MPEG-4 file format
Pop your questions regarding Home automation software here.....
MPEG-4 file format
Postby Digit » Fri Apr 30, 2010 5:54 pm
I have an IP camera that i can only use with IE and a OCX or with an windows executable. The latter is just to horrible to look at, and i don't want to use the OCX.
I've already found out how to get a mpeg4 stream from the camera, but unfortunately it can't be played with VLC media player or any other player.
It seems the stream contains unsupported metadata which makes the media players unwilling to play the stream.
So all there's left to do is capture the stream and filter out this metadata myself; for that i'm searching for detailed information about the MPEG-4 file format, so that i can do the filtering and write the filtered stream to disk or whatever...
Searches have only led me to global descriptions or sites where you have to pay for the ISO documents... :(
Who can help me plz?
Re: MPEG-4 file format
Postby TANE » Sat May 01, 2010 12:25 am
Hope it's not a IP camera from Chine..called Vison or so..
Postby steve2xyz » Sat May 01, 2010 7:37 pm
Maybe there's something useful in libmpeg4ip?
http://www.debian-multimedia.org/dists/ ... ip-dev.php
Steve
steve2xyz
Postby Digit » Sat May 01, 2010 11:00 pm
Steve,
That was my 2nd option to try; searching code for mpeg4. :)
I hope it's not to hard to find what i'm looking for, cause if it takes to much time, the camera is not worth it...
But I'll give it a try, thanks.
Postby hero_hont » Fri Aug 27, 2010 7:34 am
Digit wrote:I have an IP camera that i can only use with IE and a OCX or with an windows executable. The latter is just to horrible to look at, and i don't want to use the OCX.
hih you..
I think you can change from mpeg4 to mp4 you can use softwareTotal Video Converter.
It can change:
* H.264 TS, Mpeg-2 TS, WMV-HD, MKV-HD, DivX-HD, Divx-HD, MOV-HD, FLV-HD and MP4-HD.
* MPEG audio(.mp3, mp2)
* Ms WAV (.wav)
* Ms WMA (.wma)
* OGG (.ogg)
* Amr audio (.amr)
* AC3 (.ac3)
* SUN AU (.au)
* m4a (mp4 audio)
* aac (aac audio)
* mmf (mmf audio)
* Flac (flac audio).after you can lister or see video, music VLC media or or any other player.
wishes your success
hero_hont
