Controlling Toon via Domoticz
Re: Controlling Toon via Domoticz
Postby Jobsoft » Thu Jul 18, 2019 9:16 pm
TerrorSource wrote:Hi guys,
As requested by a few users around here i've created a how-to manual to control Toon via Domoticz.
It's pretty much a step-by-step guide and should be enough to get it working within 20-30minutes.
The complete manual is based off information and scripts found on: https://www.domoticz.com/forum/viewtopic.php?t=11421
Please ask for support in the topic/url mention above. The scripts are made by users on that forum, not by me.
I will not take credit for the scripts.
I will however create a new version of the manual when there are errors or improvements possible in the current manual.
I wil not support this manual or the content of it!
There's are seperate manuals for Dutch and English.
Please do NOT distribute this document or the content in any kind. It is for personal use only.
Version 2 available now:
- Fixes typo's
- Added LUA/DzVents option enabling
Dutch: Download v2
English: Download v2
If I set it up my Domoticz crashes. If I disable the Toon script it doesn't crash. I did exactly what was in the manual and checked it for typo's 5 times. I have no clue how to fix this.
Can someone point me in the right direction please?
Thanks!
Jobsoft
Postby witteherder » Thu Jul 25, 2019 4:17 pm
At step 7 I have put by Eventsystem everything on ON
Then I went to Setup More options then to Eventst to add scipts.
Then I see this like in my attachement.
1. Where can i put/add extra script Toon_script.txt
2. I also see in this topic that its not working by everybody who has a Toon2: What do i have to change in this script:
commandArray = {}
    ToonThermostatSensorName = uservariables['UV_ToonThermostatSensorName'] -- Sensor showing current setpoint
    ToonTemperatureSensorName = uservariables['UV_ToonTemperatureSensorName'] -- Sensor showing current room temperature
    ToonScenesSensorName  = uservariables['UV_ToonScenesSensorName'] -- Sensor showing current program
    ToonAutoProgramSensorName = uservariables['UV_ToonAutoProgramSensorName'] -- Sensor showing current auto program status
   ToonBurnerName = uservariables['UV_ToonBurnerName']
   ToonProgramInformationSensorName = uservariables['UV_ToonProgramInformationSensorName'] -- Sensor showing displaying program information status
   ToonBoilerTempSetpoint = uservariables['UV_ToonBoilerTempSetpointSensorName'] -- Sensor showing current internal boiler temp
    ToonIP = uservariables['UV_ToonIP']
    DomoticzIP = uservariables['UV_DomoticzIP']
-- Choose the correct platform which Domoticz runs on
-- Remove -- before the line which applies for your situation, set -- for all other platforms
    json = assert(loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()  -- For Raspberry
--  json = assert(loadfile "/opt/domoticz/scripts/lua/JSON.lua")()  -- For Linux (LEDE)
--  json = assert(loadfile "C:\\Program Files (x86)\\Domoticz\\scripts\\lua\\json.lua")() -- For Windows
--  json = assert(loadfile "/volume1/@appstore/domoticz/var/scripts/lua/JSON.lua")() -- For Synology
    local handle = assert(io.popen(string.format('curl -m 5 http://%s/happ_thermstat?action=getThermostatInfo', ToonIP)))
        local ThermostatInfo = handle:read('*all')
    handle:close()
-- JSON data from Toon contains a extra "," which should not be there.
