Controlling Toon via Domoticz
Moderators: marcelr, TheHogNL, TerrorSource, Toonz
Re: Controlling Toon via Domoticz
Postby madpatrick » Tue Nov 06, 2018 7:11 pm
Edwin66 wrote:
When i enter a number like dev_2.1 it gives an error right after putting it in, complaining about " expected ')' near '0.1' "
Guess this is something I need to work on tomorrow. Now it's time for other fun things
Is this in Domoticz or another program ?
Remove "." between 2.1
madpatrick
Postby mAiden » Wed Nov 07, 2018 9:12 am
Edwin,
You will have to search for the right dev. I'll have a look tonight, if I get him working, I can tell you which column you should look at.
mAiden
Postby Edwin66 » Wed Nov 07, 2018 6:42 pm
Was for domoticz. I indeed removed the '.' and seems to be working now.
Toon® (rooted) | Hue bulbs | TRÅDFRI bulbs | Smart Plug | Domoticz latest BETA |
I'm not a programmer, just wish things work MY way
Edwin66
Postby Edwin66 » Wed Nov 07, 2018 6:43 pm
mAiden wrote:Edwin,
I seem to have it working now. At least, I don't see any error's anymore.
Edwin66
Postby Edwin66 » Sat Nov 10, 2018 11:16 am
Nu merk ik dat de Toon-devices in Domoticz niet meer goed werkten. Dacht ze eventjes opnieuw te maken, maar... helaas... pindakaas, niet dus.
Deze devices zouden toch goed moeten zijn, in combinatie met de dzVents script?
Edwin66
Postby madpatrick » Sat Nov 10, 2018 7:50 pm
Check your Uservariables and then yor devices
Gebruikersvariabelen
Apparaten
What is your logfile saying ?
madpatrick
Postby Edwin66 » Sun Nov 11, 2018 11:24 am
Logfile wasn't saying anything at all. I think I've recreated the UV's and the devices. Next to do is adding the correct things to some of the devices. But that will have to wait till later this evening. Now first... a backup is in order, and then family visit. You know.. sunday
Edwin66
Postby Edwin66 » Tue Nov 13, 2018 6:48 pm
I think I;m going to give up.
Again I recreated all the user-variables:
and devices:
Using the following script:
return {
   on = {
      timer = {
         'every minute'
   execute = function(domoticz)
        local ToonThermostat        = domoticz.variables('UV_ToonThermostat').value             -- Sensor showing current setpoint
        local ToonTemperature       = domoticz.variables('UV_ToonTemperature').value            -- Sensor showing current room temperature
        local ToonBoilerTempIn      = domoticz.variables('UV_ToonBoilerTempIn').value           -- Sensor showing water temp return
        local ToonBoilerTempOut     = domoticz.variables('UV_ToonBoilerTempOut').value          -- Sensor showing current water temp out
        local ToonBoilerPressure    = domoticz.variables('UV_ToonBoilerPressure').value         -- Sensor showing current boiler pressure
        local ToonBoilerModulation  = domoticz.variables('UV_ToonBoilerModulation').value       -- Sensor showing current Boiler Modulation
        local ToonScenes            = domoticz.variables('UV_ToonScenes').value                 -- Sensor showing current program
        local ToonAutoProgram       = domoticz.variables('UV_ToonAutoProgram').value            -- Sensor showing current auto program status
        local ToonProgramInformation= domoticz.variables('UV_ToonProgramInformation').value     -- Sensor showing displaying program information status
        local ToonIP                = domoticz.variables('UV_ToonIP').value                     -- ToonIP
        local DomoticzIP            = domoticz.variables('UV_DomoticzIP').value                 -- DomoticzIP
        local ToonBurnerName        = domoticz.variables('UV_ToonBurnerName').value             --
        local P1SmartMeterPower     = domoticz.variables('UV_P1SmartMeterElectra').value        --
        local P1SmartMeterGas1      = domoticz.variables('UV_P1SmartMeterGasMeterStand').value  --
        local ToonBoilerSetpoint    = domoticz.variables('UV_ToonBoilerTempSetpoint').value     -- Sensor showing current boiler set point water temp out
        -- Handle json
        local json = assert(loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()  -- For Linux
        local handle = assert(io.popen(string.format('curl http://%s/happ_thermstat?action=getThermostatInfo', ToonIP)))
        local ThermostatInfo = handle:read('*all')
        handle:close()
        local jsonThermostatInfo = json:decode(ThermostatInfo)
        if jsonThermostatInfo == nil then
            return
        end
        local handle2 = assert(io.popen(string.format('curl http://%s/boilerstatus/boilervalues.txt', ToonIP)))
        local BoilerInfo = handle2:read('*all')
        handle2:close()
        -- JSON data from Toon contains a extra "," which should not be there.
