Resource file TSC version 1.6.0
Postby TheHogNL » Thu Jun 06, 2019 7:30 pm
Just released TSC resource file version 1.6.0
This one includes an option in the TSC menu to edit your electricity and gas tariff! If you edit it to reflect the tariff on your contract with your energy supplier the Toon cost calculation will work properly.
Hit your check update button in the TSC menu to receive this update. ONLY for newest firmwares (firmware 5 and higher) because of some new features I use in the app.
Re: Resource file TSC version 1.6.0
Postby Phoolie » Fri Jun 07, 2019 2:22 pm
Great change, this works much better then on the command line :)
Phoolie
Postby hansgrave » Fri Jun 07, 2019 4:28 pm
Nice, thanx!
Homey, rooted Toon 1 and Domoticz.
hansgrave
Postby michel30 » Fri Jun 07, 2019 6:33 pm
thanks for this nice TSC menu
michel30
Postby Hmmbob » Sat Jun 08, 2019 10:05 am
Thanks, working great.
While I was trying to set the tariffs (through VNC), I got a message saying I got enrolled to beta releases. Probably I did some magic trick somewhere.... I'd prefer stable releases - how to unsubscribe from beta again?
Hmmbob
Postby PeJeWe » Sat Jun 08, 2019 11:26 am
Working great
PeJeWe
Postby TheHogNL » Sat Jun 08, 2019 1:49 pm
Hmmbob wrote:Thanks, working great.
Yes there is a magic hidden button somewhere for us developers to go into beta modus. Currently beta is the same as production so no worries. After a day or so it will change to production mode automatically.
Postby Hmmbob » Sat Jun 08, 2019 5:17 pm
It just reverted already. Thanks for your answer though!
Hmmbob
Postby Mixpower » Wed Jun 12, 2019 9:13 pm
Running 5.5.7 but I get the message there is no TSC update?
Mixpower
Postby Mixpower » Thu Jun 13, 2019 2:12 pm
Got it all working, but the pricing is not calculated correctly.
I have changed it a few times with no effect at all, even after a full reboot it does not change.
Mixpower
Postby TheHogNL » Thu Jun 13, 2019 5:14 pm
Mixpower wrote:Got it all working, but the pricing is not calculated correctly.
Please check if the prices are correctly shown in /qmf/config/config_happ_pwrusage.xml
You will need to look for lines after <billingInfo>
If they are not there try it again. If they are there it should work...
Postby Toonz » Thu Jun 13, 2019 5:58 pm
it will only be applied to new power consumption data. The historical data stay untouched.
Postby Mixpower » Sat Jun 15, 2019 3:25 pm
Toonz wrote:it will only be applied to new power consumption data. The historical data stay untouched.
I have checked and it is correct, I was indeed looking at the historical data because that's were pricing appeared. :)
I only use Toon for my Tesla Wall Connector, so this is a great feature for me thank you! :D
Mixpower
Postby TheHogNL » Sat Jun 15, 2019 10:22 pm
Can you tell us more? How do you use your Toon for that? Is the meteradapter connected to a kWh meter on the tesla wall connector?
Postby Mixpower » Sun Jun 16, 2019 7:05 pm
Yes I have put the Toon analog sensor on my kWh meter and connected it to the Meteradapter, the Wall Connector has one whole phase for itself on it's own group and kWh meter.
Mixpower
Next
Return to Toon software development