ThermostatInfo = string.gsub(ThermostatInfo, ",}", "}")
    jsonThermostatInfo = json:decode(ThermostatInfo)
    if jsonThermostatInfo ~= nil then
    currentSetpoint = tonumber(jsonThermostatInfo.currentSetpoint) / 100
    currentTemperature = tonumber(jsonThermostatInfo.currentTemp) / 100
    currentProgramState = tonumber(jsonThermostatInfo.programState)
    currentActiveState = tonumber(jsonThermostatInfo.activeState)
    currentNextTime = jsonThermostatInfo.nextTime
   currentBurnerInfo = tonumber(jsonThermostatInfo.burnerInfo)
    currentNextSetPoint = tonumber(jsonThermostatInfo.nextSetpoint) / 100
   currentBoilerSetPoint = tonumber(jsonThermostatInfo.currentInternalBoilerSetpoint)
        if currentSetpoint ~= nil then
            -- Update the thermostat sensor to current setpoint
            if otherdevices_svalues[ToonThermostatSensorName]*100 ~= currentSetpoint*100 then
                print('Updating thermostat sensor to new set point: ' ..currentSetpoint)
                commandArray[1] = {['Variable:UV_ToonChangedByDomoticz'] = '1'} -- Set variable changed to 1 to prevent script ToonSetPoint from shooting an event at Toon
                commandArray[2] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonThermostatSensorName], currentSetpoint)}
            end
        end
        if currentTemperature ~= nil then
            -- Update the temperature sensor to current room temperature
            if otherdevices_svalues[ToonTemperatureSensorName]*100 ~= currentTemperature*100 then
                print('Updating the temperature sensor to new value: ' ..currentTemperature)
                commandArray[3] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonTemperatureSensorName], currentTemperature)}
            end
        end
        if currentBoilerSetPoint ~= nil then
         -- Update the temperature of boiler
         if otherdevices_svalues[ToonBoilerTempSetpoint]*100 ~= currentBoilerSetPoint*100 then
            print('Updating the boiler temperature to new value: ' ..currentBoilerSetPoint)
            commandArray[3] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonBoilerTempSetpoint], currentBoilerSetPoint)}
         end
      end
        if currentActiveState ~= nil then
            -- Update the toon scene selector sensor to current program state
            CurrentToonScenesSensorValue = otherdevices_svalues[ToonScenesSensorName]
            if currentActiveState == -1 then currentActiveState = '50' -- Manual
            elseif currentActiveState == 0 then currentActiveState = '40' -- Comfort
            elseif currentActiveState == 1 then currentActiveState = '30' -- Home
            elseif currentActiveState == 2 then currentActiveState = '20' -- Sleep
            elseif currentActiveState == 3 then currentActiveState = '10' -- Away
            end
            if CurrentToonScenesSensorValue ~= currentActiveState then  -- Update toon selector if it has changed
                print ('Updating Toon Scenes selector')
                commandArray[4] = {['UpdateDevice'] = string.format('%s|1|%s', otherdevices_idx[ToonScenesSensorName], currentActiveState)}
            end
        end
        if currentProgramState ~= nil then
            -- Updates the toon auto program switch
            CurrentToonAutoProgramSensorValue = otherdevices_svalues[ToonAutoProgramSensorName]
           if currentProgramState == 0 then currentProgramState = '10' -- No
            elseif currentProgramState == 1 then currentProgramState = '20' -- Yes
            elseif currentProgramState == 2 then currentProgramState = '30' -- Temporary
            end
            if CurrentToonAutoProgramSensorValue ~= currentProgramState then -- Update toon auto program selector if it has changed
                print ('Updating Toon Auto Program selector')
                commandArray[5] = {['UpdateDevice'] = string.format('%s|1|%s', otherdevices_idx[ToonAutoProgramSensorName], currentProgramState)}
            end
        end
        if currentNextTime ~= nil and currentNextSetPoint ~= nil then
            -- Updates the toon program information text box
            CurrentToomProgramInformationSensorValue = otherdevices_svalues[ToonProgramInformationSensorName]
            if currentNextTime == 0 or currentNextSetPoint == 0 then
                ToonProgramInformationSensorValue = 'Op ' ..currentSetpoint.. '°'
            else
                ToonProgramInformationSensorValue = 'Om ' ..os.date('%H:%M', currentNextTime).. ' op ' ..currentNextSetPoint.. '°'
            end
            if CurrentToomProgramInformationSensorValue ~= ToonProgramInformationSensorValue then
                commandArray[6] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonProgramInformationSensorName], ToonProgramInformationSensorValue)}
            end
        end
         -- Update the toon burner selector to current program state
         CurrentToonBurnerValue = otherdevices_svalues[ToonBurnerName]
         if currentBurnerInfo == 0 then currentBurnerInfo = '0' -- uit
         elseif currentBurnerInfo == 1 then currentBurnerInfo = '10' -- cv aan
         elseif currentBurnerInfo == 2 then currentBurnerInfo = '20' -- warmwater aan
         end
         if CurrentToonBurnerValue ~= currentBurnerInfo then  -- Update toon burner selector if it has changed
            print ('Updating Toon burner info')
            commandArray[7] = {['UpdateDevice'] = string.format('%s|1|%s', otherdevices_idx[ToonBurnerName], currentBurnerInfo)}
         end
    end
return commandArray
Stap 7 Handleiding Toon Script toevoegen
Toon 2 Rooted User
Firmware version: 5.9.6
Raspberry Pi 3B+
Domoticz V4.10717
7 Neo Coolcam PowerPlus
Domotica Beginner (need little help in beginning)
witteherder
Postby TerrorSource » Fri Jul 26, 2019 9:49 am
MarcF wrote:To All,
Based on the manual from TerrorSource domoticaforum.eu/viewtopic.php?f=102&am ... mp;t=12097 and BOverdevest domoticaforum.eu/viewtopic.php?f=102&am ... p;start=15 I created 2 files.
