Thanks for the replies
I took a little while again, i went to the south of the Netherlands again for work and even to England for a little while.
Where someone crashed in the back of my fan when i was traveling , luckily still in the Netherlands.
Just damage on the back nothing further .
Had to rebuild a biogas installation that was burned to the ground a few weeks ago.
Only thing i know is that England is not a country for me to go on a holiday, the left driving on the 4 lane roundabout is kinda troubling for the first time especially when they for got the markings on the road and it is raining and dark...
I managed to come out without any accidents, the person driving with me said i was actually doing pretty good, and he told me why he wanted me to drive instead of him haha
Year before he went alone and it was no fun, probably better to rent a car there with the steering wheel on the right.
I did see something nice i must add, stoneheadge i believe it is called.
So i was very happy when we where in the train again to France and then back home.
Have allot of work to do and took last week off, this week also for a few days.
About the rain re using, i have read some things about it, actually been reeding for whole evenings about it.
First i thought to use the water after filtering also for my dishwasher since there is little to no chalk in this water.
And i wanted to shower / bath with the same water, this would be possible with filtering machines to make it "drinkable" and will cost way to much money.
It's more a fun project actually, and who knows a few years later there will be certain discovery's to filter it for less then it costs now.
For now i will use a leave/dirt filter to catch the most debris coming from it, as far it would catch leaves because the building is high and far away from trees.
Something like this will filter the first part out as far as i could find , there are bigger filters but the price also rises rapidly
ravshopping.nl/3p-regenwater-filter-col ... grijs.html or here for more types :
http://www.dbcom.nl/regenwaterfilters.htm
And i will use the water for my washing machine, the water could be with a wrong PH value.
I think they call it acid rain ?, but to get the right PH value when you use a plastic tank you can do several things.
Most easy way is use a concrete tank, but in my case using old IBC plastic 1000L tanks i will lower some concrete blocks in the tank and this will do the same.
So it won't damage the metals in the machine and my clothes.
Use a few small particle filters that do not cost to much or you can wash them to clean them once a .....
The other problem is that the roof needs to be repaired.
This is +/- 240m2.
There is some old layer of bitumen on the roof that needs to be changed.
This whole idea is actually because of another thing i wanted to add on my roof, and that's solar panels.
Since i have 20 panels sitting in my garage not catching any light and i want to place them on a solar ramp on the roof.
I need to drill holes in the roof, connect big pipes with a chuck connection on the construction beams of my house.
Not drilling in the supports or welding on them to leave there strength.
This way i have full strength instead of having to add enormous counter weight for 34 panels in total.
This way the roofing material won't be stressed to much and less weight on the roof, is less weight on the total construction.
Now the old bitumen layer is in a year or two ready to replaced, Bitumen is not great to use when you want to re use rain water since it is just tar , chemicals.
And i can replace the bitumen again with bitumen, but then after 10-15 years or a bit longer i have to replace it again.
So i am going to do my roof with Resitrix, this is a best of both worlds product.
Been reading and searching for days about what to use, what i need , etc etc, until it drove me crazy.
This product should be oke for at least 50 years
https://www.resitrix-epdm.be/
A friend of mine is working as a slater and he gave me some info what to do and what not and said this is one of the better materials at the moment,
but when searching on rain water re using with a resitrix roof this was dismal, Why?
Well there are several reports on Belgium forum's about brown water coming of these roofs.
In Belgium they are much further with rain water use since i believe it has been mandatory when rebuilding or building your house to add a water tank in the ground and use it.
For this problem i could not find much except painting the whole roof with a special coating, alulon or something similar that would solve the problem.
This was discouraging but i found it more important to "never" have to go up to the roof and replace the material again.
After a little while i found on the internet the SEEH arrangement
rvo.nl/subsidies-regelingen/subsidie-en ... eigen-huis
This made me smile a bit more , because it basically says when you insulate your house, at least 2 sorts of isolation.
You can get subsidized for it, for a certain amount of money.
This got my attention and i have been reading and searching how what etc etc for days until night times in bed on my phone
So now i am going to place insulatiom PIR plates on the whole roof that are 130mm thick and the RD value of these plates is RD 5.48.
I first opened my old roof to see what was under it, here i found 100mm PS plates with a RD value of 2 at most.. so this would be a great improvement.
But for the arrangement this is not enough just roof isolation.
I wanted to add cavity wall insulation , drilling a hole in the wall learned me that i have already small plastic sort of snow between the cavity wall.
Then i read a bit further, HR++ or triple glass will count as 1.