        BoilerInfo = string.gsub(BoilerInfo, ",}", "}")
        jsonBoilerInfo = json:decode(BoilerInfo)
         -- http://IP_TOON/hdrv_zwave?action=getDevices.json
        local handle4 = assert(io.popen(string.format('curl http://%s/hdrv_zwave?action=getDevices.json', ToonIP)))
        local GasPowerInfo = handle4:read('*all')
        handle4:close()
        -- JSON data from Toon contains a extra "." which should not be there.
        GasPowerInfo = string.gsub(GasPowerInfo, "dev_4.", "dev_4")
        GasPowerInfo = string.gsub(GasPowerInfo, "dev_4:", "dev_4\":")
        local jsonGasPower = json:decode(GasPowerInfo)
        domoticz.log(jsonGasPower)                -- Lines disabled due to lack of working P1 connection
            local CurrentElectricityFlowHoog         = tonumber(jsonGasPower.dev_22.CurrentElectricityFlow )
            local CurrentElectricityQuantityHoog     = tonumber(jsonGasPower.dev_22.CurrentElectricityQuantity)
            local CurrentElectricityFlowLaag         = tonumber(jsonGasPower.dev_26.CurrentElectricityFlow )
            local CurrentElectricityQuantityLaag     = tonumber(jsonGasPower.dev_26.CurrentElectricityQuantity)
            local CurrentGasFlow                     = tonumber(jsonGasPower.dev_21.CurrentGasFlow)
            local CurrentGasQuantity                 = tonumber(jsonGasPower.dev_21.CurrentGasQuantity)
            local CurrentElectricityQuantity         = CurrentElectricityFlowHoog + CurrentElectricityFlowLaag
        -- local CurrentElectricityDeliveredLaag    = 0
        -- local CurrentElectricityDeliveredHoog    = 0
        -- local totalDeliveredPower                = 0
    domoticz.devices(P1SmartMeterPower).updateP1(CurrentElectricityQuantityLaag, CurrentElectricityQuantityHoog, CurrentElectricityDeliveredLaag, CurrentElectricityDeliveredHoog, CurrentElectricityQuantity, totalDeliveredPower).silent()
    domoticz.devices(P1SmartMeterGas1).updateGas(CurrentGasQuantity).silent()
-- Update the Boiler Water In to current value
       local currentboilerInTemp = tonumber(jsonBoilerInfo.boilerInTemp)
       if domoticz.utils.round(domoticz.devices(ToonBoilerTempIn).temperature,0) ~= domoticz.utils.round(currentboilerInTemp,0) then
        -- domoticz.log('Updating Boiler Water In to current value: ' ..currentboilerInTemp)
            domoticz.devices(ToonBoilerTempIn).updateTemperature(currentboilerInTemp).silent()
        end
-- Update the Boiler water Out to current value
     local currentboilerOutTemp = tonumber(jsonBoilerInfo.boilerOutTemp)
        if domoticz.utils.round(domoticz.devices(ToonBoilerTempOut).temperature,0) ~= domoticz.utils.round(currentboilerOutTemp,0) then
    --        -- domoticz.log('Updating Boiler Water Out to current value: ' ..currentboilerOutTemp)
            domoticz.devices(ToonBoilerTempOut).updateTemperature(currentboilerOutTemp).silent()
        end
-- Update the Boiler water Pressure to current value
        local currentBoilerPressure = tonumber(jsonBoilerInfo.boilerPressure) * 10
    --    if domoticz.utils.round(domoticz.devices(ToonBoilerPressure)._nValue,0) ~= domoticz.utils.round(currentBoilerPressure,0) then
    --        -- domoticz.log('Updating Boiler Pressure to current value: ' ..currentBoilerPressure)
    --        domoticz.devices(ToonBoilerPressure).updatePressure(currentBoilerPressure).silent()
    --    end
        local currentSetpoint = tonumber(jsonThermostatInfo.currentSetpoint) / 100
        local currentTemperature = tonumber(jsonThermostatInfo.currentTemp) / 100
        local currentProgramState = tonumber(jsonThermostatInfo.programState)
            if currentProgramState == 0 then currentProgramState = 10 -- No
                elseif currentProgramState == 1 then currentProgramState = 20 -- Yes
                elseif currentProgramState == 2 then currentProgramState = 30 -- Temporary
            end
        local currentActiveState = tonumber(jsonThermostatInfo.activeState)
            if currentActiveState == -1 then currentActiveState = 50 -- Manual
                elseif currentActiveState == 0 then currentActiveState = 40 -- Comfort
                elseif currentActiveState == 1 then currentActiveState = 30 -- Home
                elseif currentActiveState == 2 then currentActiveState = 20 -- Sleep
