Rooting Toon (or boxx)
Gleno0hh
Re: Rooting Toon (or boxx)
Post by Gleno0hh »
Could the raspberry 1 be used for r10, also?
I have tried it but i cant seem to get it connected properly.
Openocd either doesnt see my toon or it spits out 1000 messages telling me communication failed...
I have contacted quby but they want me to send my toon to them, and thats a no-go :-)
Thanks in advance.
mogwai
Post by mogwai »
I just posted a message in the thread about ToonRooter. Yes this can be done with a RasPI 1 but you need to modify the "assets/raspberrypi.cfg" file (I did it myself a few days ago :)). Below the settings for different RasPI configurations:
 # Raspi2 and Raspi3 peripheral_base address
 bcm2835gpio_peripheral_base 0x3F000000
 # Raspi1 peripheral_base address
 bcm2835gpio_peripheral_base 0x20000000
 # Raspi3 BCM2837 (1200Mhz):
 bcm2835gpio_speed_coeffs 194938 48
 # Raspi2 BCM2836 (900Mhz):
 bcm2835gpio_speed_coeffs 146203 36
 # Raspi1 BCM2835: (700Mhz)
 bcm2835gpio_speed_coeffs 113714 28
mogwai
Post by mogwai »
I recently rooted my Toon succesfully, but using ToonRooter on RasPI. After that I followed to manual for "hardening the Toon" and get it completely disconnected from Quby. All went well except for this part
##### Disabling pinging quby.nl: #####
Toon pings the quby ping server every so many seconds. This is done in
/HCBv2/sbin/hcb_netcon. The ping server address is unfortunately
hard-coded in hcb_netcon, so to disable this, you will need to reroute
ping requests to another machine. You can't switch it off easily.
To reroute, edit or create the file /etc/hosts.template and add the line
127.0.0.1 ping.quby.nl
at the end of the file, and save it.
Test whether your rerouting works by pinging quby:
eneco-001-xxxxxx:/# ping ping.quby.nl
PING ping.quby.nl (127.0.0.1): 56 data bytes
64 bytes from 127.0.0.1: seq=0 ttl=64 time=1.108 ms
64 bytes from 127.0.0.1: seq=1 ttl=64 time=0.738 ms
64 bytes from 127.0.0.1: seq=2 ttl=64 time=0.658 ms
If I to this modification the ping command is still pinging Quby ( 8.8.8.8 ). The only thing that does work is to add the line to the /etc/hosts file instead of the /etc/hosts.template file. Any clues?
Post by TheHogNL »
Took me a while to understand your r10 abreviation :) (rooting..)
Not sure the raspberrypi 1 is fast enough. But do you really need openocd? If you are lucky you have the old boot versions and can go with the old skool rooting guide.
mAiden
Post by mAiden »
Look at serial number.. Begin number is the year when Toon comes out, everything without 16, is easy to root ;)
mAiden wrote:Look at serial number.. Begin number is the year when Toon comes out, everything without 16, is easy to root ;)
Small correction: 16 and higher. Toons type 1 have been built well into 2017.
The real check is the bootloader version: Toons with u-boot version 2010.09-R10 and later will not be rootable through bootloader environment editing.
mAiden
Post by mAiden »
You're right.. Thanks for the correction Marcel.
Gleno0hh
Post by Gleno0hh »
mogwai wrote:I just posted a message in the thread about ToonRooter. Yes this can be done with a RasPI 1 but you need to modify the "assets/raspberrypi.cfg" file (I did it myself a few days ago :)). Below the settings for different RasPI configurations:
I found these too, they are the same as raspberrypi-native.cfg.
This is the output, which doesnt look good.
As root(!)