So i am in luck this time because i in December i am going to replace all the doors/windows and frames for triple glass and insulated frames.
Everything will be plastic and triple glass, these also count, and you have a extra option on the SEEH arrangement for using Triple glass in combination with insulated window frames.
Also the doors i ordered are like vault doors, insulated and for this you can get 120 € every 1m2
Since i have 14 m2 of doors and 16m2 window frames this will save me some money
These are the models i chose , a different color though.
Since i wanted to replace the air refreshing system for a balanced ventilation system with a heat exchanger i read allot about it.
But i came to the conclusion that it would take to much work to add this vent channel in each room and a channel to take the "dirty" air out.
I work quite some times with air systems but a bit bigger for, for example this is what i made a little while ago :
To have the right amount of airflow you have to start as big as possible and then make the end smaller to have the right air speeds.
When using to much elbows you will constrict the airflow resulting in bad values and noise.
Also another thing was that i have to go from round tubes to square tubing if i want to hide the tubes in my fake ceiling.
I also a little while added my fake ceiling plaster plates and it basically takes to much time to do all this and keep the sound production away.
Some good sites to read if you are interested are these :
http://www.jive.nl/~tenkink/WTW/
olino.org/articles/2010/03/08/aanleg-en ... entilatie/
So i decided to just place a Itho box with a CO2 sensor in the rooms that will arrange when to start to vent if it is needed.
This i can control quite easily with a arduino since they have a 0-10v connection.
I worked for a few weeks for a friend of mine, he has a demolition company.
When demolishing a home in Amsterdam i took the central heating boiler away and the air vent from itho box.
Opened this and there was also a 0-10v connection
Also want to make a shower heat exchanger, i mean this model :
Just for the fun of it, and if it really works well , why not
Some stuff i have done in my house after some busy weeks again is taking out the floor of the bathroom.
Im so happy that my dad gave me a present a few weeks ago , they are pretty cheap in France , no brand, but works absolutely great.
Believe me when i say that this is nothing compared to the standard drilling machines from makita for instance with a hammer function, without this i would have been busy for several more weeks.
My neighbor is also happy i think , 3 weekends busy hammering the *** out of it haha.
my other neighbor came to me and asked if i needed some wooden supports, why i asked ?
Well we are shaking and enjoying the sound from your hammer, these neighbors live about 7 meters next to me and the houses are not connected , to give you a impression of the noise
It took 3 trailers full with debris
and finally
Also made a choice about the floor heating system and i chose the wet system using concrete since the price of the dry system was way to high for me.
For a first time it was a bit of a hassle, first insulation so the heat would be radiated to the top instead of in the concrete.
and some gauze where the hose would be fitted on.
At first i placed a hose with my dad on te the bathroom floor, its very sturdy to handle the hose and it gets in a knot very fast.
After being busy from the morning till i think it was 23.30 i was getting mad and at the point of cutting the hose since this happened all the time, being alone it is very annoying and i stopped with it.
I spoke to a forum member on telegram and he offered me to help , thanks allot R_255 ;0 ext morning i picked him up and we manage to place the hose in some rooms.
Also the rooms need to be divided in zones, every zone can be 120M max in length otherwise the floor heating won't work optimal.
But where to end , so you have enough hose left to get back to the divider/connection point.
Well he thought of a great way, using a cable 120m in length and put that on the ground to see what we could do and this worked.
Been busy till the night, yesterday also some work but the tywraps i bought ( 2000) are gone so i am going to pick up some more to finish the last room.
First i wanted to make the distribution block myself since its from HDPE and very simple to make but i have not much time so i thought well , ill just order it.
Now i hope this week the concrete floor will be poured on the tubes and another thing is done.
I needed the exact measurements for my building for the floor heating/insulation for the roof etc and i used them to make a drawing in sweet home 3d.
It came out quite nice i must add
Some of the fronts i needed to make for my cove in the living room are made from MDF, i used a hand mill to take out a part that would slide on the edge.
I have made some by hand first and for 10 pieces it took almost 6 or 7 hours and allot of dust.
Friend of mine uses allot of woodworking machines making window frames and well actually everything at his work.
It didn't take 10 minutes in total for 20 pieces .....
Here is a video :
https://www.flickr.com/gp/134761793@N04/62J4n7
What are you talking about, well these fronts i mean that prevent you from looking into the led strips
Also bought a PTZ IP cam with a Sony imx178 sensor and it is amazing i must say.
A bit big but works good , i hanged it with some tywraps the same evening on my testing pole haha.
That's it for now.
Will keep you guys updated again
