Toon1 boot issue
Toon1 boot issue
Postby TheHogNL » Tue Mar 23, 2021 4:22 pm
Due to github URL changes a script change was necessary yesterday. We regret that a bug was introduced causing the download of resource files on a toon1 to fail. This will then result in a toon1 not able to show the GUI anymore (the toon stops booting at about 33% of the GUI screen).
For now it seems that we can not provide a automatic fix for these affected toons. So you might need to fix it yourself.
Easiest way is to SSH into your toon and issue this command:
rm /usr/bin/tsc ; reboot
This will remove the faulty tsc script and after a reboot a new tsc script will be downloaded automatically. This new script will then fix the resouce files. After about 8 mins you will notice a starting GUI again.
Another fix, without reboot:
/usr/bin/curl -Nks --retry 5 --connect-timeout 2 https://raw.githubusercontent.com/ToonSoftwareCollective/tscSettings/main/tsc -o /usr/bin/tsc
killall -9 tsc
This downloads the new tsc script directly and then restarts it by killing the old version.
Return to Toon issues and support (Nederlands toegestaan)
