One add-on could be very nice. If you use my spotenergy app and get an EasyEnergy contract you can 'switch on' the wall plug only on low tariff hours. Two weeks ago there was even a moment on a sunday when tariff's where negative so you get payed for using electricityMixpower wrote: Yes I have put the Toon analog sensor on my kWh meter and connected it to the Meteradapter, the Wall Connector has one whole phase for itself on it's own group and kWh meter.
The spotenergy has a switch to domoticz if tariff is low. You must then somehow let domoticz switch the wall-plug on or off (using a relais or something).
