I'm trying to put the rfxmeter values into a mysql database with php
He puts it in but the script doesn't come to a prompt, what do I wrong?
#!/usr/bin/php
<?php
$link = mysql_connect('localhost', 'rfxcom', 'rfxcom')or die('Couldnot connect: ' . mysql_error());
mysql_select_db( "rfxcom") or die('Could not select database');
$sql = "SELECT power FROM rfxpower ORDER by time DESC";
$query = mysql_query($sql);
$result = mysql_result($query, 0);
$data = shell_exec('/usr/local/bin/heyu rfxpower l2');
$verbruik = $data - $result;
$query2 = "insert into rfxpower(power,verbruik) values
('$data','$verbruik')";
mysql_query($query2);
// Free resultset
mysql_free_result($query);
// Closing connection
mysql_close($link);
php mysql statement hangs?
Are you sure it's not hanging on some command?
Try adding some echo statements in between, like this:
etc.
If that runs all the way to the last action, which is the mysql_close function in this case. Try adding the following, to make sure the script exits:
for more info see: http://www.php.net/exit
Maarten Damen
www.maartendamen.com
<?php
echo "connected to mysql server";
echo "database selected";
exit();
Maarten Damen
I got the problem, de php-cli form debian etch is a bug with exit.
Is it simple to get the script in perl. Any help
kind regards richard
