Fully automated rooting script
Re: Fully automated rooting script
Postby mAiden » Wed May 08, 2019 7:09 pm
rotzen wrote:Srry, thought I editted my last post yesterday. You are correct, I pressed the reset button instead of a reboot command. Connecting the 11 wires I'm able to get into u-boot, asking which runlevel I want.
if Toon is asking you "Enter the runlevel" then youre inittab is broken.. You need to fix that thing. You will find them in: /etc/inittab
Inittab:
# /etc/inittab: init(8) configuration.
# $Id: inittab,v 1.91 2002/01/25 13:35:21 miquels Exp $
# The default runlevel.
# Boot-time system configuration/initialization script.
# This is run first except when booting in emergency (-b) mode.
si::sysinit:/etc/init.d/rcS
# What to do in single-user mode.
# /etc/init.d executes the S and K scripts upon change
# of runlevel.
# Runlevel 0 is halt.
# Runlevel 1 is single-user.
# Runlevels 2-5 are multi-user.
# Runlevel 6 is reboot.
l0:0:wait:/etc/init.d/rc 0
l1:1:wait:/etc/init.d/rc 1
l2:2:wait:/etc/init.d/rc 2
l3:3:wait:/etc/init.d/rc 3
l4:4:wait:/etc/init.d/rc 4
l5:5:wait:/etc/init.d/rc 5
l6:6:wait:/etc/init.d/rc 6
# Normally not reached, but fallthrough in case of emergency.
# The "id" field MUST be the same as the last
# characters of the device (after "tty").
# Format:
#  <id>:<runlevels>:<action>:<process>
qtqt:245:respawn:/usr/bin/startqt >/dev/null 2>&1
#ovpn:235:respawn:/usr/sbin/openvpn --config /etc/openvpn/vpn.conf --verb 0 >/dev/null 2>&1
# WARNING: auto-managed by '/etc/init.d/HCBv2 inittabwrap' with '/HCBv2/etc/start.d/*'
#          lines containing 'inittabwrap' will be removed automagically.
netc:235:respawn:/etc/init.d/HCBv2 inittabwrap hcb_netcon
comm:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_comm
even:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_eventmgr
hvac:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_hvac
kpik:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_kpi
pwru:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_pwrusage
scsy:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_scsync
smar:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_smartplug
ther:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_thermstat
user:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_usermsg
weat:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_weather
bxtp:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_bxtproxy
conf:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_config
logl:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_log
rrdr:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_rrd
watc:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_watchdog
hueh:345:respawn:/etc/init.d/HCBv2 inittabwrap hdrv_hue
p1p1:345:respawn:/etc/init.d/HCBv2 inittabwrap hdrv_p1
sens:345:respawn:/etc/init.d/HCBv2 inittabwrap hdrv_sensory
zwav:345:respawn:/etc/init.d/HCBv2 inittabwrap hdrv_zwave
ligh:345:respawn:/etc/init.d/HCBv2 inittabwrap lighttpd
# end of 'inittabwrap' section.
mAiden
Postby mAiden » Thu May 09, 2019 6:15 pm
to make a long story short. I fixed it via teamviewer (With good help from TheHogNL and all others..)..
Remove qt-gui
Install qt-gui
Remove base-uni... and install hem agian
Then I ran into a problem that qml_tenant was empty, taken copy of my own Toon1 and put it in. Same was with the crony.conf
Hes Toon is up and running agian. :)
mAiden
Postby rotzen » Thu May 09, 2019 7:13 pm
Thx mAiden! You are my hero!!
rotzen
Postby Ron_nl » Tue May 14, 2019 6:47 pm
Remove qt-gui
Install qt-gui
Is this to do for a complete novice by making the short story long? ;)
I have managed to get myself into the same problem as rotzen did, and also ended up at "enter runlevel:"
U-Boot 2010.09-R8 (Dec 03 2012 - 12:50:30)
CPU:   Freescale i.MX27 at 400.168 MHz
Prodrive B.V. ED2.0
DRAM:  128 MiB
NAND:  128 MiB
LCD: 800x480, pbb 4
LCD: Drawing the logo...
