Noticed that too, bu since the debuglog showed the ToonRooter logging on just fine everytime I ignored it where I apparently shouldn't have. Apologies for that.
Anyway, ran the ToonRooter again with debug log. See the output below.
I checked the output, but can't really find anything weird on it.
After running the ToonRooter again I reset the Toon with the reset button after ToonRooter was done, but unfortunately minicom still showed R10 as U-Boot version.
pi@raspberrypi:~/ToonRooter $ sudo python . --jtag-available --output-level DEBUG
INFO:__main__:Starting up...
INFO:__main__:Detected JTAG hardware 'rpi3'
INFO:__main__:Written private and public key pair to ./id_rsa and ./id_rsa.pub, respectively
DEBUG:__main__:{"has_jtag": true, "check_uboot": true, "boot_only": false, "reboot_after": true, "cleanup_payload": true, "port": "/dev/serial0", "jtag_hardware": "rpi3", "ssh_pubkey_data": "ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQDjbXDSHRyCBjGmy4tutpHqJ14makqEyaBChF0JmmDjX7f/E4UUJlx92How2Nm0EpfzLRGa4eoPkMgjkfhDefi8EB3pzegQ4KRcz/PpZPMQ0yh/sUgeCG3GpkvGDswyDqG44B3EUR02u4ZRfH7rmMf0FwdJJQa3y7SHo2cMfZNMoAFf4CydMVlj7bHR5tH2h3QAgAEaUcZZ0yIx/RGvgZQ0vY7ZtJj1IxZPZ3ThcK01+aIoNo4ylgiDUoYSeh0t4+3Cnn3I+pR9PEu0ZFhRmR4USzfFMpNoruJVSRpFTxCCk1+5/JfXbRUtq5wvLPd+hJs6Vyn2AULuxMXfuI2s6RiX"}
INFO:rooter:Waiting for Toon to restart
INFO:rooter:Toon has U-Boot version 2010.09-R10
INFO:rooter:Loading new bootloader
INFO:rooter:Starting openocd
INFO:rooter:Waiting for 10 seconds
DEBUG:rooter:Open On-Chip Debugger
INFO:rooter:Halting CPU
DEBUG:rooter:soft_reset_halt
requesting target halt and executing a soft reset
target halted in ARM state due to debug-request, current mode: Supervisor
cpsr: 0x000000d3 pc: 0x00000000
MMU: disabled, D-Cache: disabled, I-Cache: disabled
DEBUG:rooter:reset halt
JTAG tap: imx27.etb tap/device found: 0x1b900f0f (mfg: 0x787 (<unknown>), part: 0xb900, ver: 0x1)
JTAG tap: imx27.cpu tap/device found: 0x07926121 (mfg: 0x090 (Chip Express), part: 0x7926, ver: 0x0)
srst pulls trst - can not reset into halted mode. Issuing halt after reset.
cpsr: 0x200000d3 pc: 0xa1f20580
MMU: disabled, D-Cache: disabled, I-Cache: enabled
NOTE! Severe performance degradation without fast memory access enabled. Type 'help fast'.
INFO:rooter:Loading new image to RAM
DEBUG:rooter:load_image assets/u-boot.bin 0xa1f00000
166504 bytes written at address 0xa1f00000
downloaded 166504 bytes in 2.108246s (77.126 KiB/s)
INFO:rooter:Starting up new image
INFO:rooter:Using password to log in
INFO:rooter:Logging in to U-Boot
DEBUG:rooter:
CPU: Freescale i.MX27 at 400.168 MHz
Prodrive B.V. ED2.0
DRAM: 128 MiB
NAND: 128 MiB
LCD: 800x480, pbb 4
LCD: Drawing the logo...
In: serial
Out: serial
Err: serial
Display-bmp: 800 x 480 with 16777216 colors
Net: FEC
Address in SROM is 00:00:20:03:00:00
Address in environment is 00:0f:11:08:9b:9a
Autoboot in 2 sec...
Enter the password to interrupt.
