Toon for Android
Re: Toon for Android
Postby ikookmaar » Mon Apr 29, 2019 11:20 pm
Could anyone direct me to some instructions on how and where to configure a redirection service using an an Api token (or login authentication, if it works) to safely control the Toon from the internet with this app?.
This is not exactly the same as a reverse-proxy, is it?
I have a Raspberry Pi I could use, running Apache2 as well as Domoticz (haven't figured out what webserver this runs on) ...
Thanks!
ikookmaar
Postby mAiden » Tue Apr 30, 2019 11:12 am
ikookmaar wrote:Could anyone direct me to some instructions on how and where to configure a redirection service using an an Api token (or login authentication, if it works) to safely control the Toon from the internet with this app?.
Thanks!
You could look to run OpenVPN on your Raspberry PI, to use the Toon app? I use a Draytek VPN to connect to my PI or my rooted Toon.
mAiden
Postby RoadXY » Tue Apr 30, 2019 5:17 pm
Thanks!
Redirection service could be used with an reverse proxy while adding an extra header.
Based on the header the proxy will proxy the requests through to your internal device (i.e. Toon).
I'm working on using a reverese proxy with basic authentication and ssl.
If I got this working I'll be updating the app to support this scenario.
An nice feature would be to have an cloud connection and have Toon set up an VPN to it.
Maybe someday :D
RoadXY
Postby glsf91 » Tue Apr 30, 2019 5:21 pm
Thanks!
Configure OpenVPN on your router. Install openVPN on your phone. Then you can access everything from your phone in your house.
glsf91
Postby _Arjen_ » Tue Apr 30, 2019 7:52 pm
RoadXY wrote:An nice feature would be to have an cloud connection and have Toon set up an VPN to it.
Maybe someday :D
Well, since openvpn is already installed on Toon, one could adapt the config. We can setup Toon as vpn-server or use vpn-client to connect to another server as Eneco so one can access it via that VPN-server.
_Arjen_
Postby ikookmaar » Tue Apr 30, 2019 8:29 pm
All nice ideas, but how is (or was) this "Gebruik redirection service" and "Api token" intended to be used?
ikookmaar
Postby RoadXY » Tue Apr 30, 2019 10:18 pm
ikookmaar wrote:All nice ideas, but how is (or was) this "Gebruik redirection service" and "Api token" intended to be used?
See my previous reply, using a reverse proxy while using custom headers
RoadXY
Postby anconakip » Tue May 07, 2019 4:57 pm
i want to use this app to. But i need to fill in the "Toon poort". how can i find this?
anconakip
Postby _Arjen_ » Tue May 07, 2019 7:51 pm
It is 10080
_Arjen_
Postby anconakip » Wed May 08, 2019 6:53 am
_Arjen_ wrote:It is 10080
Nope. Sorry. The the app say to me: pagina niet gevonden op apparaat.
And if i do 10800 the iT says: geen reactie van apparaat.
anconakip
Postby WickedMaster » Wed May 08, 2019 1:09 pm
You can try port 80 as well.
WickedMaster
Postby mAiden » Wed May 08, 2019 7:11 pm
Go to you're iptables (/etc/default/iptables), and look for this line:
-A HCB-INPUT -p tcp -m tcp --dport 22 --tcp-flags SYN,RST,ACK SYN -j ACCEPT
-A HCB-INPUT -p tcp -m tcp --dport 80 --tcp-flags SYN,RST,ACK SYN -j ACCEPT
-A HCB-INPUT -p tcp -m tcp --dport 10080 --tcp-flags SYN,RST,ACK SYN -j ACCEPT
mAiden
Postby RoadXY » Tue May 14, 2019 8:59 pm
Anyone using a Nokia Nokia 7.1 (CTL_sprout) on Android 9?
I'v got like 40 crashes on 12 mei at 17:09
I've received a lot of crash reports from this user and I'd like to investigate what goes wrong.
RoadXY
Postby PeJeWe » Sat May 18, 2019 7:35 pm
the app starts, then i fill in the IP and the port 10800,i get the positive connection "aangemeld" then the app crashes and keeps crashing after restart.
Android 8.1
edit:
after firmware update 5.5.7 i get the error wrong host.
ip_adress_toon/qmf/www gives an error 404
Rooted Toon 1, Domoticz running on a RPI3b+, RFXCOM XL, RFLINK.
PeJeWe
Postby mAiden » Sat May 18, 2019 9:24 pm
PeJeWe wrote:the app starts, then i fill in the IP and the port 10800,i get the positive connection "aangemeld" then the app crashes and keeps crashing after restart.
Android 8.1
edit:
Try to run update-rooted.sh script with the -f parameter.
mAiden
PreviousNext
Return to Toon external control
cron