In:    serial
Out:   serial
Err:   serial
Display-bmp: 800 x 480  with 16777216 colors
Net:   FEC
Address in SROM is         00:00:20:03:00:00
Address in environment is  00:0f:11:04:40:02
Enter password - autoboot in 2 sec...
NAND read: device 0 offset 0x300000, size 0x300000
3145728 bytes read: OK
## Booting kernel from Legacy Image at a1000000 ...
   Image Name:   Linux-2.6.36-R10-h28
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    1944236 Bytes = 1.9 MiB
   Load Address: a0008000
   Entry Point:  a0008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.36-R10-h28 (jbraam@dvl) (gcc version 4.5.3 20110223 (prerelease) (GCC) ) #1 PREEMPT Fri Sep 28 15:51:09 CEST 2018
CPU: ARM926EJ-S [41069264] revision 4 (ARMv5TEJ), cr=00053177
CPU: VIVT data cache, VIVT instruction cache
Machine: Prodrive B.V ED2.0
Memory policy: ECC disabled, Data cache writeback
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32512
Kernel command line: ubi.mtd=4,2048 root=ubi0:rootfs rw rootfstype=ubifs mtdparts=mxc_nand:512K@0x00100000(u-boot-env)ro,1536K(splash-image),3M(kernel),3M(kernel-backup),119M(rootfs) console=ttymxc0,115200 mem=128M lpj=999424
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 128MB = 128MB total
Memory: 126092k/126092k available, 4980k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xffa00000 - 0xffe00000   (   4 MB)
    vmalloc : 0xc8800000 - 0xf4000000   ( 696 MB)
    lowmem  : 0xc0000000 - 0xc8000000   ( 128 MB)
    modules : 0xbf000000 - 0xc0000000   (  16 MB)
      .init : 0xc0008000 - 0xc0022000   ( 104 kB)
      .text : 0xc0022000 - 0xc0367000   (3348 kB)
      .data : 0xc037e000 - 0xc03a17a0   ( 142 kB)
Hierarchical RCU implementation.
        RCU-based detection of stalled CPUs is disabled.
        Verbose stalled-CPUs detection is disabled.
NR_IRQS:272
MXC IRQ initialized
MXC GPIO hardware
Console: colour dummy device 80x30
Calibrating delay loop (skipped) preset value.. 199.88 BogoMIPS (lpj=999424)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
Configured for LCD: TM070RDH11
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Switching to clocksource mxc_timer1
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
msgmni has been set to 246
io scheduler noop registered (default)
Serial: IMX driver
imx-uart.0: ttymxc0 at MMIO 0x1000a000 (irq = 20) is a IMX
console [ttymxc0] enabled
imx-uart.1: ttymxc1 at MMIO 0x1000b000 (irq = 19) is a IMX
imx-uart.2: ttymxc2 at MMIO 0x1000c000 (irq = 18) is a IMX
NAND device: K9F1G08U0E detected, disabling sub-page writes
NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bit)
Scanning device for bad blocks
RedBoot partition parsing not available
5 cmdlinepart partitions found on MTD device mxc_nand
Creating 5 MTD partitions on "mxc_nand":
0x000000100000-0x000000180000 : "u-boot-env"
0x000000180000-0x000000300000 : "splash-image"
0x000000300000-0x000000600000 : "kernel"
0x000000600000-0x000000900000 : "kernel-backup"
0x000000900000-0x000008000000 : "rootfs"
UBI: attaching mtd4 to ubi0
UBI: physical eraseblock size:   131072 bytes (128 KiB)
UBI: logical eraseblock size:    126976 bytes
UBI: smallest flash I/O unit:    2048
UBI: VID header offset:          2048 (aligned 2048)
UBI: data offset:                4096
UBI: max. sequence number:       355894
UBI: attached mtd4 to ubi0
UBI: MTD device name:            "rootfs"
UBI: MTD device size:            119 MiB
UBI: number of good PEBs:        952
UBI: number of bad PEBs:         0
UBI: max. allowed volumes:       128
UBI: wear-leveling threshold:    4096
UBI: number of internal volumes: 1
UBI: number of user volumes:     1
UBI: available PEBs:             0
