Hi
I have a rooted toon1 at fw 5.0.4. I have linked the toon to Home assistant and can control the thermostat and see the boilerstatus. But i cannot see the readings from the smart meter. I can see the values on the toon but not on home assistant. Where do i need to look to fix this?
Rooted toon 1 on Home assistant
Re: Rooted toon 1 on Home assistant
Assuming that you're using the cyberjunky/home-assistant-custom-components, you need to edit the sensor/toon_smartmeter.py file. There you need to define the correct HAE_METERS. Go to http://toon.ip:port/hdrv_zwave?action=getDevices.json and search for dev_
thanks that was indeed the problem. Now i have the correct readings.
