android app TOON
- Starting Member
Re: android app TOON
Aad,
Thanks for the tip. There is an new release with fix.
https://github.com/jonkootje/toon-app
Sander & Martin
Sander & Martin
Thanks for sharing. Looks great and works smoothly.
For me the slider (program on/off) and the buttons (home/away/comfort/sleep) aren't working. As soon as the refreshinterval passes the changes are reverted.
Keep up the good work; I hope he has some more free time to finish (and support) the app.
There's a typo in the url for setting the mode:
http://toon:10080/happ_thermstat?action ... ureState=3
In the current code it says 'thermostat'. Without the 'o' it works fine.
Pull-request created.
FW 4.9.23
http://toonip
10080
FW 4.9.23
http://toonip
10080
- Starting Member
Up and running,
FW Toon 4.7.23 android 6.0.1 marsmallow
Great job, nice app.
Grz. Globegrabber
Grz. Globegrabber
Still no joy.
My android is ancient, 4.2-something, maybe that's why.
- Starting Member
All,
There is an new release with the adjusted Url. happ_thermostat is now happ_thermstat
With my Toon FW 4.8.25 it made no difference, both are working.
Rg,
Sander & Martin
Rg,
Sander & Martin
- Starting Member
First i try to to run it in the lan ip setting, with the modified apk this was no problem en was with the first attempting bingo,
Then struggle some time with the wwan ip setting, and after port forwarding from my router to port 10080 http server, i had initial port 10080 on Toon opened as mansions in the form turtuals for Toon about the vcn turtual.
And then was accessing Toon with the android apk bulls-eye.
Grz Globegrabber
Grz Globegrabber
- Starting Member
Looks great! Any plans for Apple as well
Hopefully somebody could build this for apple.
But I think there is an problem with that, the apple appstore.
with android you can always install apk files manual, with apple not the only way to do that is to jailbreak your apple device.
- Starting Member
Great to hear that it's working.
Be aware there is no security at all if you portforward your toon to the outside world.
Thats wy I use an VPN to connect to my lan.
It would be nice if the toon webserver could handle SSL en authentication, but I dont now how?
PS: Sorry to say but a IOS app is not within our possibilities
Not with everyoneMartin101010 wrote:Great to hear that it's working.
Toon's webserver (lighttpd) has ssl support built in. You just have to switch it on and redirect all outside communication through port 443. No big deal, if you ask me. Maybe you need to get a bunch of ssl certificates.Martin101010 wrote: It would be nice if the toon webserver could handle SSL en authentication, but I dont now how?
- Starting Member
Marcel,
We used https://websitetoapk.com/ to create the app.
I've noticed that other users complain about malware false positives.
I have a Galaxy S6 with Android 7 where the app is not working.
The difference is, on that phone the anti-malware is enabled and also reconizes the app as malware.
Maybe that’s also your problem.
furthermore, we like to enable the app to auto login while using ssl
First step is to enable ssl on toon. I've tried your example in this tread;
domoticaforum.eu/viewtopic.php?f=87& ... tpd#p82479
unfortunately, the server becomes unreachable on port 80 and 443. No clue why. As soon as I comment out the changes in the config file, port 80 is working again.
Any ideas why?
Any ideas why?
- Starting Member
I probably found the cause.
When I manually start lighttpd, I get the message; ssl requested but openssl is not compiled in.
I am on: lighttpd/1.4.33-devel-b27-3-g2da0ff3
Installed using lighttpd_1.4.33-28_qb2.ipk
Is there an ipk that I can use that has openssl compiled in?
# /HCBv2/bin/lighttpd -D -m /HCBv2/lib/lighttpd -f /HCBv2/etc/lighttpd/lighttpd.conf
[hdrv] libhcb_drv v0.1 r336 (Sep 7 2017 10:48:44) [master#4ff9b18d14]
[hcom] libhcb_com v0.1 r114 (Jul 3 2017 08:34:25) [master#893be971f0]
[hbxt] libhcb_boxtalk v0.1 r115 (Jun 30 2017 16:59:48) [master#8a175d01f2]
[hxml] libhcb_xml v0.1 r98 (Jun 21 2017 18:17:16) [master#ef293b2d11] (ezxml 0.8.6)
[hbas] libhcb_base v0.1 r287 (Sep 7 2017 11:00:16) [master#de173cbd21]
2018-01-05 13:13:22: (../../../src/network.c.400) SSL: ssl requested but openssl support is not compiled in
According to the executable it has ssl support built in. It should be enabled manually in /HCBv2/etc/lighttpd/lighttpd.conf. It's disabled by default.
- Starting Member
Marcel,marcelr wrote:According to the executable it has ssl support built in. It should be enabled manually in /HCBv2/etc/lighttpd/lighttpd.conf. It's disabled by default.
I did exacty what you discribed in an other tread;
Create the directory /HCBv2/etc/lighttpd/ssl, cd into it and issue:
openssl req -new -x509 -keyout lighttpd.pem -out lighttpd.pem -days 365 -nodes
Add ssl support to lighttpd by adding the following to its config file ( the part from #added onwards, until # end):
server.document-root = "/HCBv2/www"
$SERVER["socket"] == ":10080" {
#added MR! 20170526
$SERVER["socket"] == ":443" {
ssl.engine = "enable"
ssl.pemfile = "/HCBv2/etc/lighttpd/ssl/lighttpd.pem"
# end add
## where to send error-messages to
server.errorlog = "/tmp/lighttpd_error.log"
unfortunately lightttp will not start when I do that. That's why tried to start it manually to see what the error was with;
That's when I get the response;
So you have a version that differs from mine. Is there a pressing need for this functionality? It would mean a rebuild of the daemon and ssl libraries. It's possible, but it takes time, and that's a rare commodity as of this weekend.
