Control happ_thermstat boiler setpoint
Posted: Mon Jun 29, 2020 11:55 am
by knug2
Currently im building a zone regulated heating system.
I would like to control/override the 'boiler-setpoint' of Toon, is this possible? For example : http://<IP>/happ_thermstat?action=setSetboilerSetpoint=4000?
Re: Control happ_thermstat boiler setpoint
Posted: Mon Jun 29, 2020 1:26 pm
by TheHogNL
knug2 wrote:Currently im building a zone regulated heating system.
This wil set the settemp to 22 degrees and turn off the schedule:
http://<IP>/happ_thermstat?action=changeSchemeState&state=0&temperature=2200
This wil set the settemp to 22 degrees only during the current scheduled state:
http://<IP>/happ_thermstat?action=changeSchemeState&state=2&temperature=2200
Posted: Mon Jun 29, 2020 1:39 pm
by knug2
@ TheHogNL Thanks for your reply.
But this is just the 'room' setpoint.
What I need/want too change is the 'boiler' output temperature ( eg 60 degrees out ).
I need to override the calculated boiler setpoint value by Toon.
Curious if this is possible, otherwise I will use an OTGW to override the boiler setpoint. But I prefer to only use the Toon if possible.
Posted: Mon Jun 29, 2020 2:00 pm
by TheHogNL
knug2 wrote:@ TheHogNL Thanks for your reply.
Ok that is impossible I am afraid with the toon.
Posted: Mon Jun 29, 2020 2:47 pm
by knug2
OK, unfortunately.....
Is there somewhere a list (besides this one :
domoticaforum.eu/viewtopic.php?f=97& ... tat#p94570 with all the available commands that can be executed trough happ_thermstat?
Posted: Thu Jul 16, 2020 4:22 pm
by knug2
Still have not found a solution yet ( besides OpenThermGateway ). Does anyone know if there is a possibility to manually override the boiler setpoint temperature ( and not just the roomtemperature ), but the calculated boiler setpoint??
Thanks in advance
Posted: Thu Jul 16, 2020 6:31 pm
by marcelr
The data from and towards the boiler module are sent through a standard serial protocol. You can intercept the communication and replace e.g., the boiler output setpoint with your own value. It will take some C programming skills to make this work. In the distant past I have used interceptty to monitor the boiler module communication, with some reprogramming it may serve as an interface to push your own data into the communication channel. You will also need to use the edge protocol as defined by Quby (and reverse-engineered by me
) to keep the communication with the boiler functional.
In short: Not an easy job, but it can be done.
