I have an Elster M100 'Artist' water meter (see http://www.elster-meters.nl/downloads/MNRArtist.pdf dutch, or http://www.elstermetering.com/downloads ... e_0708.pdf english but less info).
According to the documentation the meter is or can be equipped with an magnetic contact so that a reed/pulse meter can be attached. It is unclear to me if my model has this magnetic contact or whether it can be fitted onto it (without tampering with the device of course). Does anyone know if my device has this magnetic part and if so, how I should attach the reed contact to be able to measure pulses?
Because of the black wheel with indentations (see picture in documents) I assume I could also fit an optical pulse meter, but if the device is already equipped with or prepared for some pulse mechanism I think it would make sense to make use of it. Does anyone have any experience with this type of meter?
Thanks and regards, PP
