Page 1 of 2
Resource file TSC version 1.6.0
Posted: Thu Jun 06, 2019 8:30 pm
by TheHogNL
Just released TSC resource file version 1.6.0
This one includes an option in the TSC menu to edit your electricity and gas tariff! If you edit it to reflect the tariff on your contract with your energy supplier the Toon cost calculation will work properly.
Hit your check update button in the TSC menu to receive this update. ONLY for newest firmwares (firmware 5 and higher) because of some new features I use in the app.
Re: Resource file TSC version 1.6.0
Posted: Fri Jun 07, 2019 3:22 pm
by Phoolie
Great change, this works much better then on the command line
Posted: Fri Jun 07, 2019 5:28 pm
by hansgrave
Nice, thanx!
Posted: Fri Jun 07, 2019 7:33 pm
by michel30
thanks for this nice TSC menu
Posted: Sat Jun 08, 2019 11:05 am
by Hmmbob
Thanks, working great.
While I was trying to set the tariffs (through VNC), I got a message saying I got enrolled to beta releases. Probably I did some magic trick somewhere.... I'd prefer stable releases - how to unsubscribe from beta again?
Posted: Sat Jun 08, 2019 12:26 pm
by PeJeWe
Working great
Posted: Sat Jun 08, 2019 2:49 pm
by TheHogNL
Hmmbob wrote:Thanks, working great.
Yes there is a magic hidden button somewhere for us developers to go into beta modus. Currently beta is the same as production so no worries. After a day or so it will change to production mode automatically.
Posted: Sat Jun 08, 2019 6:17 pm
by Hmmbob
TheHogNL wrote:Hmmbob wrote:Thanks, working great.
It just reverted already. Thanks for your answer though!
Posted: Wed Jun 12, 2019 10:13 pm
by Mixpower
Running 5.5.7 but I get the message there is no TSC update?
Posted: Thu Jun 13, 2019 3:12 pm
by Mixpower
Got it all working, but the pricing is not calculated correctly.
I have changed it a few times with no effect at all, even after a full reboot it does not change.
Posted: Thu Jun 13, 2019 6:14 pm
by TheHogNL
Mixpower wrote:Got it all working, but the pricing is not calculated correctly.
Please check if the prices are correctly shown in /qmf/config/config_happ_pwrusage.xml
You will need to look for lines after <billingInfo>
If they are not there try it again. If they are there it should work...
Posted: Thu Jun 13, 2019 6:58 pm
by Toonz
it will only be applied to new power consumption data. The historical data stay untouched.
Posted: Sat Jun 15, 2019 4:25 pm
by Mixpower
Toonz wrote:it will only be applied to new power consumption data. The historical data stay untouched.
I have checked and it is correct, I was indeed looking at the historical data because that's were pricing appeared.
I only use Toon for my Tesla Wall Connector, so this is a great feature for me thank you!
Posted: Sat Jun 15, 2019 11:22 pm
by TheHogNL
Mixpower wrote:Toonz wrote:it will only be applied to new power consumption data. The historical data stay untouched.
Can you tell us more? How do you use your Toon for that? Is the meteradapter connected to a kWh meter on the tesla wall connector?
Posted: Sun Jun 16, 2019 8:05 pm
by Mixpower
TheHogNL wrote:Mixpower wrote:Toonz wrote:it will only be applied to new power consumption data. The historical data stay untouched.
Yes I have put the Toon analog sensor on my kWh meter and connected it to the Meteradapter, the Wall Connector has one whole phase for itself on it's own group and kWh meter.
