NaN values toon Smartmeter in Home Assistant
Posted: Wed Oct 09, 2019 1:08 pm
i have climate and boiler working in HA, but the smartmeter part just keeps giving NaN sensor values.
I use the code from cyberjunkie, but also tried m-Aiden his code and from some other GitHub contributors.
I now HA connects to the Toon, because i get a NaN value, if i connect with a wrong IP adress, i get no values (-).
In the logs i get no errors.
I've search the webs extensively, as well as this board, but found no apparent solution.
I hope You wizards can help me in my Quest.
Regards Freddie
Regards Freddie
