Toon for Android
Re: Toon for Android
Is this Alpha or Beta?
- 20190412_223425.jpg (184.57 KiB) Viewed 12779 times
If you go down, you will see Read More. Click on it and scroll down you will see the version. I see 0.5.6.MyZ wrote:Is this Alpha or Beta?
0.5.2glsf91 wrote:If you go down, you will see Read More. Click on it and scroll down you will see the version. I see 0.5.6.MyZ wrote:Is this Alpha or Beta?
0.5.2 is beta and 05.6 is alpha
we need 0.5.6 but me to not can install the 0.5.6
only 0.5.2 in in the play store
Toon solarpannels
Or there is something really messed up on the play store or there must be another logical explanation like you opted in for Beta and later Alpha.
Any idea how I can fix this? Or can you publish the APK somewhere?RoadXY wrote:Or there is something really messed up on the play store or there must be another logical explanation like you opted in for Beta and later Alpha.
I don't have an APK nor will I build one.
I upload an Android Bundle, no APK.
My suggestion would be to unsubscribe to the play store testing, wait for an day and subscribe again.
Unsubscription is available here:
https://play.google.com/apps/testing/com.toonapps.toon
Released to Beta testers.RoadXY wrote:0.5.6 is released to Alpha.
Solved issues in this release:
https://github.com/fabianblom/Toon-Andr ... ne%3A0.5.4
Bugfix: When starting app, the correct mode button wasn't selected
Bugfix: Fix toast message when setting stuff (Fixes fabianblom#13)
Bugfix: IllegalFormatConversionException on formatting string
Bugfix: change layout so it works better on lower resolution devices (fixes fabianblom#24)
Bugfix: Next program text contained "\n" text
Bugfix: Use CurrentUsageInfo for power and gas usage instead of DeviceInfo (fixes fabianblom#8)
Bugfix: Get next set point (fixes fabianblom#6)
Enhancement: Auto refresh & pull down to refresh
Enhancement: Change layout to resemble o.g. Toon app
Enhancement: Add support for when no program is used
Enhancement: Add setting to choose between next program or next temp
Enhancement: Set power usage meter relative to average usage
Enhancement: Add extra setting to change temperature by 1 degree
Enhancement: Only 1 decimal after the comma (Solves fabianblom#14)
Enhancement: Provide feedback when using the refresh button (Solves fabianblom#15)
Enhancement: Use burner info (only on OpenTherm?) to show flame
Enhancement: Change mode buttons to resemble the Toon buttons
All feedback is appreciated!
Cool, fits my phone as well, now
Got 'm!
Very nice. Steady and good improvements. The only thing is the gas usage. 214m3 is a little bit much for today. I have a smart meter. I think this is the last gas usage reading over the period of an hour in l/h. Can you display this the same as on Toon, total daily usage (sum of all the readings for the current day)? That would be great.
Thanks.MyZ wrote:Got 'm!
Yeah, we cought that one:
https://github.com/fabianblom/Toon-Android/issues/34
Already in version 0.5.7 (currently in internal test)MyZ wrote:Can you display this the same as on Toon, total daily usage (sum of all the readings for the current day)? That would be great.
Especially for youmarcelr wrote:Cool, fits my phone as well, now
Perfect! Thumbs upRoadXY wrote:Thanks.MyZ wrote:Got 'm!
