Rooting Toon (or boxx)
Re: Rooting Toon (or boxx)
Please ask again in a different thread. This has got nothing to do with rooting.
- Starting Member
Hi, I just bought a Toon and started using the manual to root the thing.
After connecting the usb to serial to the right pins I only get strange symbols in Putty. Double checked everything but I can't find the problem.
Can't find other posts about this problem, so if anybody knows whats wrong...
- Putty.png (11.08 KiB) Viewed 6723 times
Probably wrong COM port settings:
115200 baud, 8 databits, 1 stop bit, no parity.
- Starting Member
Using 11520 baud doesn't workmarcelr wrote:Probably wrong COM port settings:
Thanks
It should, because that's the rate the serial port is working at. Just to be sure, it's 115200, not 11520
- Starting Member
That was the problem, needed the extra 0marcelr wrote:It should, because that's the rate the serial port is working at. Just to be sure, it's 115200, not 11520
im gonna crazy here rooting my toon..
what i need to do to install it ?
Installing dropbear (2015.71-r0) to root...
Configuring dropbear.
Collected errors:
* pkg_run_script: package "dropbear" postinst script returned status 255.
* opkg_configure: dropbear.postinst returned 255.
That's normal. Just run the postinst script yourself after opkg failed to do it. The auto root script also has this problem and runs the postinst afterwards:
echo ">>> Installing dropbear"
opkg install dropbear_2015.71-r0_qb2.ipk
if [[ $? == 255 ]] ; then
set -e
sh /usr/lib/opkg/info/dropbear.postinst
fi
I'm new to this forum, and trying to root my Toon with an RPI4 ( using the automated script of martenjacobs ). Currently i'm getting stuck since I have a newer toon ( bootloader R10 ).
First of all the regular startup Toonrooter command is not working :
However using :
is working sort of?
So i've run the OPENOCD command stated at the git from martenjacobs with following output:
Currently i'm stuck at this point. Can anyone help me getting further? Could it be that an RPI4 is not supported for the rooting script?
Thanks!
pi@raspberrypi:~/ToonRooter $ sudo python . --jtag-available
INFO:__main__:Starting up...
CRITICAL:__main__:Cannot autodetect jtag hardware
pi@raspberrypi:~/ToonRooter $ sudo python . --jtag-hardware TYPE
INFO:__main__:Written private and public key pair to ./id_rsa and ./id_rsa.pub, respectively
INFO:rooter:Waiting for Toon to restart
INFO:rooter:Toon has U-Boot version 2010.09-R10
ERROR:rooter:Unable to log in using password (need JTAG, but it's disabled)
pi@raspberrypi:~/ToonRooter $ sudo git clone --recursive git://git.code.sf.net/p/openocd/code openocd
Cloning into 'openocd'...
remote: Enumerating objects: 61666, done.
remote: Counting objects: 100% (61666/61666), done.
remote: Compressing objects: 100% (25612/25612), done.
remote: Total 61666 (delta 50663), reused 43569 (delta 35892)
Receiving objects: 100% (61666/61666), 13.99 MiB | 818.00 KiB/s, done.
Resolving deltas: 100% (50663/50663), done.
Submodule 'jimtcl' (http://repo.or.cz/r/jimtcl.git) registered for path 'jimtcl'
Submodule 'src/jtag/drivers/libjaylink' (http://repo.or.cz/r/libjaylink.git) registered for path 'src/jtag/drivers/libjaylink'
Submodule 'tools/git2cl' (http://repo.or.cz/r/git2cl.git) registered for path 'tools/git2cl'
Cloning into '/home/pi/ToonRooter/openocd/jimtcl'...
warning: redirecting to https://repo.or.cz/r/jimtcl.git/
remote: Counting objects: 7564, done.
remote: Total 7564 (delta 0), reused 0 (delta 0) /s s
Receiving objects: 100% (7564/7564), 5.99 MiB | 1.95 MiB/s, done.
Resolving deltas: 100% (5503/5503), done.
Cloning into '/home/pi/ToonRooter/openocd/tools/git2cl'...
warning: redirecting to https://repo.or.cz/r/git2cl.git/
remote: Counting objects: 64, done.
remote: Total 64 (delta 0), reused 0 (delta 0)
Cloning into '/home/pi/ToonRooter/openocd/src/jtag/drivers/libjaylink'...
warning: redirecting to https://repo.or.cz/r/libjaylink.git/
remote: Counting objects: 991, done.
remote: Total 991 (delta 0), reused 0 (delta 0)
Receiving objects: 100% (991/991), 234.83 KiB | 412.00 KiB/s, done.
Resolving deltas: 100% (758/758), done.
