cat: can't open '/HCBv2/env': No such file or directory
Postby edwinth » Thu May 16, 2019 8:08 pm
I'm trying to update my Toon but it fails because some folder is missing ?
How can I fix this ?
Thanks,
Edwin
Version: 3.85 - TheHogNL & TerrorSource & yjb - 14-4-2019
If you like the update script for rooted toons you can support me. Any donation is welcome and helps me developing the script even more.
https://paypal.me/pools/c/8bU3eQp1Jt
You are currently running version 5.2.11 on a qb2 with flavour uni
Available versions: 1.0.9 1.9.10 2.1.0 2.2.24 2.3.17 2.3.29 2.3.36 2.4.7 2.4.12 2.5.11 2.5.14 2.5.18 2.6.24 2.6.33 2.8.16 2.8.21 2.8.27 2.9.15 2.9.26 2.10.15 3.0.29 3.0.32 3.1.22 3.2.14 3.2.18 3.2.21 3.3.8 3.4.2 3.4.4 3.5.4 3.6.3 3.7.8 3.7.9 4.3.20 4.4.21 4.7.23 4.8.25 4.9.23 4.9.124 4.10.6 4.11.6 4.12.0 4.13.6 4.13.7 4.15.2 4.15.6 4.16.8 4.18.8 4.19.10 4.20.7 4.22.7 5.0.4 5.2.11 5.5.7
Which version do you want to upgrade to?
5.5.7
Alright, I will try to upgrade to 5.5.7
iptables: Chain already exists.
Upgrade script downloaded. We need to download the upgrade files first. No upgrade is done yet. Do you want me to download the files (yes) or quit (anything else)?
yes
Waiting to finish. Sometimes this takes a minute or two ..
Done preparing.
Are your sure you want to upgrade to 5.5.7 (yes)? This is the last moment you can stop the upgrade. Answer with 'yes' will start the upgrade.
yes
Starting the upgrade now! Just wait a while... It can take a few minutes.
Progress: 0% .
edwinth
Re: cat: can't open '/HCBv2/env': No such file or directory
Postby edwinth » Thu May 16, 2019 8:26 pm
Update looks succesfull, version is now 5.5.7
edwinth
Postby TheHogNL » Thu May 16, 2019 9:30 pm
Just ignore that "cat: can't open '/HCBv2/env': No such file or directory" line. It a bug in Eneco's script. Not mine :)
Postby bertbigb » Fri Sep 13, 2019 1:22 pm
Dear All,
I try to do the update but I get the following:
eneco-001-083821:~# sh /root/update-rooted.sh
Welcome to the rooted Toon upgrade script. This script will try to upgrade your        Toon using your original connection with Eneco. It will start the VPN if necessa        ry.
Version: 3.992  - TheHogNL & TerrorSource & yjb - 3-9-2019
You are currently running version 4.7.23 on a qb2 with flavour ene
Available versions: 1.9.10 2.1.0 2.2.24 2.3.17 2.3.29 2.3.36 2.4.7 2.4.12 2.5.11 2.5.14 2.5.18 2.6.24 2.6.33 2.8.16 2.8.21 2.8.27 2.9.15 2.9.26 2.10.        15 3.0.29 3.0.32 3.1.22 3.2.14 3.2.18 3.2.21 3.3.8 3.4.2 3.4.4 3.5.4 3.6.3 3.7.8 3.7.9 4.3.20 4.4.21 4.7.23 4.8.25 4.9.23 4.9.124 4.10.6 4.11.6 4.12.        0 4.13.6 4.13.7 4.15.2 4.15.6 4.16.8 4.18.8 4.19.10 4.20.7 4.22.7 5.0.4 5.0.5 5.0.6 5.2.11 5.5.7 5.9.6
5.9.6
You need to upgrade to 5.0.4 first due to possible disk space issues! Selecting this version for you.
Upgrade script downloaded. We need to download the upgrade files first. No upgrade is done yet. Do you want me to download the files (yes) or quit (a        nything else)?
yes
Pogress: 0% ...
Then I tried to do the update at new (and now it comes to 23%):
Your Toon already tried downloading version 5.0.4 before. Need to force this version!
yes
Progress: 23%  ..
Prepare failed. Please check the logs at /mnt/data/update/upgrade-qb2.sh.log
Then I had a look in the log file and I see (the last lines)
> opkg_dl.download.supervisor: /tmp/opkg-RBQ9fj/busybox_1.27.2-r1_qb2.ipk: downloading
> opkg_dl.download.supervisor: /tmp/opkg-RBQ9fj/firmware-ma_1.143-master_all.ipk: downloading
> opkg_dl.download.supervisor: /tmp/opkg-RBQ9fj/happ-pwrusage_1.775-master_qb2.ipk: downloading
> opkg_dl.download.supervisor: /tmp/opkg-RBQ9fj/hcb-comm_1.199-N-master_qb2.ipk: downloading
> opkg_dl.download.supervisor: /tmp/opkg-RBQ9fj/kernel-image_2.6.36-R10-h28_qb2.ipk: downloading
> opkg_dl.download.supervisor: /tmp/opkg-RBQ9fj/libhcb-drv_1.446-master_qb2.ipk: downloading
> opkg_dl.download.supervisor: /tmp/opkg-RBQ9fj/libhcb-xml_1.136-master_qb2.ipk: downloading
> opkg_dl.download.supervisor: /tmp/opkg-RBQ9fj/libz1_1.2.8-r0_armv5e.ipk: downloading
> opkg_dl.download.supervisor: /tmp/opkg-RBQ9fj/openssl_1.0.2p-r0_armv5e.ipk: downloading
> opkg_dl.download.supervisor: /tmp/opkg-RBQ9fj/qt-gui_1.9133-master_qb2.ipk: downloading
> opkg_dl.download.supervisor: /tmp/opkg-RBQ9fj/wpa-supplicant-cli_2.6-r0_qb2.ipk: downloading
> opkg_dl.download.supervisor: /tmp/opkg-RBQ9fj/www-resources_1.38-master_qb2.ipk: downloading
The df -h gives me
eneco-001-083821:~# df -h
Filesystem                Size      Used Available Use% Mounted on
ubi0:rootfs             106.4M     54.8M     51.5M  52% /
tmpfs                    61.6M      2.5M     59.1M   4% /var/volatile
eneco-001-083821:~#
What to do now? I hope someone can help me.
bertbigb
Postby TerrorSource » Sat Sep 14, 2019 4:13 pm
bertbigb wrote:Dear All,
5.9.6
yes
Pogress: 0% ...
yes
Progress: 23%  ..
The df -h gives me
eneco-001-083821:~#
Can you post the complete log of the /mnt/data/update/upgrade-qb2.sh.log as an attachment?
My guess is that the issue is not shown on the lines you posted but before in the log.
TerrorSource
Return to Toon issues and support (Nederlands toegestaan)
cron
