Page 1 of 2
Toon not booting after failed update
Posted: Mon Sep 03, 2018 7:38 pm
by MadDemonoide
Hey.
I tried doing a software update, and the power fell out during the update.
I can access SSH, and the screen is stuck at the T logo.
I tried using the update script, but it cannot seem to connect to the vpn. The keys are in the vpn folder.
What can i do?
Thanks
Re: Toon not booting after failed update
Posted: Mon Sep 03, 2018 8:27 pm
by TerrorSource
can you try the update script as followed:
sh update-rooted.sh -v 4.19.10
and tell us wat happens
Posted: Mon Sep 03, 2018 8:30 pm
by marcelr
So it is booting.
You can test whether vpn is started by typing
If that gives no output (or nothing useful) you can start vpn manually by copying the command part of the openvpn line from /etc/inittab into the ssh console and run it.
Posted: Mon Sep 03, 2018 8:36 pm
by MadDemonoide
Hey. With the forcing it is still waiting for VPN to be alive. See the screenshot.
Thank you
Posted: Mon Sep 03, 2018 8:41 pm
by MadDemonoide
As far as I can see it is running.
I see the line and the conf file defined there.
marcelr wrote:So it is booting.
Posted: Mon Sep 03, 2018 8:42 pm
by TerrorSource
MadDemonoide wrote:Hey. With the forcing it is still waiting for VPN to be alive. See the screenshot.
Thank you
Just keep trying a few times. had that once before too.
Also, check the /etc/inittab if it's not empty.
Posted: Mon Sep 03, 2018 8:45 pm
by MadDemonoide
I tried a few times now. Nothing changes.
The inittab is not empty. The openvpn item is there. Uncommented.
TerrorSource wrote:MadDemonoide wrote:Hey. With the forcing it is still waiting for VPN to be alive. See the screenshot.
Thank you
Posted: Mon Sep 03, 2018 8:49 pm
by marcelr
In that case, you should be able to ping feed.hae.int, and get a response.
Posted: Mon Sep 03, 2018 8:51 pm
by MadDemonoide
marcelr wrote:In that case, you should be able to ping feed.hae.int, and get a response.
I’m not getting a response from that URL.
Posted: Mon Sep 03, 2018 8:56 pm
by marcelr
try
(google) then.
If that doesn't give a response, you don't have a working connection to the outside world.
Posted: Mon Sep 03, 2018 8:57 pm
by MadDemonoide
When I try to manually start the VPN, I get the following:
Socket bind failed on local address. [AF_ INET]127.0.0.1:8000 Address already in use.
by MadDemonoide
marcelr wrote:try
(google) then.
I tried google. I get a nice ping back.
Posted: Mon Sep 03, 2018 9:12 pm
by marcelr
Maybe you should edit inittab to not start openvpn, then kill it, and let the script do it for you.
Posted: Mon Sep 03, 2018 10:06 pm
by TheHogNL
I think you have a very old version of Toon firmware which doesn't update the /etc/hosts file properly (your feed.hae.int entry in your hosts file doesn't match with the routing table)
Try to remove the "feed.hae.int" line from the /etc/hosts file and restart the Toon and the script again.
Posted: Tue Sep 04, 2018 2:37 pm
by MadDemonoide
marcelr wrote:Maybe you should edit inittab to not start openvpn, then kill it, and let the script do it for you.
I can start the VPN manually, but it still does not update.
It also shows up @ the top command as a process.
