Hi Guys,
I thing my Toon is crashed:
FW version 4.4.21 / U-Boot 2010.09-R8
download wget
http://files.domoticaforum.eu/uploads/T ... r0_qb2.ipk
eneco-001-xxxxxx:~# opkg install dropbear_2015.71-r0_qb2.ipk
Installing dropbear (2015.71-r0) to root...
Installing libc6 (2.21-r0) to root...
Downloading
http://feed.hae.int/feeds/qb2/oe/angeli ... armv5e.ipk.
Removing package glibc from root...
Removing package glibc-patch-dns from root...
Installing glibc (2.10.1-r37.1) to root...
Downloading
http://feed.hae.int/feeds/qb2/oe/angeli ... .1_qb2.ipk.
Collected errors:
* pkg_run_script: package "glibc-patch-dns" postrm script returned status 255.
* opkg_install_pkg: Failed to verify the signature of /var/lib/opkg/oe-2.6.36-base-r17-splash2.
* opkg_install_cmd: Cannot install package dropbear.
eneco-001-031019:~# ls -l
-sh: /bin/ls: not found
eneco-001-031019:~# cd /
eneco-001-031019:/# ls -l
eneco-001-031019:/# cd root
eneco-001-031019:~# cat
-sh: cat: not found
Can't see or find any files
After reboot toon stops with a panic kernel:
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: file system size: 119476224 bytes (116676 KiB, 113 MiB, 926 LEBs)
UBIFS: journal size: 9033728 bytes (8822 KiB, 8 MiB, 71 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root: 0 bytes (0 KiB)
VFS: Mounted root (ubifs filesystem) on device 0:13.
Freeing init memory: 104K
Kernel panic - not syncing: No init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance.
[<c00273d0>] (unwind_backtrace+0x0/0xf0) from [<c029e720>] (panic+0x60/0x190)
[<c029e720>] (panic+0x60/0x190) from [<c00223dc>] (init_post+0x78/0xc4)
[<c00223dc>] (init_post+0x78/0xc4) from [<c0008b54>] (kernel_init+0x110/0x14c)
[<c0008b54>] (kernel_init+0x110/0x14c) from [<c00238ec>] (kernel_thread_exit+0x0/0x8)
Any idea whats happend ?
