Currently I have a humax settop box with ziggo. Works fine, I use plugwise to determine if it's on or off and a IR Trans to control it.
I don't really like it because it want to add more info about the device in my control panel. Also the control and onoff status is a bit flimsy.
I read about some decoder like the vu duo2 which can be connected through its Ethernet port. It sends statuses. I read some about this decoder. Its track record with ziggo isn't flawless. I'm looking for advice.
What are you guys using? Can you connect to it?