The password is: toon
U-Boot>
DEBUG:rooter:Logged in to U-Boot
INFO:rooter:Patching U-Boot
DEBUG:rooter:printenv
bootdelay=2
baudrate=115200
loadaddr=0xA1000000
bootdelay=2
mtdids=nand0=mxc_nand
mtdparts=mtdparts=mxc_nand:1M(u-boot)ro,512K(u-boot-env)ro,1536K(splash-image),3M(kernel),3M(kernel-backup),119M(rootfs)
mtdparts_kernel=mtdparts=mxc_nand:512K@0x00100000(u-boot-env)ro,1536K(splash-image),3M(kernel),3M(kernel-backup),119M(rootfs)
mem=128M
autoload=no
backlight_brightness=50
baudrate=115200
console=ttymxc0
addtty=setenv bootargs ${bootargs} console=${console},${baudrate}
addmtd=setenv bootargs ${bootargs} ${mtdparts_kernel}
addlcd=setenv bootargs ${bootargs} lcd=${lcd}
nandargs=setenv bootargs ubi.mtd=4 root=ubi0:rootfs rw rootfstype=ubifs
boot_nand=run nandargs addmtd addtty addmisc addlcd; nand read ${loadaddr} kernel; bootm ${loadaddr}
boot_nand_backup=run nandargs addmtd addtty addmisc addlcd; nand read ${loadaddr} kernel-backup; bootm ${loadaddr}
bootcmd=run boot_nand
splashimage=0x180000
ethact=FEC
sn=16-39-013-828
pn=6599-1500-4100
software_compatibility=0
manufacture_date=2016/10
ethaddr=00:0F:11:08:9B:9A
addmisc=setenv bootargs ${bootargs} mem=${mem} lpj=999424
lcd=TDA-WVGA0700F00048
Environment size: 1106/131068 bytes
U-Boot>
DEBUG:rooter:bootdelay=2
DEBUG:rooter:baudrate=115200
DEBUG:rooter:loadaddr=0xA1000000
DEBUG:rooter:mtdids=nand0=mxc_nand
DEBUG:rooter:mtdparts=mtdparts=mxc_nand:1M(u-boot)ro,512K(u-boot-env)ro,1536K(splash-image),3M(kernel),3M(kernel-backup),119M(rootfs)
DEBUG:rooter:mtdparts_kernel=mtdparts=mxc_nand:512K@0x00100000(u-boot-env)ro,1536K(splash-image),3M(kernel),3M(kernel-backup),119M(rootfs)
DEBUG:rooter:mem=128M
DEBUG:rooter:autoload=no
DEBUG:rooter:backlight_brightness=50
DEBUG:rooter:console=ttymxc0
DEBUG:rooter:addtty=setenv bootargs ${bootargs} console=${console},${baudrate}
DEBUG:rooter:addmtd=setenv bootargs ${bootargs} ${mtdparts_kernel}
DEBUG:rooter:addlcd=setenv bootargs ${bootargs} lcd=${lcd}
DEBUG:rooter:nandargs=setenv bootargs ubi.mtd=4 root=ubi0:rootfs rw rootfstype=ubifs
DEBUG:rooter:boot_nand=run nandargs addmtd addtty addmisc addlcd; nand read ${loadaddr} kernel; bootm ${loadaddr}
DEBUG:rooter:boot_nand_backup=run nandargs addmtd addtty addmisc addlcd; nand read ${loadaddr} kernel-backup; bootm ${loadaddr}
DEBUG:rooter:bootcmd=run boot_nand
DEBUG:rooter:splashimage=0x180000
DEBUG:rooter:ethact=FEC
DEBUG:rooter:sn=16-39-013-828
DEBUG:rooter:pn=6599-1500-4100
DEBUG:rooter:software_compatibility=0
DEBUG:rooter:manufacture_date=2016/10
DEBUG:rooter:ethaddr=00:0F:11:08:9B:9A
DEBUG:rooter:addmisc=setenv bootargs ${bootargs} mem=${mem} lpj=999424
DEBUG:rooter:lcd=TDA-WVGA0700F00048
DEBUG:rooter:
DEBUG:rooter:Environment size: 1106/131068 bytes
DEBUG:rooter:U-Boot>
DEBUG:rooter: setenv addmisc setenv bootargs \${bootargs} mem=\${mem} lpj=999424 init=/bin/sh
