QT websockets
Re: QT websockets
Postby TheHogNL » Tue May 05, 2020 9:43 am
oepi-loepi wrote:
TheHogNL wrote:From firmware 5.0.4 the original Toon resources also include libraries for QT5 websockets!
To use the libraries install them when having the VPN running with "opkg install libqt5websockets5" (I will probably add an option to the update-script to install this for you soon).
if i run opkg list-installed then libqt5websockets5 is not in the list and when i run "opkg install libqt5websockets5" it throws an error. Even when i open the VPN (in inittab and then init q)
Installing libqt5websockets5 (5.11.2+git0+e71467cb56-r0) on root.
Downloading http://feed.hae.int/feeds/nxt/oe/angelica-1.7.0-master-kernel-4.9.88/cortexa9hf-vfp-neon/libqt5websockets5_5.11.2+git0+e71467cb56-r0_cortexa9hf-vfp-neon.ipk.
Collected errors:
* opkg_download: Failed to download http://feed.hae.int/feeds/nxt/oe/angelica-1.7.0-master-kernel-4.9.88/cortexa9hf-vfp-neon/libqt5websockets5_5.11.2+git0+e71467cb56-r0_cortexa9hf-vfp-neon.ipk: Couldn't connect to server.
* opkg_install_pkg: Failed to download libqt5websockets5. Perhaps you need to run 'opkg update'?
Do I do something wrong or would it be possible to post the .ipk package in the files section?
Run the update-rooted.sh with option -o and after that 'opkg update'
Re: QT websockets
Postby oepi-loepi » Tue May 05, 2020 2:36 pm
Yes! This worked. It is now in the list. Allready puzzling here...
oepi-loepi
Re: QT websockets
Postby marcelr » Tue May 05, 2020 3:36 pm
Puzzling in the UK sense or the NL sense of the word?
Re: QT websockets
Postby oepi-loepi » Tue May 05, 2020 10:47 pm
marcelr wrote:Puzzling in the UK sense or the NL sense of the word?
Both ;)
I am working on a new version of the Onkyo (and Pioneer) controller based on a Wemos bridge between The Onkyo eISCP commands and the Toon via websockets. This because this will work faster and without the need for an external controller like Domoticz. (as you might know the Wemos is a 2 dollar piece of small .... which can do the job).
Now trying to get it all working together: websockets, smart AP, eISCP over TCP and a webserver so you can also have acces through a browser.....
Allmost done..
oepi-loepi
Previous
Return to Toon software development