// STARTING
Download the manual from TerrorSource, base topic page 1. This Manual explains how you create virtual sensors and define User Variables
The Virtual sensors (Devices) and User Variables you create need to have the EXACT value that is used within the scripts. If this doesn't match, the scripts won't work
To help you out, here is some helpfull data for setting up the Toon <=> Domoticz connection with the proces described by TerrorSource and the script from BOverdevest
NOTE: Download notepad++ if you don;y have it allready. It's free and very usefull! You can use it to replace some parts in the files (personal config settings)
When all is set up, you can use this script. Please also note the remarks in the top part to update some parts of the script to make it match your situation
When all is done correctly, it will work with a rooted Toon, fw 5.04. Maybe you need to install the boilerstatus module from the toonstore if you get boiler issues.
I'm getting the following errors:
2019-07-26 10:37:00.612 Error: dzVents: Error: (2.4.26) An error occurred when calling event handler Toon
2019-07-26 10:37:00.613 Error: dzVents: Error: (2.4.26) /home/pi/domoticz/dzVents/runtime/Utils.lua:45: attempt to perform arithmetic on local 'x' (a nil value)
TerrorSource
Postby brommetje » Wed Jul 31, 2019 10:54 am
Hi @MarcF thanks for your clear explanation, just implemented the script, devices etc. and it looks like it is working but if I have a look to the BoilerPressure is for example 18.9 BAR so I changed the script.
New postby MarcF » Fri Mar 08, 2019 8:27 pm
To All,
// STARTING
-- Update the Boiler water Pressure to current value
        local currentBoilerPressure = tonumber(jsonBoilerInfo.boilerPressure) * 10
        -- local currentBoilerPressure = tonumber(jsonBoilerInfo.boilerPressure) * 10
and now my BoilerPressure = 1.9 BAR and that looks OK so my question why did you do the calculation * 10 ?
Or is there already a new updated one or missing something?
Martin
brommetje
Postby witteherder » Sat Aug 17, 2019 3:18 pm
Where can I check this error from the Domoticz log file?
2019-08-17 16:01:34.568 Status: PROXY: Authenticate result: success.
2019-08-17 16:06:17.024 (Dummy) Thermostat (ToonThermostat)
2019-08-17 16:06:17.025 Status: EventSystem: reset all device statuses...
2019-08-17 16:06:17.173 Status: LUA: Updating the temperature sensor to new value: 24.11
2019-08-17 16:06:17.174 Status: EventSystem: Script event triggered: Toon
2019-08-17 16:06:17.176 Status: LUA: Setting Toon setpoint to 10.00
2019-08-17 16:06:17.176 Status: EventSystem: Fetching URL http://192.168.2.15/happ_thermstat?acti ... point=1000 after 0.2 seconds...
2019-08-17 16:06:17.176 Status: EventSystem: Script event triggered: ToonThermostat
2019-08-17 16:06:17.173 Error: EventSystem: in Toon: [string "commandArray = {}..."]:58: attempt to perform arithmetic on field '?' (a nil value)
2019-08-17 16:06:22.737 Status: EventSystem: reset all device statuses...
2019-08-17 16:06:25.093 Status: EventSystem: reset all device statuses...
2019-08-17 16:06:55.630 Status: EventSystem: reset all device statuses...
Toon 2 Rooted User
Raspberry Pi 3B+
Domoticz V4.10717
witteherder
Previous
Return to Toon external control