UBI: total number of reserved PEBs: 952
UBI: number of PEBs reserved for bad PEB handling: 9
UBI: max/mean erase counter: 1112/373
UBI: image sequence number:  1168213731
UBI: background thread "ubi_bgt0d" started, PID 309
at25 spi0.0: 32 KByte at25640B eeprom, pagesize 64
spi_imx spi_imx.0: probed
FEC Ethernet Driver
fec_enet_mii_bus: probed
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
mxc-ehci mxc-ehci.0: initializing i.MX USB Controller
mxc-ehci mxc-ehci.0: portsc setup 1: 0x80000000
mxc-ehci mxc-ehci.0: Work around for USB enabled
ULPI transceiver vendor/product ID 0x0424/0x000d
mxc-ehci mxc-ehci.0: Freescale On-Chip EHCI Host Controller
mxc-ehci mxc-ehci.0: new USB bus registered, assigned bus number 1
mxc-ehci mxc-ehci.0: irq 56, io mem 0x10024000
mxc-ehci mxc-ehci.0: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: Freescale On-Chip EHCI Host Controller
usb usb1: Manufacturer: Linux 2.6.36-R10-h28 ehci_hcd
usb usb1: SerialNumber: mxc-ehci.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mxc-ehci mxc-ehci.2: initializing i.MX USB Controller
mxc-ehci mxc-ehci.2: portsc setup 1: 0x80000000
mxc-ehci mxc-ehci.2: Work around for USB enabled
mxc-ehci mxc-ehci.2: Freescale On-Chip EHCI Host Controller
mxc-ehci mxc-ehci.2: new USB bus registered, assigned bus number 2
mxc-ehci mxc-ehci.2: irq 55, io mem 0x10024400
mxc-ehci mxc-ehci.2: USB 2.0 started, EHCI 1.00
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: Freescale On-Chip EHCI Host Controller
usb usb2: Manufacturer: Linux 2.6.36-R10-h28 ehci_hcd
usb usb2: SerialNumber: mxc-ehci.2
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver usbserial
usbserial: USB Serial Driver core
input: TSC2007 Touchscreen as /devices/virtual/input/input0
rtc-isl1208 1-006f: chip found, driver version 0.3
rtc-isl1208 1-006f: rtc core: registered rtc-isl1208 as rtc0
i2c /dev entries driver
tmp431 0-004c: Could not read configuration register (-5)
imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
adt7410 0-0048: adt7410 temperature sensor registered.
adt7410 0-0049: adt7410 temperature sensor registered.
nf_conntrack version 0.5.0 (1970 buckets, 7880 max)
ip_tables: (C) 2000-2006 Netfilter Core Team
TCP cubic registered
NET: Registered protocol family 17
Bridge firewalling registered
rtc-isl1208 1-006f: setting system clock to 2019-05-14 09:57:45 UTC (1557827865)
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: file system size:   117833728 bytes (115072 KiB, 112 MiB, 928 LEBs)
UBIFS: journal size:       9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
UBIFS: media format:       w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root:  0 bytes (0 KiB)
VFS: Mounted root (ubifs filesystem) on device 0:13.
Freeing init memory: 104K
usb 2-1: new high speed USB device using mxc-ehci and address 2
INIT: version 2.86 bootingusb 2-1: New USB device found, idVendor=148f, idProduct=5370
usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 2-1: Product: 802.11 n WLAN
usb 2-1: Manufacturer: Ralink
usb 2-1: SerialNumber: 1.0
Enter runlevel:
Ron.
Ron_nl
Postby mAiden » Wed May 15, 2019 8:27 am
If Toon ask you for runlevl. Then you're inittab is broken. Will look if i can post a inittab for Toon1 today.
mAiden
Postby Ron_nl » Wed May 15, 2019 1:27 pm
I do have a working Toon, so I could get the initab from that one?
If so, how do I get it into the broken one?
When I boot the broken one, it wont stop at the password point if I try to put the password there within the 2 seconds.
It is just not reacting to the input.
At the "enter runlevel" point it is possible again to enter whatever you want.
Thanks, Ron.
