I am looking for counter pulse to put on the mechanical water meter of my water supplier company. I also want to transmit the comsuption datas wireless.
If anyone has some pieces of solutions, i will be happy to receive them.
Thanks in advance
Normand
Water mesure
Water mesure
Check www.rfxcom.com: RFXMeter + RFXPulse. I use it to monitor water usage. Works perfect & always.
Water mesure
<br />Check www.rfxcom.com: RFXMeter + RFXPulse. I use it to monitor water usage. Works perfect & always.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Thanks a lot Robert but i need a sensor to put on my existing water counter
- Snelvuur
Water mesure
Andr: the rfxpulse is one of those devices you put on your mechanical water meter..
Water mesure
Normand,
Then besides RFXCOM you need an adittional water meter with pulse output, to put in series with the existing one. That is the easiest. It takes a bit of plumbing but it's not to hard. Here you can find some pictures. Putting a counter on an existing meter i do not have a solution for.
