is (of course putting in my own credentials).
My questions:
- Did anyone get it to work while *not* forwarding all e-mail to your e-mail account?
- @Bas: What HTTP API did you use? Could you post some example code? Or did you use Prowl instead of AppNotifications?
I also tried Prowl as discussed here: http://www.domoticaforum.eu/topic.asp?T ... rowl#24749 and that works flawlessly (thanks Bas!).
Lennart
Posted: Thu Sep 17, 2009 9:14 am
by Rene
Wat zijn de voordelen van deze applicatie t.o.v. Prowl (http://www.domoticaforum.eu/topic.asp?TOPIC_ID=3305)?