Open On-Chip Debugger 0.10.0+dev-00512-gfd04460 (2018-08-10-12:09)
Licensed under GNU GPL v2
For bug reports, read
        http://openocd.org/doc/doxygen/bugs.html
BCM2835 GPIO config: tck = 11, tms = 25, tdi = 10, tdo = 9
BCM2835 GPIO config: trst = 8
BCM2835 GPIO config: srst = 24
adapter speed: 500 kHz
adapter_nsrst_delay: 400
none separate
trst_and_srst srst_pulls_trst srst_gates_jtag trst_push_pull srst_open_drain connect_deassert_srst
Info : auto-selecting first available session transport "jtag". To override use 'transport select <transport>'.
dcc downloads are enabled
ed20_init
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Info : BCM2835 GPIO JTAG/SWD bitbang driver
Info : JTAG only mode enabled (specify swclk and swdio gpio to add SWD mode)
Info : clock speed 500 kHz
Info : JTAG tap: imx27.etb tap/device found: 0x1b900f0f (mfg: 0x787 (<unknown>), part: 0xb900, ver: 0x1)
Info : JTAG tap: imx27.cpu tap/device found: 0x07926121 (mfg: 0x090 (Chip Express), part: 0x7926, ver: 0x0)
Info : Embedded ICE version 6
Info : imx27.cpu: hardware has 2 breakpoint/watchpoint units
Info : ETM v1.3
Info : Listening on port 3333 for gdb connections
Warn : WARNING: unknown debug reason: 0xf
Error: invalid mode value encountered 7
Warn : ThumbEE -- incomplete support
Error: cpsr contains invalid mode value - communication failure
Polling target imx27.cpu failed, trying to reexamine
Info : ETM v1.3
Error: invalid mode value encountered 0
target halted in Thumb state due to debug-request, current mode: Thread
cpsr: 0x00000020 pc: 0xffffffee
MMU: disabled, D-Cache: disabled, I-Cache: disabled
target halted in Thumb state due to debug-request, current mode: Abort
cpsr: 0x800000b7 pc: 0xffffffee
Info : ETM v1.3
target halted in ThumbEE state due to debug-request, current mode: Thread
cpsr: 0xffff1020 pc: 0xffff01f6
Info : ETM v1.3
Error: cp15 read operation timed out
Info : ETM v1.3
Info : ETM v1.3
cpsr: 0xa00000b7 pc: 0xffffffee
Info : ETM v1.3
cpsr: 0xffff1020 pc: 0xffff02be
Info : ETM v1.3
Info : ETM v1.3
Info : ETM v1.3
target halted in ThumbEE state due to debug-request, current mode: System
cpsr: 0xffffffff pc: 0xffff0b26
cpsr: 0x00000020 pc: 0xffffffed
Info : ETM v1.3
target halted in ThumbEE state due to debug-request, current mode: User
cpsr: 0xffff0270 pc: 0xffff0922
Info : ETM v1.3
Info : ETM v1.3
Info : ETM v1.3
Info : ETM v1.3
Info : ETM v1.3
Info : ETM v1.3
Warn : WARNING: unknown debug reason: 0xf^CError: invalid mode value encountered 0
It is wired correct. Checked it a million times!
Gleno0hh
Post by Gleno0hh »
Wow... My post got deleted?
I think you keep editing the same post, right?
Wouldn't do that if I were you. Just add incremental info, or wait until you have a more or less complete post to fill.
Gleno0hh
Post by Gleno0hh »
marcelr wrote:??
Editted once. I tought it was worth to mention that i wired it correctly, before it becomes a suggestion.
Gleno0hh
Post by Gleno0hh »
Managed to root with a other raspberry.
I do suggest that the tutorial gets an update...
There are missing commands in the English part which are in the Dutch part.
Thank though, time to customize it.
Post by TheHogNL »
Did you use the Toon Rooter on https://github.com/martenjacobs/ToonRooter ?
Gleno0hh
Post by Gleno0hh »
TheHogNL wrote:Did you use the Toon Rooter on https://github.com/martenjacobs/ToonRooter ?
Tried, didnt work with raspberry 1a. Actually, nothing worked with the 1a, see my previous post. After using a model b, it was easy. I believe with the model b it gave me a import error on pyserial with toonrooter.
mogwai
Post by mogwai »
mogwai wrote:I recently rooted my Toon succesfully, but using ToonRooter on RasPI. After that I followed to manual for "hardening the Toon" and get it completely disconnected from Quby. All went well except for this part
Seems like my post drowned in others. Still bugs me why the hosts.template is not working. Any hints?
Return to “Toon Rooting”
