Humax 5050C
Humax 5050C
Just installed my new PVR.
Humax has build a nice device with lot of options including HD recording with dual tuner.
Standby power consumption is 2,19 - 4,5 watt (Plugwise)
in operation +/- 11 watt
Humax 5050C
Hi Enver,
I have the 5050c to, but there are quite a few buggy problems in it
Picture quality is good, but the IR is not very strong.
Ftp is very Spartan etc. Standby setting is strange
gr Ruud
gr Ruud
Humax 5050C
Ruud,
IR is working fine here..it's stronger than all other IR remotes..It can pick up signals even when not in straight line. I have connected to Irtrans..
Standby is working okay here there is also a extra power save option in standby
Humax is not connected to network...can't tell you any thing about FTP option.
Humax 5050C
When the extra power save is active power consumption in standby is so low that plugwise can't measure it.
even the display (clock) will go black
Device will sometimes wakeup with the message UPDATE after short time it will go in standby again.
Humax 5050C
When in powersavemode it give's no signal to the antenna output.
There for youre televison get's no signal when the 5050 is of.
Humax 5050C
I have spited the cable before the Humax so no problem here
- Willem4ever
- Global Moderator
Humax 5050C
I got this device today, made a few recordings and sofar so good. Two strange things I noticed, when machine wakes-up from standby it always booting and takes a little bit of time to become fully active. This behavior obviously doesn't happen during recordings. Ok here is something strange, before a recording the machine wakes up, press standby button and you have instant picture, switch it off (press standby) and the machine becomes unresponsive untill the recording starts. During this period the display flickers to show it is receiving IR when you press a button on the remote.
There is a red/blue led beneath the display, what is the purpose, it is blue for a short while and it turns red and stays red ... who knows. (i search thru the manual, but I can't find a reference)
Files can be accessed with FTP and are in .ts format .....
Humax 5050C
I heard that the dutch televisonmakers, try to stop the delivery of the humax 5050c. They don't like the FTP possibility of this machine, something about copyright's etc
Gr Ruud
Gr Ruud
- Willem4ever
- Global Moderator
Humax 5050C
Why ? there are so many possibilities to record TV broadcasts in digital quality, on my Mac I have an Elgato device, does exactly the same.
- Willem4ever
- Global Moderator
Humax 5050C
FTP seems dead slow .... can you confirm this rualblas ?
Humax 5050C
Good FTP access is only possible with active client option
most of the clients are default set top passive.
- Willem4ever
- Global Moderator
Humax 5050C
Don't think this has to do with active or passive. Anyway the ts file plays nicely with VLC subtitles can be switched on or off.
Humax 5050C
@willem4ever,
Your right ftp is very slow.
Deleting of files is also very slow.
There are some known bugs in the system. But it's stil waiting voor a update.
Next a copy/paste from de ziggo forum.
It's dutch text sorry!!!
Bugs
- Opnamen welke zijn geprogrammeerd stoppen niet op tijd
- Opnamen komen meerdere malen met meerdere opnamelengtes
- Opname/weergave blijken niet of niet geheel uitgevoerd met een Encryptie-error(mogelijke, gedeeltelijke oplossing. Humax laten opwarmen 5 a 10 minuten voor een opname)
- Handshake probleem, Humax geeft zwart beeld bij inschakelen na wisselen van kanaal is het probleem "opgelost"
-Door extra tijd bij een opname in te plannen (3 min. voor, 10min na) word de verkeerde EPG-informatie opgeslagen
- Matige SD kwaliteit, te gecompressed
- Na het opnemen van video met subtitlestream (Discovery Science) loopt de ondertiteling bij het afspelen niet synchroon
- teletekstpagina's worden niet automatisch ververst.
- Bij het hernoemen van je favorietenlijst vervalt de reeds ingevoerde tekst als je van toetsenbord wisselt. bv tbv invoeren "/"
- Bij het inplannen van "herhaal"opnamen krijgt men een conflictmelding
- Audio: Kiezen van geluidskanaal (stereo/links/rechts) in het geluidsmenu met cursortoetsen links/rechts werkt niet. Zou volgens handleiding wel moeten. (pag 24, paragr. 4.6)
- Foto's kijken via SCART. Speler gaat er van uit dat het beeld 16:9 is. Als je naar een 4:3 zender kijkt, blijft TV in 4:3 verhouding staan. Fotos worden dan niet in juiste verhouding weergegeven. Op de component uitgang gaat het wel goed.
- Aspect ratio change tijdens skippen in een opname wordt niet opgemerkt op SCART uitgang, Widescreen pulse wordt niet verzonden naar TV. Bijv. reclame op Veronica wordt in breedbeeld uitgezonden, druk aantal keer op skip tot in het volgende programma dat 4:3 is. De 4:3 puls wordt niet naar de TV gestuurd, dus beeld blijft opgerekt. Op de component uitgang gaat het wel goed.
- Instellingen voor weergeven breedbeelduitzending op een 4:3 scherm werken niet goed. Center cut out werkt niet op SCART, beeld blijft wel 4:3, maar randen zijn er niet af geknipt (resultaat heel dunne mensen). Op de component uitgang zijn de randen er dan wel af... Ook 14:9 lijkt niet goed te gaan, er zou dan een randje aan de zijkanten afgesneden moeten worden (anders klopt de verhouding niet meer) en dat gebeurt niet. Beeld wordt vertikaal wel ingedrukt. (minder dan bij 16:9, zoals te verwachten)
- Favorietenlijst hernoemen; Je kan een favorietenlijst een heel lange naam geven (70 chars?) Na standby zijn daar 20 characters van over, de rest is weg.
