TSC settings menu item
Moderators: marcelr, TheHogNL, TerrorSource, Toonz
Re: TSC settings menu item
Postby michel30 » Thu Nov 01, 2018 10:14 pm
Thanks, for this nice upgrade it works super..
michel30
Postby yjb » Fri Nov 02, 2018 7:52 am
2 Questions about this
- Would it make sense to introduce some simple password mechanism (even a simple hardcoded PIN will do as far as I'm concerned) to these advance features so that the ignorant (ie kids) cannot initiate these kind of advanced things)
- Would it make sense to initiate a root password recovery as well from thsi screen, just in case the /etc/passwd file gets overwritten
Thanks for looking at this.
yjb
Postby TheHogNL » Fri Nov 02, 2018 7:58 am
yjb wrote:Hi,
PIN should be possible. Let me work on that. Also recovering the root password would be feasable. Thanks for your input. These kinds of ideas are welcome.
Postby Toonz » Fri Nov 02, 2018 11:03 am
yjb wrote:- Would it make sense to introduce some simple password mechanism (even a simple hardcoded PIN will do as far as I'm concerned) to these advance features so that the ignorant (ie kids) cannot initiate these kind of advanced things)
Great idea, usually it are our kids who physically damage the Toons or accidentally fire software upgrades :D :D :D :D :D :D
Postby TerrorSource » Fri Nov 02, 2018 11:39 am
Ask @TheHogNL, The knows the result of a Toon2 dropping from a table :D
TerrorSource
Postby hansgrave » Fri Nov 02, 2018 5:31 pm
Thanx! Upgraded to 4.19.10 and disabeld the native funtions, Toon works smoother now :D
Homey, rooted Toon 1 and Domoticz.
hansgrave
Postby TheHogNL » Sat Nov 03, 2018 8:55 am
TheHogNL wrote:
yjb wrote:Hi,
Just released version 1.3.1 which includes settings lock with pin and password recovery.
Postby mAiden » Sat Nov 03, 2018 9:44 am
TheHogNL wrote:
TheHogNL wrote:
yjb wrote:Hi,
Nice done TheHog. Will install the new updates as soon as I am back home.
mAiden
Postby glsf91 » Thu Nov 15, 2018 3:14 pm
Sometimes I don't want to update when there is a new resource file. But repeating everyday the notification is a little bit annoying.
Is it possible to just show the notification only once per version?
glsf91
Postby Toonz » Thu Nov 15, 2018 3:52 pm
glsf91 wrote:Sometimes I don't want to update when there is a new resource file. But repeating everyday the notification is a little bit annoying.
I would opt for a TSC menu option to enable/disable the notification bar - it is usually annoying :-)
Postby glsf91 » Thu Nov 15, 2018 3:57 pm
Toonz wrote:I would opt for a TSC menu option to enable/disable the notification bar - it is usually annoying :-)
I don't have a problem with the notification bar. I even like it is telling there is an update. But not everyday the same notification :)
glsf91
Postby TheHogNL » Thu Nov 15, 2018 4:15 pm
Yes that would be possible. On the next update then :-)
Postby TheHogNL » Thu Nov 15, 2018 6:44 pm
And done. In next script version you will only be notified once if there is a update available. Only if you manually check for updates the next time it will notify you again once.
Postby glsf91 » Thu Nov 15, 2018 6:54 pm
TheHogNL wrote:And done. In next script version you will only be notified once if there is a update available. Only if you manually check for updates the next time it will notify you again once.
Great !
Maybe you can put in de first post what Lock TSC settings and lock password is doing.
glsf91
Postby Mixpower » Tue Nov 20, 2018 1:30 pm
Any update on the price setting?
Or is it still not possible to change this?
Mixpower
PreviousNext
Return to Toon software development
