I have a mediacenter pc its on 24/7 because homeseer is on it,
but it`s using 140 watt,is there a better solution to run homeseer on with enough usb ports to run rfxcom ,infrared,webcam,enz.
and using a lot less energie?
better solution?
better solution?
There are some good solutions like the eee pc from Asus power consumption +/- 18 watt
Asus Top and shuttle are also good (including Touch screen)
If you are looking for a combination MCE and Homeseer:
I have Acre Idea 511 power consumption 55 watt if you are interested in this let me know that.
better solution?
Mac Mini!
better solution?
<br />There are some good solutions like the eee pc from Asus power consumption +/- 18 watt
Do you have some specs and demensions because my mce is build in de wall
better solution?
Mac Mini is much better...but will cost a bit more.
better solution?
Acer spec
http://www.topproduct.nl/hardware/deskt ... aties.html
Only different my Acer has 3 Gb memory
