toon activation problem
Moderators: marcelr, TheHogNL, TerrorSource, Toonz
Postby patricx » Wed Apr 18, 2018 7:15 am
Hello
i have changed config_happ_scsync.xml in the folder /HCBv2/config
but every time i reboot the toon, toon overwrite that file and come back in the wizard menu.
please can someone help me ?
patrick
patricx
Re: toon activation problem
Postby flamingbob » Wed Apr 18, 2018 10:06 am
Simple questions first. Have you disabled the ipsec tunnel? If you still talk to the mothership it always override that exact file.
flamingbob
Postby patricx » Wed Apr 18, 2018 6:36 pm
i have change the line
ovpn:235:respawn:/usr/sbin/openvpn --config /etc/openvpn/vpn.conf --verb 0 >/dev/null 2>&1
in
#ovpn:235:respawn:/usr/sbin/openvpn --config /etc/openvpn/vpn.conf --verb 0 >/dev/null 2>&1
but the same problem
patricx
Postby TheHogNL » Thu Apr 19, 2018 7:01 am
patricx wrote:i have change the line
in
That is impossible. The scsync file is only overwritten if the openvpn is running. Did you reboot after editing the line (add the # in front)?
After the reboot, change the scsync file (look in the forum for the exact changes you need to make, this is answered over and over again), reboot again, and it would be fine then.
Postby EJanus » Thu Apr 19, 2018 11:11 am
Or (but this is perhaps to simple :wink: ) it could be that saving the file goes wrong.
So open config_happ_scsync.xml
edit the file
save
close
open config_happ_scsync.xml again
Check if your changes were in fact saved.
EJanus
Postby patricx » Thu Apr 19, 2018 11:37 am
when i check the file config_happ_scsync.xml that's i write to the toon it's ok.
when i go to the activation center it's tell that er is no conection to the activation center.
I have follow al instructions but i do not see what's wrong.
is the a other way to see if the openvpn is running ?
patricx
Postby EJanus » Thu Apr 19, 2018 3:01 pm
But what is your problem exactly?
If you want to change the VPN status, you can do that in the file /etc/inittab and put a # in front of the line ovpn:2345:respawn:/usr/sbin/openvpn --config /etc/openvpn/vpn.conf --verb 0 >/dev/null 2>&1 as stated in the root manual.
If you want to disable the wizard menu, you can try to do that in de file config_happ_scsync.xml and check if this is there: <activated>1</activated><wizardDone>1</wizardDone> (in line 11).
EJanus
Postby patricx » Thu Apr 19, 2018 3:23 pm
Ejanus,
I have do everythink follow the root manual .
i have put # for the openvpn row and i have change config_happ_scsync.xml as you write.
I have root the toon by a rapberry pi with that script without problems or errors.
and all other thinks in the manual i have do it also.
but every time i reboot te toon it overwrite the config_happ_scsync.xml file that's te problem and i can not find the solution.
patricx
Postby patricx » Thu Apr 19, 2018 6:45 pm
in /etc/inittab
i have change flas:245:respawn:/usr/bin/startflash >/dev/null 2>&1 to #flas:245:respawn:/usr/bin/startflash >/dev/null 2>&1
and reboot the toon but then it's do not start to the home screen.
remove the # and reboot again and now the toon work
patricx
Postby EJanus » Thu Apr 19, 2018 11:08 pm
So you put the # in front of: flas:245:respawn:/usr/bin/startflash >/dev/null 2>&1
That is not going to work and Toon will not boot correctly.
You should put the # in front of: ovpn:2345:respawn:/usr/sbin/openvpn --config /etc/openvpn/vpn.conf --verb 0 >/dev/null 2>&1
So it looks like:
# ovpn:2345:respawn:/usr/sbin/openvpn --config /etc/openvpn/vpn.conf --verb 0 >/dev/null 2>&1
The # tells Toon to ignore the line after the #. So Toon can not connect to the Eneco server using vpn.
Good luck!
EJanus
Postby DAP61 » Thu Mar 14, 2019 6:09 pm
I bought myself a rooted Toon 43 weeks ago.
I updated it to 5.0.4.
But i can't get past the activation code.
And i'm not allowed to change the config file.
Who can tell me what to do so I can get more use out of TOON then yust a thermostat?
DAP61
Postby TerrorSource » Thu Mar 14, 2019 11:07 pm
DAP61 wrote:Hello,
What did you already read on this forum? Solution and additional possibilities are mentioned everywhere! :D
TerrorSource
Postby TheHogNL » Thu Mar 14, 2019 11:18 pm
DAP61 wrote:And i'm not allowed to change the config file.
Why? You are root. You can do everything you want.
Return to Toon issues and support (Nederlands toegestaan)
