Charts
Pop your questions regarding Home automation software here.....
Charts
Postby DJF3 » Sun May 13, 2012 9:12 pm
Team,
I'm looking for a solution that allows me to create (custom) charts based on .MDB file data. (RFXCOM, own DB, etc). This would be a (more flexible) alternative to RFXCharts.
- Online could be nice
- easy interface for filtering (table, year, month, week, custom filters etc)
- Scheduled saving of chart images
Any suggestions?
DJF3
Re: Charts
Postby Sooty » Sun May 13, 2012 11:05 pm
The main reason for me not continuing development of RFXCharts is the fact that not everyone wants the same thing when it comes to the actual charts and the data they contain.
In order to create a "suits all" solution I would need to create a user friendly interface for one of the charting API's which is a task I just don't have the time to undertake.
Another consideration is the frequency that data is recorded. Some people are happy to have the outside temperature for example recorded at 1 hour intervals and others would like it at 5 minute intervals. Wind speed and direction for example really need to be recorded when they change value or the data is meaningless. The recording of data is not a problem and it is easy enough to have any device recorded on change or at a given interval etc. The hard part is presenting the recorded data in charts that a user can configure to suit their requirements without having to learn a charting API.
I actually record nearly all my HS devices to a database, some at various intervals and others only when the value changes. I also have dampers for things like wind direction so that direction changes are not recorded if the wind speed is less than xx etc. I'm actually using the free Microsoft chart controls to create the charts and running the solution on an IIS server because the Homeseer web server won't play with the MS controls. This is not a solution that I can easily make available to other users as the charts are hard coded and bespoke to my system.
The Google charts tools are quite easy to use. You can get an idea of how it works here https://developers.google.com/chart/ima ... playground
Of course you will still need to extract the required data from you underlying DB and present it to Google charts in the correct format which will inevitably require some code writing.
There are also a number of free Java based charting solutions out there that look pretty good. Again you will need to consider how your data is recorded and some code writing will be required.
I already have a comprehensive data recording HS plug-in that I am using now, however I am waiting to see what HS3 brings to the table before I put a significant amount of time into any new charting front end. I'm not ruling out a full blown charting plug-in at some stage in the future but normal work seems to take priority these days :(
Paul..
Sooty
Re: Charts
Postby ludom » Wed Aug 22, 2012 3:01 pm
In my application I use HighCharts;
http://www.highcharts.com/
Fully Javascript based, so you have to create some pages (with PHP for example) to read-out your MDB files.
Home-brewed HA system based on Linux, PHP5, MySQL and Beanstalkd
ludom
Re: Charts
Postby vanisher » Wed Aug 22, 2012 8:19 pm
How are you getting the device values in the database? Which script are you using for that?
A Domotica starter, currently running: Plugwise, Z-Wave, Jeenods, Homeseer / DomotiGa
vanisher
Re: Charts
Postby Irritanterik » Thu Aug 23, 2012 11:50 pm
Hi Vanisher,
Just figured it all out, after lots of reading and learning on this forum. Probably my script might help you getting started with database logging.
I use this line in Script\Startup.txt within the Main sub:
  hs.RegisterStatusChangeCB "TON_StatusChange.vb", "StatusChange"
With this command Homeseer will call the 'StatusChange' function in TON_StatusChange.vb each time a DeviceStatus changes.
TON_StatusChange.vb contains the following:
'TONs Eerste StatusChange script
Const LogLevel As Integer = 1        '0 = no logging, 1 = normal logging, 2 = debug logging
Const DbUpdate As Boolean = TRUE
Const DbFile As String = "c:\Program Files\HomeSeer HS2\data\TON\TON_DB.mdb"
Const ScriptName As String = "TON_StatusChange"
Sub StatusChange(params)
   Dim hc As String
   Dim dc As String
   Dim status As Integer
   Dim deviceId As Integer
    Dim strConnectionString As String
   Dim sql As String
    Dim objConn As Object
   hc = params(0)
   dc = params(1)
   status = params(2)
   deviceId = params(3)
   Log("Logging status change for device " & hc & dc & " (" & status & ")")
   Log("hc: " & hc & " dc: " & dc & " status: " & status & " deviceid: " & deviceId, 2)
   ' === SQL STATEMENT
   sql = "INSERT INTO tblStateUpdate ( HouseCode, DeviceCode, State, DeviceId ) values ("
   sql = sql & "'" & hc & "','" & dc & "'," & status & "," & DeviceId & ");"
   Log("SQL query: " & sql, 2)
   ' === DB WRITE1
   If DbUpdate Then
      objConn = CreateObject("ADODB.Connection")
      strConnectionString = "Provider=Microsoft.Jet.OLEDB.4.0; Data Source=" & DbFile
      objConn.Open(strConnectionString)
      objConn.execute(sql)
      objConn.close()
      objConn = Nothing
      Log("Write To DB executed", 2)
   Else
      Log("Write To DB disabled", 2)
   End if
End Sub
Private Sub Log(Message As String, Optional MessageLevel As Integer = 1)
   If LogLevel >= MessageLevel Then
      hs.WriteLog(ScriptName, Message)
   End if
End Sub
For now i log all devicechanges in a MS Access database. To use this script the database has to contain a table named tblStatuUpdate with fields:
- ID (autoindexnumber)
- DateTime (datefield with default = now())
- HouseCode (text)
- DeviceCode (text)
- State (integer)
- DeviceId (integer)
My next step is to figure out how to combine ASP.NET, JqWidgets and Highcharts with Homeseer...
Irritanterik
cron
