What about RFID ?
What about RFID ?
Voortbordurend op GPS...maar zeker niet minder serieus bedoeld:
Heeft iemand ooit al eens serieus onderzoek gedaan wat er tegenwoordig met RFID te bereiken valt en hoe dit evt. toe te passen in het Domotica-domein? Mogelijkheden, kostenplaatje, ...
"Elvis has left the building" geheel geautomatiseerd te horen krijgen is dan alleen nog maar een kwestie van een beetje programmeren..toch?
Gr.
What about RFID ?
Hi Digit,
It's on my ToDo list as well, I like rfid, specially the long range RFid. See also this topic
http://www.domoticaforum.eu/topic.asp?T ... Terms=rfid
http://www.iautomate.com has some interesting RFid devices which are compatible with Homeseer. Long range RFid I want to use for example in the car, to see that you are approaching your home and trigger all kind of events. Short rage RFid for opening secure doors, alarm de- activating, and of course in the near feature for all your products in the fridge and garbage can :-)
I'm thinking about buying something from www.iautomate.com in the near future and experiment with it. What are your thoughts?
Please keep it in English, I know there are some topic in Dutch but those are a split of from a Dutch Homerseer forum. You know topics can go in all directions and sometimes it's interesting to split the topic.
Regards Pieter
MindBender
What about RFID ?
Post by MindBender »
Me too. Does anybody know a doctor who is willing to implant a RFID pill in my upper arm? Does anybody know if you can read out the tags useds in pets and what standard they use?
Snelvuur
What about RFID ?
Post by Snelvuur »
I know "Ski-Hut" in Rotterdam once had a test where people had an implant in there arm/hand so they could pay the bill (instead of asking them if/when there too drunk)
kockie
What about RFID ?
Post by kockie »
Unfortunately I am not a doctor, i'm a veterinarian. I have "tagged" many animals with a chip and was thinking of the same idea. I do not think using a pet chip is a good idea, because the range to read it is very small, on order of cm's. I would propose to start witch a chip in your wallet instead of placing one in your arm. If you insist, i could look if there is a possibility to place one in your arm.
MindBender
What about RFID ?
Interesting, kockie...
Could (/would) you tag me? Can you supply tags? Do you know which protocol is being used for these tags? Would it be a wise idea to tag my 15(!) years old Persian cat?
kockie
What about RFID ?
Post by kockie »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by MindBender</i>
<br />Interesting, kockie...
I could tag you (if you won't tell anyone[8D]) I can supply the tags, shouldn't be a problem.. The protocol, I don't know, but http://www.virbac.nl/elektronische_identificatie.htm here you can read what the manufacturer says about it (in dutch)
I say again that de reach of these tags is very poor, just a couple of cm's (with our reader).
It's always wise to tag a cat, especially when it goes out on occasion.
What about RFID ?
Good Idea to tag Mindbinder then we can alway's see on which forum he is [:D]
MindBender
What about RFID ?
Pet tags seem to use the ISO 11784 and ISO 11785 standard to communicate with a reader. Older tags seem to use a 125kHz carrier, but more modern tags use 134.2kHz. Some tags offer OPT features as well. The standard is told to be Open, but more like in 'OpenTherm' than like in 'Open Source'. And the encryption algorithm to convert the tag data into registration number is still a protected secret. For all of us who want to know more, Mr. Andy Kluck has written a web page full of useful information:
http://www.maxmicrochip.com/
foo
What about RFID ?
Post by foo »
On http://www.eztronics.nl/webshop/catalog ... th/1_28_29 you can buy al kinds of rfid tags
ddgiel
What about RFID ?
Post by ddgiel »
Hi Bwired,
On your weblog of 19 Okt 2007 (RFID in car) http://www.bwired.nl/weblog.asp?id=126
, you show the RFID in your car.
Can you explain more in details. Which reader, tags you use an how its implemented.
The long range RFID is intresting.
drmacchi
What about RFID ?
Post by drmacchi »
May be similar to these . http://stores.ebay.com/Ananiah-Electron ... idZ2QQtZkm . they work with Homeseer and Blade's Rfid plugin.
Lorenzo
Vullisbak
What about RFID ?
Post by Vullisbak »
Anyone of you successfully implemented a RFID access control mechanism?
I currently use a RF transmitter to (un)arm the security system. But since it is a rather bulky device on my key cord, and has some reception issues, I'm looking for IButton-like security at my front- and backdoor. Any advice is welcomed.
Carlo
What about RFID ?
Post by Carlo »
Hi Vullisbak (and all other members),
Because more people experience the same problems, I am building an active RF-ID like you described myself.
It will work stable within a range between 100m - 300m and I expect to have it working in January for an interesting low price! (Unfortunately some patience is needed, but then again you get something nice.)
Another member already offered to make the plug-in for Homeseer.
If you have some special requirements, wishes or ideas, perhaps I can implement them also for you.
(An extra advantage when built by the community.)
Carlo
What about RFID ?
Keep us posted about that Carlo, lots of members are interested, I'm sure!
Perhaps you can make a new topic in Home automation projects and tell us about the specs etc. perhaps we can help.....
good luck on building the set!
