Long time users of this forum knows already about ZMC v3 for doing whole house audio and VR cheaply. ( http://www.zoelen.net/ZMC.htm )
However, while this script is great it got a real problem and that is that doesn't run on HS3. That has changed now!
I've rewritten big parts of the script to make it function under HS3. But even more, It now supports also multiple units so if you need up to 96 outputs then here you have it.
So what is possible with this version?
- Runs in HomeSeer 3
- Control up to 8 units (AP400, AP800, XAP400 or XAP800)
- Max. number of outputs is 96(or 64 when using XAP400)
- Max number of microphones is 8
- Added a setup to create all the devices for you
- Simplified the configuration
- Added StartMediaPlayer call
- Added RestoreUnit call
' Version
' 4.0.3 - 29 Aug 2015
' Conversion to integer bug prevented to calculate the
' correct unitID in some instances.
' Code refactoring
' 4.0.2 - 15 Aug 2015
' Added extra check to catch the 'Room not found' case and
' trying to resolve it without error.
' (Documentation) Added StartVR and EndVR to the list of
' implemented unit calls.
' 4.0.1 - 12 Aug 2015
' Setup contained 2 wrong references for Telco and VR devices
Head over to http://www.zoelen.net/ZMCv4.htm to read more about it and to get your copy of the files.