- In het menu "zenders vergrendelen", werkt de blauwe knop "alles ontgrendelen" niet.
- Timer uitschakelen op bepaald tijdstip, vraag verschijnt 1 minuut van tevoren "wilt u blijven kijken", kies JA, toch schakelt de 5050 uit na 1 minuut...
- Klokje verdwijnt in de epg als je de tijd handmatig verlengt
- na inschakelen onverklaarbaar veel beeldruis of groen scherm
- formatteren/partitioneren vanuit het menu gaat niet goed
- bij extra opnametijd klopt de EPG-info in de medialijst niet. mogelijk kan de Humax automatisch de EPG info van bijvoorbeeld 30 minuten na het starten van de opname weergeven in de Medialijst.
- Als je insteld dat je een letterinvoer per sms-indeling wilt doen is deze keuze opgeheven na het uit,- inschakelen van de Humax
- Hetzelfde geld voor de ingestelde audiovertraging, hiervoor moet men na het opnieuw inschakelen eerst weer door het menu
Bug/Wish
- De timerbalk blijft exact 10 seconden staan, ondanks dat de instelling doet vermoeden dat je dit aan kunt passen. de bug is... de instelling werkt niet. de wish is we willen dit kunnen instellen
- Uitlijning van de EPG is onprettig
Wishes:
- Knipfunctie in opnamen
- Dimbaar display en LED (indien mogelijk)
- Slimmere EPG-opnames (bij 2 programma's achter elkaar opnemen). zoals omschreven in bericht #6 en in dit bericht.
- Tijdgesynchroniseerde opnamen
- EPG met TVTV - ondersteuning
- Opnamekeuzes als in link
- het hernoemen van een opname voordat deze word opgenomen
- Bredere ondersteuning Mediabestanden
- Grotere HDD (is uiteraard niet mogelijk dmv een Firmwareupgrade)
- Humax on Demand (HoD ) op afstand programmeren (tevens onderdeel van tvtv)
- Mogelijkheid om na het teruggaan in de buffer vanaf dat punt op te nemen
- Opname tijd vermelden in Medialijst
- Grotere tekst teletekst, pagina's bekijken welke al geladen zijn
- Knipfunctie in bewerkmodus (gele toets)
- 16:10 modus voor 4:3 content
- Programma's markeren of klaarzetten voor Deleten bv. (dat dit word uitgevoerd zodra de Humax hier klaar voor is of bij voorkeur direct).
- Kortere Opstarttijd
- Picture in Picture net als de 9200C (niet mogelijk omdat er geen dual decosing word ondersteunt)
- een mogelijkheid om een USB disk netjes te unmounten voordat je hem lostrekt.
- Mogelijkheid om programma's langer dan 20 minuten uitloop te geven
- Mogelijkheid om vaste opstartzender in te stellen voor iig Radio.
- Mogelijkheid om een favorietenlijst echt vast te zetten (zodat bij iedere keer opstarten deze word gekozen oid)
- Ondersteuning NTFS
- Sneller deleten.
- Mogelijkheid om beeldinstellingen/regelingen op de Humax in te stellen
- Mogelijkheid meerdere playlist in te stellen
- Instelbare grootte ondertiteling
- Auto Replace Recording
- het aan en uit kunnen schakelen van meldingen.
- Optie tot eenmalige scroll in display van lange File,- programmanamen
- Mogelijkheid om de klok handmatig in te stellen
- "Als de humax de keuze geeft opname of live opname beindigen omwille van een nieuwe opname. bij geen antwoord of uitschakelen apparaat, opname starten."
- Weergave datum/tijd in bestandsbeheermenu.
Het volgende kon ik niet samenvatten en heb ik zodoende in zijn geheel gekopieerd:
Hoi,
Wat zitten spelen met een externe USB disk. Eerst een algemene opmerking: copieren naar de disk vind ik vrij traag gaan. Hij is echt minuten bezig met een relatief klein bestand van +/- 1G. Maar ik weet niet of dat aan mijn USB disk ligt of niet. Wellicht doet ie USB1 ipv USB2 en/of is er verschil tussen de voor en de achter USB aansluitng? Iets om nog eens verder uit te zoeken.
Maar nu de bugs
1. Ik had de disk op Linux de disk eerst als ext2 geformateerd. De disk werd door de Humax niet herkend. Pas toen ik hem als ext3 formateerde, ging het goed.
2. Toen ik probeerde via het "USB instelling" menu alle bestanden te wissen, resette de Humax.
3. De handleiding spreekt in de sectie "USB instelling" over formatteren. Het menu heeft het over "alle bestanden wissen". Formatteren is niet hetzelfde als alle bestanden wissen. Graag in de menu's en de handleiding eenduidige termen gebruiken.
4. Verder is het nuttig als (indien formatteren bedoeld wordt) erbij zou staan WELK formaat ext2, ext3, FAT32, ....gebruikt gaat worden. Of een keuze, anders zadel je windows gebruikers mogelijk op met een bestandsformaat waar ze niks mee kunnen. Het zou ook aardig zijn als NTFS en HFS+ (voor de mac gebruikers) ondersteund werden. FAT32 heeft te veel beperkingen.
Als ik wat tijd vind, zal ik proberen problemen 1 en 2 te reproduceren.
met dank aan om1
Bugs
Bug/Wish
Wishes:
- Sneller deleten.
Hoi,
Maar nu de bugs
met dank aan om1
