As I have now connected my boiler directly, I have little/no use for the OTGW I built in December. It has been connected and running without issue since built. Modifications from the original spec include upgraded transformer, ESP8266 (Adafruit) with ESP-Link. OTGW can be reset from ESP-Link interface (no need to open case or reset button)
Was configured for and working with Domoticz. €70.00+post
[Sold/Verkocht] - Opentherm Gateway with ESP8266 WiFi
Re: Opentherm Gateway with ESP8266 WiFi - Less than 2months old
Very much interest! PM
Sent you a reply...but it says its still in my outbox - let me know if you receive otherwise I'll try contact you by emailsimjoc wrote:Very much interest! PM
Received, probably this gateway is sold
Re: [Sold/Verkocht] - Opentherm Gateway with ESP8266 WiFi
how did you achieve this functionality? Can you please post details how to wire ESP8266 together with OTGW to be able to reset it from esp-link?rjblake wrote:.. OTGW can be reset from ESP-Link interface (no need to open case or reset button)
many thanks in advance.
Very easily. Connect one of the RST pins on the OTGW to a GPIO pin on the ESP8266, configure in ESP-Link that this GPIO is for 'reset' from the web interface and job done. Bear in mind that I was using an Adafruit Huzzah (which is ok with 5V). I connected GPIO5 in my case. If you want to know how to wire an ESP8266 completely to the OTGW, there are a number of write ups already, but I could shed some light. A few changes to components is suggested/requiredBororo wrote:how did you achieve this functionality? Can you please post details how to wire ESP8266 together with OTGW to be able to reset it from esp-link?rjblake wrote:.. OTGW can be reset from ESP-Link interface (no need to open case or reset button)