                elseif currentActiveState == 3 then currentActiveState = 10 -- Away
            end
        -- Update the toon burner selector to current program state
        local currentBurnerInfo = tonumber(jsonThermostatInfo.burnerInfo)
    --    local CurrentToonBurnerValue = domoticz.devices(ToonBurnerName).level
        if currentBurnerInfo == 0 then currentBurnerInfo = 0 -- uit
            elseif currentBurnerInfo == 1 then currentBurnerInfo = 10 -- cv aan
            elseif currentBurnerInfo == 2 then currentBurnerInfo = 20 -- warmwater aan
        end
        if CurrentToonBurnerValue ~= currentBurnerInfo then  -- Update toon burner selector if it has changed
            -- domoticz.log('Updating Toon burner info:')
         --   domoticz.devices(ToonBurnerName).switchSelector(currentBurnerInfo)
        end
        -- Update the modulation level of the burner
        local currentModulationLevel = tonumber(jsonThermostatInfo.currentModulationLevel)
        --if domoticz.devices(ToonBoilerModulation).percentage + 1 ~= currentModulationLevel + 1 then
            -- domoticz.log('Updating the Modulation sensor to new value: ' ..currentModulationLevel)
        --    domoticz.devices(ToonBoilerModulation).updatePercentage(currentModulationLevel)
        --end
         -- Update the temperature Boiler setpoint to current boiler set point
        local currentInternalBoilerSetpoint = jsonThermostatInfo.currentInternalBoilerSetpoint+1
        --if domoticz.utils.round(domoticz.devices(ToonBoilerSetpoint).temperature, 1) ~= domoticz.utils.round(currentInternalBoilerSetpoint, 1) then
            -- domoticz.log('Updating the Boiler internal temperature setpoint to new value: ' ..currentInternalBoilerSetpoint)
        --    domoticz.devices(ToonBoilerSetpoint).updateTemperature(currentInternalBoilerSetpoint)
       -- end
        -- Update the thermostat sensor to current setpoint
        if domoticz.devices(ToonThermostat).setPoint*100 ~= currentSetpoint*100 then
            -- domoticz.log('Updating thermostat sensor to new set point: ' ..currentSetpoint)
            domoticz.devices(ToonThermostat).updateSetPoint(currentSetpoint).silent()
        end
        -- Update the temperature sensor to current room temperature
        if domoticz.utils.round(domoticz.devices(ToonTemperature).temperature, 1) ~= domoticz.utils.round(currentTemperature, 1) then
            -- domoticz.log('Updating the temperature sensor to new value: ' ..currentTemperature)
            domoticz.devices(ToonTemperature).updateTemperature(currentTemperature)
        end
        -- Update the toon scene selector sensor to current program state
        if domoticz.devices(ToonScenes).level ~= currentActiveState then  -- Update toon selector if it has changed
            -- domoticz.log('Updating Toon Scenes selector to: '..currentActiveState)
            domoticz.devices(ToonScenes).switchSelector(currentActiveState).silent()
        end
        -- Updates the toon auto program switch
        if domoticz.devices(ToonAutoProgram).level ~= currentProgramState then -- Update toon auto program selector if it has changed
            -- domoticz.log('Updating Toon Auto Program selector to: '..currentProgramState)
            domoticz.devices(ToonAutoProgram).switchSelector(currentProgramState).silent()
        end
        -- Updates the toon program information text box
        local currentNextTime = jsonThermostatInfo.nextTime
        local currentNextSetPoint = tonumber(jsonThermostatInfo.nextSetpoint) / 100
        if currentNextTime == 0 or currentNextSetPoint == 0 then
            ToonProgramInformationSensorValue = 'Op ' ..currentSetpoint.. '°'
        else
            ToonProgramInformationSensorValue = 'Om ' ..os.date('%H:%M', currentNextTime).. ' op ' ..currentNextSetPoint.. '°'
        end
        if domoticz.devices(ToonProgramInformation).text ~= ToonProgramInformationSensorValue then
            -- domoticz.log('Updating Toon Program Information to: '..ToonProgramInformationSensorValue)
            domoticz.devices(ToonProgramInformation).updateText(ToonProgramInformationSensorValue)
        end
   end
The only thing I can get working are the auto program and scenes .
Edwin66
Postby madpatrick » Tue Nov 13, 2018 7:23 pm
Don’t give up. It took me also some frustration and time to get it working smoothly.