U-Boot>
INFO:rooter:Waiting for boot up
DEBUG:rooter: run boot_nand
NAND read: device 0 offset 0x300000, size 0x300000
3145728 bytes read: OK
## Booting kernel from Legacy Image at a1000000 ...
Image Name: Linux-2.6.36-R10-h27
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 1944336 Bytes = 1.9 MiB
Load Address: a0008000
Entry Point: a0008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.36-R10-h27 (jbraam@dvl) (gcc version 4.5.3 20110223 (prerelease) (GCC) ) #1 PREEMPT Tue Oct 25 20:03:05 CEST 2016
CPU: ARM926EJ-S [41069264] revision 4 (ARMv5TEJ), cr=00053177
CPU: VIVT data cache, VIVT instruction cache
Machine: Prodrive B.V ED2.0
Memory policy: ECC disabled, Data cache writeback
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Kernel command line: ubi.mtd=4 root=ubi0:rootfs rw rootfstype=ubifs mtdparts=mxc_nand:512K@0x00100000(u-boot-env)ro,1536K(splash-image),3M(kernel),3M(kernel-backup),119M(rootfs) console=ttymxc0,115200 mem=128M lpj=999424 init=/bin/sh lcd=TDA-WVGA0700F00048
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 128MB = 128MB total
Memory: 126092k/126092k available, 4980k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xffa00000 - 0xffe00000 ( 4 MB)
vmalloc : 0xc8800000 - 0xf4000000 ( 696 MB)
lowmem : 0xc0000000 - 0xc8000000 ( 128 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.init : 0xc0008000 - 0xc0022000 ( 104 kB)
.text : 0xc0022000 - 0xc0367000 (3348 kB)
.data : 0xc037e000 - 0xc03a17a0 ( 142 kB)
Hierarchical RCU implementation.
RCU-based detection of stalled CPUs is disabled.
Verbose stalled-CPUs detection is disabled.
NR_IRQS:272
MXC IRQ initialized
MXC GPIO hardware
Console: colour dummy device 80x30
Calibrating delay loop (skipped) preset value.. 199.88 BogoMIPS (lpj=999424)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
Configured for LCD: TDA-WVGA0700F00048
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Switching to clocksource mxc_timer1
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
msgmni has been set to 246
io scheduler noop registered (default)
Serial: IMX driver
imx-uart.0: ttymxc0 at MMIO 0x1000a000 (irq = 20) is a IMX
console [ttymxc0] enabled
imx-uart.1: ttymxc1 at MMIO 0x1000b000 (irq = 19) is a IMX
imx-uart.2: ttymxc2 at MMIO 0x1000c000 (irq = 18) is a IMX
NAND device: K9F1G08U0E detected, disabling sub-page writes
NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bit)
Scanning device for bad blocks
RedBoot partition parsing not available
5 cmdlinepart partitions found on MTD device mxc_nand
Creating 5 MTD partitions on "mxc_nand":
0x000000100000-0x000000180000 : "u-boot-env"
0x000000180000-0x000000300000 : "splash-image"
0x000000300000-0x000000600000 : "kernel"
0x000000600000-0x000000900000 : "kernel-backup"
0x000000900000-0x000008000000 : "rootfs"
UBI: attaching mtd4 to ubi0
UBI: physical eraseblock size: 131072 bytes (128 KiB)
UBI: logical eraseblock size: 126976 bytes
UBI: smallest flash I/O unit: 2048
UBI: VID header offset: 2048 (aligned 2048)
UBI: data offset: 4096
UBI: max. sequence number: 169999
UBI: attached mtd4 to ubi0
UBI: MTD device name: "rootfs"
UBI: MTD device size: 119 MiB
UBI: number of good PEBs: 952
UBI: number of bad PEBs: 0
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 4096
UBI: number of internal volumes: 1
UBI: number of user volumes: 1
UBI: available PEBs: 0
UBI: total number of reserved PEBs: 952
UBI: number of PEBs reserved for bad PEB handling: 9
UBI: max/mean erase counter: 492/178
UBI: image sequence number: 1701871061
UBI: background thread "ubi_bgt0d" started, PID 309
at25 spi0.0: 32 KByte at25640B eeprom, pagesize 64
spi_imx spi_imx.0: probed
FEC Ethernet Driver
fec_enet_mii_bus: probed
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
