rooting issue (tx/rx connected) help
Postby vso » Mon May 18, 2020 9:25 am
I am trying to root the toon,
- rpi (1b+) tx,rx gnd connected to toon
- i used screen/minicom with 115200, 8n1 to ttyAMA0
- toon U-Boot 2010.09-R8 (Dec 03 2012 - 12:50:30)
I get data only because of "reasons" i don't understand the data gets messy (data shifts or gets a ladder view) and unreadable characters ..
the RPI freezes because of this .. I cannot root..
CPU:   Freescale i.MX27 at 400.168 MHz
DRAM:  128 MiB
NAND:  128 MiB
Do i need to connect more cables ?? any advise is appriciated ..
vso
Re: rooting issue (tx/rx connected) help
Postby TerrorSource » Mon May 18, 2020 9:42 am
Why not use the ToonRooter? Makes it easier.
My guess is that your trying to root a Toon with 4.16.8+ firmware which must be done via secure line. Pretty hard if you never done that.
TerrorSource
Postby vso » Mon May 18, 2020 11:16 am
Secure line ? could you explain or give me a link what explains this a bit more ?
do i need to connect more pins ?
vso
Postby TheHogNL » Mon May 18, 2020 11:27 am
vso wrote:I am trying to root the toon,
DRAM:  128 MiB
NAND:  128 MiB
Did you disable the Pi's normal serial console output? Probably you are now getting two sources tallking on same line.
Postby TerrorSource » Mon May 18, 2020 11:31 am
vso wrote:Secure line ? could you explain or give me a link what explains this a bit more ?
nevermind my useless previous post. was too realy and didnt thought well enough :roll:
Spoken with TheHogNL and best thing for you to do is using ToonRooter.
That will automaticallt recognize the Pi model used and adjust the JTAG for that Pi model.
TerrorSource
Postby vso » Mon May 18, 2020 2:59 pm
hmmm well actually you might be right on this one :D :roll: :lol:
vso
@TerrorSource You might be right,, stupid me
vso
Postby TheHogNL » Mon May 18, 2020 5:30 pm
If you had followed the toonrooter manual you would have noticed that :)
Postby vso » Tue May 19, 2020 7:26 pm
TheHogNL wrote:If you had followed the toonrooter manual you would have noticed that :)
if I had connected directly the JTAG pins .. instead of only tx/rx and indeed RFTM --> less headache
vso
Return to Toon Rooting
