Toon screen not responding
BrainHunt
Post by BrainHunt »
On my Toon2 with firmware 5.04, I recently noticed that the screen is behaving strange:
- if the screen is in sleep or in dark mode, it does turn on if I touch the screen
- however if the screen is active, it doesn't respond to selecting tiles or any other touches (e.g. selecting menu and so)
Rebooting did fix it for the short term but after not using it for multiple days, the above happens again. Apart from that, everything is still working great (showing everyting, rotating through the tiles with the setting from Toonz, running the heating program, etc.).
Any thoughts?
Re: Toon screen not responding
Post by TheHogNL »
Check your diskspace on your toon. Maybe something is clogging the disk? Or maybe memory usage?
madpatrick
Post by madpatrick »
TheHogNL wrote:Check your diskspace on your toon. Maybe something is clogging the disk? Or maybe memory usage?
My parentz are have my old Toon 1 which is slow at the moment.
How can ik clean up the disk ? because i think this could be the problem.
X11VNC is uninstalled and not running.
Post by TheHogNL »
madpatrick wrote: My parentz are have my old Toon 1 which is slow at the moment.
Check diskspace with "df -h" and your memory with '"free". Most of the time it is memory on a toon1 which is bugging you. You can, from firmware 4.16 and further, disable some native unused toon features using the TSC menu which frees some memory.
madpatrick
Running on 5.0.4 and disabled all native Toon features.
Rebooted the Toon several times, but still slow on screen responces.
I’ll check the disk space and memory shortly
Templar
Post by Templar »
Firmware 5.0.4 is a slower than the previous firmware.
Running on 5.0.4 and disabled all native Toon features. Running apps: toonstore, boilerstatus, buienradar and calendar.
df -h
Filesystem                Size      Used Available Use% Mounted on
ubi0:rootfs             106.5M     73.2M     33.3M  69% /
tmpfs                    61.6M      2.9M     58.7M   5% /var/volatile
free
             total       used       free     shared    buffers     cached
Mem:        126196     120052       6144          0          0      30924
-/+ buffers/cache:      89128      37068
Swap:            0          0          0
Can I free up space by deleting some backup resource files? Currently I have the following files:
resources-static-base.bak
resources-static-base.rcc
resources-static-base.rcc.backup
resources-static-ebl.bak
resources-static-ebl.rcc
resources-static-ebl.rcc.backup
Do not remove these files. Disk space is not the problem. Available RAM is a problem on Toon 1.
I also noticed in 5.0.4 on my Toon 1 that it takes a bit of time to wake up from dim state.
After that the response is good on my Toon.
Templar
Post by Templar »
Toonz wrote:Do not remove these files.
To make clear, I only meant to delete (two of) these files.
Toonz wrote:I also noticed in 5.0.4 on my Toon 1 that it takes a bit of time to wake up from dim state.
Exactly that.
Exactly that.
The backup files can be removed but that will not solve the performance issue ;-)