mxc-ehci mxc-ehci.0: initializing i.MX USB Controller
mxc-ehci mxc-ehci.0: portsc setup 1: 0x80000000
mxc-ehci mxc-ehci.0: Work around for USB enabled
ULPI transceiver vendor/product ID 0x0424/0x000d
mxc-ehci mxc-ehci.0: Freescale On-Chip EHCI Host Controller
mxc-ehci mxc-ehci.0: new USB bus registered, assigned bus number 1
mxc-ehci mxc-ehci.0: irq 56, io mem 0x10024000
mxc-ehci mxc-ehci.0: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: Freescale On-Chip EHCI Host Controller
usb usb1: Manufacturer: Linux 2.6.36-R10-h27 ehci_hcd
usb usb1: SerialNumber: mxc-ehci.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mxc-ehci mxc-ehci.2: initializing i.MX USB Controller
mxc-ehci mxc-ehci.2: portsc setup 1: 0x80000000
mxc-ehci mxc-ehci.2: Work around for USB enabled
mxc-ehci mxc-ehci.2: Freescale On-Chip EHCI Host Controller
mxc-ehci mxc-ehci.2: new USB bus registered, assigned bus number 2
mxc-ehci mxc-ehci.2: irq 55, io mem 0x10024400
mxc-ehci mxc-ehci.2: USB 2.0 started, EHCI 1.00
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: Freescale On-Chip EHCI Host Controller
usb usb2: Manufacturer: Linux 2.6.36-R10-h27 ehci_hcd
usb usb2: SerialNumber: mxc-ehci.2
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver usbserial
usbserial: USB Serial Driver core
input: TSC2007 Touchscreen as /devices/virtual/input/input0
rtc-isl1208 1-006f: chip found, driver version 0.3
rtc-isl1208 1-006f: rtc core: registered rtc-isl1208 as rtc0
i2c /dev entries driver
tmp431 0-004c: Could not read configuration register (-5)
imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
adt7410 0-0048: adt7410 temperature sensor registered.
adt7410 0-0049: adt7410 temperature sensor registered.
nf_conntrack version 0.5.0 (1970 buckets, 7880 max)
ip_tables: (C) 2000-2006 Netfilter Core Team
TCP cubic registered
NET: Registered protocol family 17
Bridge firewalling registered
rtc-isl1208 1-006f: setting system clock to 2019-01-29 17:18:52 UTC (1548782332)
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: file system size: 117833728 bytes (115072 KiB, 112 MiB, 928 LEBs)
UBIFS: journal size: 9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root: 0 bytes (0 KiB)
usb 2-1: new high speed USB device using mxc-ehci and address 2
VFS: Mounted root (ubifs filesystem) on device 0:13.
Freeing init memory: 104K
usb 2-1: New USB device found, idVendor=148f, idProduct=5370
usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 2-1: Product: 802.11 n WLAN
usb 2-1: Manufacturer: Ralink
usb 2-1: SerialNumber: 1.0
/bin/sh: can't access tty; job control turned off
INFO:rooter:Transferring payload
INFO:rooter:Patching Toon
DEBUG:rooter:/ #
DEBUG:rooter:sh payload/patch_toon.sh "DIMPGRD2"
INFO:rooter:>>> Enabling root user. Your root password is: DIMPGRD2
INFO:rooter:>>> Opening ports 22, 80 and 10080 on firewall
INFO:rooter:>>> Installing dropbear
DEBUG:rooter:Installing dropbear (2015.71-r0) to root...
DEBUG:rooter:Installing libc6 (2.21-r0) to root...
DEBUG:rooter:Downloading http://feed.hae.int/feeds/qb2/oe/angelica-1.4.0-master-qt5112-ssl102-aws/armv5e/libc6_2.21-r0_armv5e.ipk.
DEBUG:rooter:Collected errors:
DEBUG:rooter:* opkg_download: Failed to download http://feed.hae.int/feeds/qb2/oe/angelica-1.4.0-master-qt5112-ssl102-aws/armv5e/libc6_2.21-r0_armv5e.ipk: Couldn't connect to server.
DEBUG:rooter:* opkg_install_pkg: Failed to download libc6. Perhaps you need to run 'opkg update'?
DEBUG:rooter:* opkg_install_cmd: Cannot install package dropbear.
DEBUG:rooter:sh: can't open '/usr/lib/opkg/info/dropbear.postinst'
INFO:rooter:Cleaning up
DEBUG:rooter:rm -r payload
INFO:rooter:Rebooting
INFO:rooter:Your Toon is now rooted. Please wait for it to boot up and try to log in using SSH