Ron_nl
Postby WickedMaster » Wed May 15, 2019 11:44 pm
Password 3BHf2 should work there. Try again, and check your serial cable.
WickedMaster
Postby Ron_nl » Thu May 16, 2019 8:09 am
@Wickedmaster, that worked, got the wrong password thought you needed the rooted generated PW.
Thanks!
1 step further 8)
Ron.
Ron_nl
Postby mAiden » Thu May 16, 2019 10:01 am
You could grab the inittab of your other Toon1. You could also take this one:
# of runlevel.
# Format:
Step 1: Log in with serial connection on Toon, with the password that is giving..
Step 2:
BE CAREFUL .. 1 TYPING ERROR IS DEADLY FOR YOUR TOON HERE !!
setenv addmisc setenv bootargs \$\{bootargs\} mem=\$\{mem\} lpj=999424 init=/bin/sh
Just copy paste my line in Toon..
Step 3:
You can lower your blood pressure now .. Run the following command now:
run boot_nand
Step 4:
U-Boot opens a command shell at the end of the boot process..
/bin/sh: can't access tty; job control turned off,
it has no effect.
Step 5:
Now you can fix you're inittab.
Open it with:
vi /etc/inittab
You will almost certainly see this. ~ ~ ~ ~ remove that.
If you remove it, copy en paste the inittab that i post here, or you other inittab from Toon1.
Save it with the following steps:
ESC then : then wq then enter
Just be sure, check if everything is ok, open inittab agian with: vi /etc/inittab
If everything is ok, do: ESC and : and q then enter.
Step 6:
Reboot Toon with:
reboot -f
If you can't figure it out. Just send me an e-mail or message, so i can always watch with you with teamviewer. :)
mAiden
Postby Ron_nl » Thu May 16, 2019 11:15 am
Thanks @maiden.
Toon is booting now till 1/3 and is stuck there.
Do have SSH again, and tried the update-rooted script but it isn't working "update-rooted.sh not found"
will have to look into that later today.
But a lot of thanks already!
It is so cool to get this info and help to get hings fixed.
Ron.
Ron_nl
Postby marcelr » Thu May 16, 2019 1:34 pm
If the script is not executable, you can get that message.
Try
sh ./update-rooted.sh
or
chmod 755 ./update-rooted.sh
and then execute.
Postby mAiden » Thu May 16, 2019 1:53 pm
Ron_nl wrote:Thanks @maiden.
Ron.
Hmmm... You can do 2 things here..
1:
In SSH from Toon, go to:
vi /etc/inittab
And change :
TO
qtqt:245:respawn:/usr/bin/startqt  >/var/log/qt 2>&1
Dont forget to change it back to the first one, That log file fills up very quickly !!
This will post a log file, so you can see what is happend..
You can monitor it with:
tail -f /var/log/qt
Other option is to look or update-rooted will be on that path, with:
ls
If it is there, run this command:
sh update-rooted.sh -f
This will fix some files for you :)
mAiden
Postby Ron_nl » Thu May 16, 2019 3:01 pm
Fixed! :D
@mAiden & marcelr;
Had to do the initab copying twice, something went wrong copying it was missing a few lines (dunno why..)
After that sh update-rooted.sh -f fixed some, it still had an issue with qmf_tenant.xml.
Used Winscp to fix that, the file was empty so I copied it from my working Toon.
After reboot the only thing needed fixing was activation, but got that done as well with the help of this forum search function.
Learned a lot from today you guys, Thanks!
Ron.
Ron_nl
Postby Jasper » Wed Jun 05, 2019 10:46 pm
Is this noob proof?
I'm thinking about getting a second Toon before ruining my own because I have a lot of problems with it. Well a lot lol. Most used is the weather, power consumption and PV monitoring. Weather is offline a lot and paying €4,50 a month just for the weather ain't Dutch.
Or are there people in the Netherlands selling pre-rooted Toon's?
Jasper
Postby marcelr » Thu Jun 06, 2019 3:36 pm
Jasper wrote:Or are there people in the Netherlands selling pre-rooted Toon's?
Just check out MP. Plenty options, or contact forum member TerrorSource.
PreviousNext
Return to Toon Rooting
cron