Submodule path 'jimtcl': checked out 'a9bf5975fd0f89974d689a2d9ebd0873c8d64787'
Submodule path 'src/jtag/drivers/libjaylink': checked out '4959f4e18a2bb0de21abe66bbfe403b56f599856'
Submodule path 'tools/git2cl': checked out '8373c9f74993e218a08819cbcdbab3f3564bbeba'
pi@raspberrypi:~/ToonRooter $ cd openocd
pi@raspberrypi:~/ToonRooter/openocd $ sudo apt install make libtool libtool-bin pkg-config autoconf automake texinfo libusb-1.0 libusb-dev
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'libusb-1.0-0' for regex 'libusb-1.0'
Note, selecting 'libusb-1.0-0-dev' for regex 'libusb-1.0'
Note, selecting 'libusb-1.0-doc' for regex 'libusb-1.0'
libusb-1.0-0 is already the newest version (2:1.0.22-2).
libusb-1.0-0 set to manually installed.
make is already the newest version (4.2.1-1.2).
make set to manually installed.
pkg-config is already the newest version (0.29-6).
The following additional packages will be installed:
autotools-dev libauthen-sasl-perl libdata-dump-perl libencode-locale-perl
libfile-listing-perl libfont-afm-perl libhtml-form-perl libhtml-format-perl
libhtml-parser-perl libhtml-tagset-perl libhtml-tree-perl
libhttp-cookies-perl libhttp-daemon-perl libhttp-date-perl
libhttp-message-perl libhttp-negotiate-perl libio-html-perl
libio-socket-ssl-perl libltdl-dev libltdl7 liblwp-mediatypes-perl
liblwp-protocol-https-perl libmailtools-perl libnet-http-perl
libnet-smtp-ssl-perl libnet-ssleay-perl libsigsegv2 libtext-unidecode-perl
libtimedate-perl libtry-tiny-perl liburi-perl libusb-0.1-4 libwww-perl
libwww-robotrules-perl libxml-libxml-perl libxml-namespacesupport-perl
libxml-parser-perl libxml-sax-base-perl libxml-sax-expat-perl
libxml-sax-perl m4 perl-openssl-defaults tex-common
Suggested packages:
autoconf-archive gnu-standards autoconf-doc gettext libdigest-hmac-perl
libgssapi-perl libtool-doc libcrypt-ssleay-perl gfortran
| fortran95-compiler gcj-jdk libauthen-ntlm-perl libxml-sax-expatxs-perl
m4-doc debhelper texlive-base texlive-latex-base texlive-generic-recommended
texinfo-doc-nonfree texlive-fonts-recommended
The following NEW packages will be installed:
autoconf automake autotools-dev libauthen-sasl-perl libdata-dump-perl
libencode-locale-perl libfile-listing-perl libfont-afm-perl
libhtml-form-perl libhtml-format-perl libhtml-parser-perl
libhtml-tagset-perl libhtml-tree-perl libhttp-cookies-perl
libhttp-daemon-perl libhttp-date-perl libhttp-message-perl
libhttp-negotiate-perl libio-html-perl libio-socket-ssl-perl libltdl-dev
libltdl7 liblwp-mediatypes-perl liblwp-protocol-https-perl libmailtools-perl
libnet-http-perl libnet-smtp-ssl-perl libnet-ssleay-perl libsigsegv2
libtext-unidecode-perl libtimedate-perl libtool libtool-bin libtry-tiny-perl
liburi-perl libusb-0.1-4 libusb-1.0-0-dev libusb-1.0-doc libusb-dev
libwww-perl libwww-robotrules-perl libxml-libxml-perl
libxml-namespacesupport-perl libxml-parser-perl libxml-sax-base-perl
libxml-sax-expat-perl libxml-sax-perl m4 perl-openssl-defaults tex-common
texinfo
0 upgraded, 51 newly installed, 0 to remove and 57 not upgraded.
Need to get 7,124 kB of archives.
After this operation, 26.3 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Abort.
Thanks!
Script isn't tested yet on a Pi4.
But you need --jtag-available (because of R10) and then try with --jtag-hardware rpi3 (I hope the pi4 is compatible with the pi3 on the jtag pins).
Also you openocd install failed. In the end I see 'Abort'. Try it again please.
- Starting Member
I'm having a hard (that is: unsuccessful) time rooting my Toon on R10. Tried multiple Pi's on the single Toon, but all give me the "error jtag scan chain interrogation failed all zeroes" on starting OpenOCD so I cannot do a soft_reset. Triple checked wiring, used both the fully automated method as well as the 'manual' method described here. Any suggestions? Anyone in the area of Haarlem able to assist?
Check the wiring for the 4th time.
- Starting Member
I will although my wife already complained about this consuming most of the Sunday. But could it be that JTAG header on the Toon was destroyed by me? And if so, how would that present itself? Would there be some other error code? I might grab another Toon from MP to try again....
Yes could be but that would require you to put a higher voltage then the 3.3v on the wrong pins. Don't know how that would present itself though. Maybe some experienced toon rooter in your neighborhood can help you indeed.finalcut62 wrote: I will although my wife already complained about this consuming most of the Sunday. But could it be that JTAG header on the Toon was destroyed by me? And if so, how would that present itself? Would there be some other error code? I might grab another Toon from MP to try again....
TheHogNL wrote:Script isn't tested yet on a Pi4.
Thanks for your support. Reinstalled OpenOCD, which succeeded.
However still the same issue
Thanks!
