Built in IP Dome camera outdoor
Moderator: Esteban
Lempens
Post by Lempens »
I'm looking for a built in IP dome camera for use outdoor.
I'm making an outdoor roof of concrete above the main entrance. And want to built in the camera in the roof.
Does anyone have experience with this. Because I don't want to let it stick out very much.
olof
Re: Built in IP Dome camera outdoor
Post by olof »
Your requirements are somewhat different. Normally an IP dome camera is placed on the ceiling (outdoor / indoor) but not inside the ceiling.
I suggest you ask that question to the experts over at http://www.networkcamerareviews.com/forums/
Some really good reviews on IP camera's can be found at http://www.networkcameracritic.com/
I would get a Powered Over Ethernet (POE) IP camera. It saves having to place 2 wires to the camera (ethernet + power)
Cheers,
Olof
olof
Post by olof »
here is a nice mini dome IP camera for outdoors:
http://www.networkcameracritic.com/?p=1595#more-1595
Q-see is private label US company. Camera is made by Dahua or HikVision
or
http://www.networkcameracritic.com/?p=1479#more-1479
cheers,
Olof
Lempens
Post by Lempens »
Thanks for the advice of Dahua and Hikvision.
But there is no standard camera that can be used in a Halox Box
The have different size cover plates.
olof
Post by olof »
Ok, then I still think you should ask the experts at the IP cameraforum. There might be acreative solution over there.
raymonvdm
Post by raymonvdm »
When i google for inceiling dome camera i get some hits
olof
Post by olof »
I would make sure itbis one rated for outdoors (ip rating min 65, low temp, etc..).
Can't tell from the picture, but it looks like an indoor camera
