Software: modifications and extensions Toon
Moderators: marcelr, TheHogNL, TerrorSource, Toonz
Postby michel30 » Fri Sep 22, 2017 8:55 pm
walberg wrote:
How did you make these double tile with 3 days of gas use?
michel30
Postby marcelr » Sat Sep 23, 2017 8:33 am
Vibestar wrote:Maybe more hardware and software related: is there a way to controle the state of the boiler with a movementsensor?
I had a thermostat of ICY for many years. Of I wasnt in the room for 30 min the thermostat was set back to a colder state. I was wondering if it could be done by the TOON?
Should be possible. If you can get the sensor to work with toon, influencing the heating sequence should not be an issue.
michel30 wrote:How did you make these double tile with 3 days of gas use?
Just install the same tile twice ...
Postby walberg » Sat Sep 23, 2017 9:11 am
Actually very simple, it turned out that the chip that controls the touch layer had some short circuits by soldering small droplets. There were also some cold connections at the location where the previous owner had soldered the serial cable. As a result, the screen did not respond as It should be. I came here because I was able to connect via VNC to the screen (though it was very slow). So I opened the Toon and yes the modifications were done very messy. Well hardware and software are 2 different branches of sport. I corrected it and now i don't get double (even tripple) tiles anymore and even i can remove double tiles on the Toon directly.
walberg
Postby TheHogNL » Sat Sep 23, 2017 7:14 pm
My point of view on this, just put such kind of intellegence in domoticz. You can then also use geofencing etc.
Based on what domoticz decides, you can then try to set the correct program of the Toon (away, at home, comfort, sleeping). This would need something which could interact with domoticz and toon. I think the best option for now is let the toon poll domoticz each minute (a virtual sensor or something in which domoticz puts the requested mode) and then change the program of the thermostat accordingly. The builtin thermostat app will probably guide you how to set the program using your script.
Postby Toonz » Sat Sep 23, 2017 7:49 pm
TheHogNL wrote:My point of view on this, just put such kind of intellegence in domoticz. You can then also use geofencing etc.
Even better, Domoticz can directly change the selected program on Toon via an http request to Toon. This can be triggered via any event in Domoticz.
A cleaner solution than having Toon polling Domoticx in my view.
In other words, connect a motion sensor to Domoticz and of you go......
Kind regardz,
Toonz.
Postby DennisD » Sat Sep 23, 2017 8:04 pm
I use domoticz to control my toon. I use presence detection (ping wifi) in order to let domoticz know somebody is home. When somebody is home the scene comfort is selected, when nobody is at home toon scene away is selected by domoticz. I also have the normal timer function so the sleep scene is still controlled by toon. In order to let toon switch on/off the comfort scene on movement I would think adding a motion sensor to domoticz would be the easiest.
DennisD
Postby Vibestar » Sun Sep 24, 2017 8:22 am
Thanks, slowly I get pulled into the Domoticz where I only bought the Toon :D
Now I need to decided what to use. I have a pi one en pi zero already at home. Are they strong enough?
Sure I’m gona use your solutions.
Vibestar
Postby TheHogNL » Sun Sep 24, 2017 12:41 pm
Toonz wrote:[
Owh didn't now that. Which http requests are available then? I only know about the ones getting info from the Toon :)
Postby Toonz » Sun Sep 24, 2017 1:12 pm
Postby TheHogNL » Sun Sep 24, 2017 2:35 pm
Lolz,.. don't know why I missed that post :)
Postby Martin101010 » Wed Jan 10, 2018 12:46 pm
makkie2002 wrote:Hi all. I made my first app! It is showing images from my webcam on a Toon tile. If you click on the tile you get a fullscreen image of the webcam.
The app uses the fact that my webcam has an URL with the latest jpg image. The images are refreshed every 10s for now. If I refresh more quickly the Toon processor is too heavily loaded. I would like to have the refresh rate for the full screen somewhat faster than for the tile, but I am afraid my programming skills hold me back :? . So if someone wants to look into the code and help out ... very much appreciated !
@ Makkie;
Nice idea, unfortunatly all I get is a white screen and the GUI keeps restarting. What I did was;
I've copied the app to /HCBv2/qml/apps
added webcam-0.05 to globals file,
reset with: killall -9 qt-gui
Do I miss something?
Martin
Martin101010
Postby Martin101010 » Wed Jan 10, 2018 6:57 pm
@ Makkie;
Edit: Found it, I indeed missed something, forgot a semicolon in de globals file. App is working fine
Any progress on the time out when closed?
Martin
Martin101010
Postby Martin101010 » Thu Jan 11, 2018 8:52 am
Too bad I had to turn off the webcam app as it slowed down the response of the user interface.
Hopefully there will come a solution to inactivate the app when the tile is not visible.
Martin101010
Postby HansS » Sat Feb 24, 2018 6:29 pm
I have a Tile, with some text, and an Item, and in that Item are two buttons with an Image. When the screen dims, the tile and text disappear, but the buttons stay visible, which is what I want. But, the button background stays white, which is not what I want. I would like the buttons to not be visible, but the images to stay visible. Something like change the button's background colour in dimState. But I cannot seem to find how to do that. I cannot change the button color, in any mode. Any ideas?
HansS
Postby marcelr » Sat Feb 24, 2018 6:42 pm
Like this (from an old version of the wastecollection app):
Tile {
   property bool dimState: screenStateController.dimmedColors
   onClicked: {
      if (app.wastecollectionConfigurationScreen)
         app.wastecollectionConfigurationScreen.show();
   Image {
      source: app.wasteIcon
      anchors {
         baseline: parent.top
         baselineOffset: 10
         horizontalCenter: parent.horizontalCenter
      cache: false
          visible: dimState ? app.wasteIconShow : false      // only show if one icon
   Image {
      height: 100
      width: 100
      anchors {
         baselineOffset: 10
         left: parent.left
         leftMargin: 10
      cache: false
          visible: dimState ? app.wasteIcon2Show : false      // only show if two icons
PreviousNext
Return to Toon software development
cron