Do you have the setpoint script enabled for the temparature setting.
return {
   on = {
      devices = {
         'Toon Thermostat'
   execute = function(domoticz, device)
      domoticz.openURL(string.format('http://%s/happ_thermstat?action=setSetpoint&Setpoint=%s', domoticz.variables('UV_ToonIP').value, device.setPoint*100))
            domoticz.log('Setting Toon setpoint to '.. device.setPoint)
   end
If you need help to check on your system, just let me know.
Does the Boilerapp on your Toon gives you the boiler information ?
madpatrick
Postby mAiden » Tue Nov 13, 2018 8:09 pm
I have a closer look at your script and user variable.
You miss the following user variable:
UV_ToonThermostat
* Create a setpoint dummy. with the name: ToonThermostat (By user variable you give it the name: UV_ToonThermostat and select string and add the name of the sensor, in this case: ToonThermostat.)
UV_ToonTemperature
* Create a temp sensor dummy with the name: ToonTemperature (By user variable you give it the name: UV_ToonTemperature and select string and add the name of the sensor, in this case: ToonTemperature.)
* Create a P1 smart meter sensor dummy with the name: Stroom (By user variable you give it the name: UV_P1SmartMeterElectra and select string and add the name of the sensor, in this case: Stroom.)
* Create a Gas sensor dummy with the name: Gas (By user variable you give it the name: UV_P1SmartMeterGasMeterStand and select string and add the name of the sensor, in this case: Gas.)
Replace this script, with the one do you have now. I have edited him for you, to you user variable. (back up the old one. ;) )
return {
   on = {
      timer = {
         'every minute'
        local ToonBoilerTempOut     = domoticz.variables('UV_ToonboilerOutTempname').value          -- Sensor showing current water temp out
        local ToonBoilerModulation  = domoticz.variables('UV_ToonBoilerModulationLevel').value       -- Sensor showing current Boiler Modulation
        local ToonScenes            = domoticz.variables('UV_ToonScenesSensorName').value                 -- Sensor showing current program
        local ToonAutoProgram       = domoticz.variables('UV_ToonAutoProgramSensorName').value            -- Sensor showing current auto program status
        local ToonProgramInformation= domoticz.variables('UV_ToonProgramInformationSensorName').value     -- Sensor showing displaying program information status
        local ToonBoilerSetpoint    = domoticz.variables('UV_ToonBoilerTempSetpointSensorName').value     -- Sensor showing current boiler set point water temp out
        -- Handle json
        handle:close()
            return
        end
        handle2:close()
        handle4:close()
        GasPowerInfo = string.gsub(GasPowerInfo, "dev_21.", "dev_21")
        GasPowerInfo = string.gsub(GasPowerInfo, "dev_21:", "dev_21\":")
            local CurrentElectricityFlowHoog         = tonumber(jsonGasPower.dev_25.CurrentElectricityFlow )
            local CurrentElectricityQuantityHoog     = tonumber(jsonGasPower.dev_25.CurrentElectricityQuantity)
            local CurrentElectricityFlowLaag         = tonumber(jsonGasPower.dev_25.CurrentElectricityFlow )
            local CurrentElectricityQuantityLaag     = tonumber(jsonGasPower.dev_25.CurrentElectricityQuantity)
        end
        end
    --    end
            end
            end
        end
        end
        --end
       -- end
        end
        end
        end
        end
        else
        end
        end
   end
mAiden
Postby TerrorSource » Tue Nov 13, 2018 8:32 pm
Please let me know if there’s a typo or error in the manual so I can edit it if needed.
TerrorSource
Postby Edwin66 » Wed Nov 14, 2018 9:44 am
madpatrick wrote:Don’t give up. It took me also some frustration and time to get it working smoothly.
i thought the dzVents script was replacing all the seprate scripts.
Nope.
Trying with mAiden's edited script now.
Edwin66
Postby Edwin66 » Wed Nov 14, 2018 10:06 am
mAiden wrote:I have a closer look at your script and user variable.
UV_ToonThermostat
UV_ToonTemperature
Strange. I thought I had created those, must have clicked update instead of add . Added them, and now running your script. Hope it will work. Time will tell.
Maybe it's because I'm a little autistic that I don't get those things right off.
Edwin66
Postby mAiden » Wed Nov 14, 2018 10:20 am
UV_ToonThermostat
UV_ToonTemperature
I hope it will work, Otherwise you know I am here to help you, we are going to get it fully working ;)
mAiden
Postby madpatrick » Wed Nov 14, 2018 12:21 pm
UV_ToonThermostat
UV_ToonTemperature
Check you log files. This always give you a lot of information.
Put logging on "debug" to see everything.
madpatrick
PreviousNext
Return to Toon external control
