Loods like there is a new IP doorcam available on the market.
ELEC IP DOORCAM IP video-deurintercom in de Conrad online shop - https://www.conrad.nl/nl/elec-ip-doorca ... 47915.html
Anyone experience with this cam?
Sent from my iPad using Tapatalk
Elec IP doorcam
Moderator: Esteban
Re: Elec IP doorcam
looks nice, also the specs..
one user remark that the connection via the app is not working good
you should also be able to get the images of the cam, so is there an api
- RDNZL
Re: Elec IP doorcam
Some more resources.
Manufacturer:
http://hesdo.nl/onze-merken/alecto/huis ... rbel-idc25
A little bit cheaper even:
http://www.redcoon.nl/B635787-Alecto-El ... erkcameras
Also known as doorsafe 6600?
http://www.bol.com/nl/p/wifi-deurbel-me ... 046096434/
http://www.doorsafe.nl/shop/wifi-deurbe ... et-camera/
Using the correct mounting height is critical since it uses 16:9 camera format.
There is a mounting bracket to mount it under 45 degree angle
http://www.bol.com/nl/p/doorsafe-6610-m ... _role%3din
http://www.doorsafe.nl/shop/wifi-deurbe ... de-ds6600/
Some complaints about bad audio, clumsy wiring.
It uses an unknown cloudservice.
Manufacturer:
Regards, Ron.
