Start x11vnc at boot
Postby Erik007 » Mon Feb 25, 2019 9:00 pm
Maybe handy for someone else.
I created a rc.local
( rc.local can be used to do some things after boot)
and a startupfile for x11vnc
I wanted x11vnc to start at boot and did the following:
touch rc.local
ln -s /etc/rc.local /etc/rc5.d/S99rc
vi /etc/rc.local
#!/bin/sh
set -e
/usr/bin/startx11.sh &
exit 0
chmod 755 /etc/rc.local
vi /usr/bin/startx11.sh
#!/bin/sh
set PATH="/bin:/usr/bin:/usr/local/bin:/sbin:/usr/sbin:/usr/local/sbin"
exec 2> /tmp/startx11.log
exec 1>&2
su - root -c "/usr/bin/x11vnc :0 &" &
chmod 755 /usr/bin/startx11.sh
Erik007
Re: Start x11vnc at boot
Postby mAiden » Mon Feb 25, 2019 9:08 pm
Will advise you to use x11vnc only when you need it.
On Toon1, this actually eats processor space, and you just need this space to let Toon run properly, without having to restart itself.
That's my opinion. :)
mAiden
Postby Erik007 » Tue Feb 26, 2019 11:56 am
Here some data:
5 minuten na startup - met starten x11vnc - tigervnc not connected
Mem: 109748K used, 16448K free, 128K shrd, 0K buff, 38160K cached
CPU: 3.5% usr 5.1% sys 0.0% nic 91.2% idle 0.0% io 0.0% irq 0.0% sirq
Load average: 0.43 0.66 0.32 1/140 1629
5 minuten na startup - met x11vnc - met tigervnc connected
Mem: 113532K used, 12664K free, 128K shrd, 0K buff, 38624K cached
CPU: 7.3% usr 3.1% sys 0.0% nic 89.5% idle 0.0% io 0.0% irq 0.0% sirq
Load average: 1.64 0.81 0.46 1/140 2180
5 minuten na startup - zonder x11vnc te starten
Mem: 105412K used, 20784K free, 120K shrd, 0K buff, 37428K cached
CPU: 4.1% usr 5.1% sys 0.0% nic 90.6% idle 0.0% io 0.0% irq 0.0% sirq
Load average: 0.64 0.57 0.29 1/139 1679
So as you can see;
memory for loading program, about 4000K
with tigervnc connected another 4000K
Processor usage with 0.32; without about 0.29 -- 0.03 not a very big difference
Processor usage with tigervnc, about -- 0.17
So, unless you need that 4000K extra memory ..
Erik007
Postby Toonz » Tue Feb 26, 2019 12:14 pm
Erik007 wrote:So, unless you need that 4000K extra memory ..
Especially on a Toon1 with lot of custom apps installed, this could mean the difference between stable operations and spontaneous reboots because of lack of RAM
Postby mAiden » Tue Feb 26, 2019 1:14 pm
This is what I meant, Toon1 only has 128MB DDR on 133Mhz (and 128MB NAND flash). Especially with many custom apps installed, he really needs this space.
On Toon2 is this not a issue, then we talk about it 512Mb DDR3 @ 800Mhz (and 4Gb eMMC Flash, support up to 8GB)
mAiden
Postby NLKris » Mon May 20, 2019 10:39 pm
I've tried this on a Toon 1. My Toon did not start up futher than +/- 15%. Thank god that dropbear is one of the first things to start. After connecting with SSH and deleting the files i've made in the steps on top of this, its back alive.
NLKris
Postby PeJeWe » Tue May 21, 2019 8:36 pm
how can we shutdown x11vnc manually?
PeJeWe
Postby mAiden » Tue May 21, 2019 9:40 pm
PeJeWe wrote:how can we shutdown x11vnc manually?
First do:
ps x
This will give you a list with all the process al running on Toon.
Then look up for VNC, and hes PID, it stands at the beginning.
then run:
kill -9 PID
mAiden
Postby PeJeWe » Tue May 21, 2019 9:48 pm
First do:
ps x
then run:
kill -9 PID
i get an error
eneco-001-289077:~# ps --x
ps: unrecognized option '--x'
BusyBox v1.27.2 (2017-10-03 14:20:01 CEST) multi-call binary.
Usage: ps
Show list of processes
        w       Wide output
        l       Long output
        T       Show threads
i get no list
PeJeWe
Postby mAiden » Tue May 21, 2019 11:14 pm
You did it wrong.
You did: ps - -x
Most be: ps x
mAiden
Postby PeJeWe » Tue May 21, 2019 11:19 pm
mAiden wrote:You did it wrong.
You did: ps - -x
Most be: ps x
eneco-001-289077:~# ps x
ps: invalid option -- 'x'
Usage: ps
        w       Wide output
        l       Long output
        T       Show threads
eneco-001-289077:~#
Did not work also.
Edit:
I rebooted my toon, now it is offline.
PeJeWe
Return to Toon external control
