miele@home
Re: miele@home and the experience
Postby Verkenner » Mon Jan 10, 2011 3:15 pm
Hi Snelvuur,
I recently installed the Miele@home system.
Its a part of KEMA Smart Grid.
ECN in Petten can turn on the washingmachine and dishwasher from remote when energy-price is low on the spotmarket (during the nights).
There is a connection with my Miele@home-system via ADSL.
Miele in the Netherlands do not have knowledge of the gateway.
Indeed, my gateway comes fron Germany. ;-)
Thanks for your quick response and advice.
I am going to use the new machines.
The chicken are in the grill ( I trust Miele@home but no risk) ;-)
See yeah, Verkenner
Best regards, Verkenner
Verkenner
Re: miele@home
Postby Snelvuur » Mon Jan 10, 2011 3:39 pm
i would want to know how they turn on/off there devices since i have no clue how to do that with the gateway. Indeed miele@home in .nl does not know how to work it, i also got it from germany. i know you can read out the xml and you can also "turn off" the current program for most devices with the xml but i have not seen any things to turn on/off via remote.
Snelvuur
Re: miele@home
Postby Snelvuur » Thu Dec 08, 2011 12:00 pm
An update, i was at the Domotica Beurs and noticed the miele devices and some more updates. I asked the friendly people from Miele and they upgraded my gateway. It now has a newer version with more feedback through XML. I can get more detailed information like which hub is turned on and which programs are used and if it is turned on (but not running for instance)
Also there is a new pdf now for the gateway which http://files.domoticaforum.eu/Miele/Mie ... DE.pdf.pdf
I've not found this on the german site.
A new iphone app is also out but its only availible in germany.
Looks a lot better too now :)
Snelvuur
Re: miele@home
Postby labium » Sat Dec 10, 2011 12:34 am
well , miele is the only manufaturer in europe which makes kitchen apps domoticable, when i get time the next years i like to make a plugin for homeseer
labium
Re: miele@home
Postby Bjochems » Tue Dec 13, 2011 7:55 pm
@snelvuur
Do you have connected a Miele washing machine to the Miele gateway? If so, which model and where did you buy it?
Thanks!
Bas
Bjochems
Re: miele@home
Postby Snelvuur » Tue Dec 13, 2011 10:15 pm
i have, but its been some time.. the best thing you can do is go to miele.de and select washing machine.. then you can also select the models that only support miele@home (then check if those models are in .nl too) germany is a bit ahead usually.
Snelvuur
Re: miele@home
Postby Bjochems » Wed Dec 14, 2011 10:33 am
thanks, found out that all models with miele@home are expensive
EUR 2000,- or more...
thanks anyway
Bas
Bjochems
Re: miele@home
Postby Snelvuur » Wed Dec 14, 2011 11:13 am
I dont think i payed that much, but like i said its a long time ago.
Snelvuur
Re: miele@home
Postby Thor_h » Tue Jul 24, 2012 6:04 pm
Hello Guys,
half a year ago, i bought a Miele laundry washer W5967 und a Miele laundry dryer T8969WP with their powerline network cards and the XGW2000 PL-Ethernet-Gateway. The Software v3.0.1 was a horror! Now a got a v4.0.1 version and it looks better. While updating I tcdumpd' the traffic to the gateway and found the telnet and ftp password for root: 't20e0ar2'. It's a linux distri named ELinOS - 2.6.15.7-ELinOS-280 (http://en.wikipedia.org/wiki/ELinOS) on armv5tel. I'm interested in additional information!
Cheers
Thor
Thor_h
Re: miele@home
Postby Snelvuur » Wed Jul 25, 2012 10:26 am
hehe, thats funny, getting root via a tcpdump :)
Snelvuur
Re: miele@home
Postby Snelvuur » Wed Jul 25, 2012 10:37 am
well i tried to login, but it just hangs. But you say you updated to 4.0.1 and then did a tcpdump, i actually had to send mine in to miele to get it updated. How did you update?
*got in though now*
Snelvuur
Re: miele@home
Postby Snelvuur » Wed Jul 25, 2012 11:17 am
Some other sites on it too..
Registered HTTP URLs
Miele@home Gateway Root URL
http://<gateway_ip>:<http_port>/
Miele@home Browser Prototype
http://<gateway_ip>:<http_port>/browser
Control Unit Browser
http://<gateway_ip>:<http_port>/cube
Miele@home Gateway Web Administration Application
http://<gateway_ip>:<http_port>/gwadmin
Miele@home Gateway Web Administration Application - Backend Settings
http://<gateway_ip>:<http_port>/gwadmin/backend/settings
Miele@home Homebus
http://<gateway_ip>:<http_port>/homebus
Miele@home Homebus Test Tool
http://<gateway_ip>:<http_port>/homebustool
Miele@Home Minibrowser
http://<gateway_ip>:<http_port>/miele
Valid Credentials
username: xgw2000
password: xgw2000
Keyboard Usage - Timer Dialog
Up & Down arrow keys - change the time field
Left & Right arrow keys - change the digit in the time field
The digit keys - edit the currently selected digit
Snelvuur
Re: miele@home
Postby Snelvuur » Wed Jul 25, 2012 11:25 am
Thats nice..
prm.manager.url = secure:tcp://dz2.prosyst.com:1503
gw.net.reconnect.continuous = true
gw.net.auto.connect = true
gw.net.reconnect.interval=30
its phones home too..
Snelvuur
Re: miele@home
Postby Thor_h » Wed Jul 25, 2012 12:38 pm
a got this link from Miele yesterday, after having raised a complaint ;-):
http://www.miele.de/media/haushalt/VG_D ... W_2000.exe
I have only Linux, so I had to unpack it on a Windows in a VM (VMware), then I copied thes files:
installmah
installmah.jar
version.dat
xgw2000_gateway_4.0.1.zip
to my Linux PC and started the script ./installmah (may be you have to correct the IP in it). In an other Terminal I started "tcpdump tcp port 23 -s 0 -w miele.dmp"; Editing the .dmp after the update, I found "MyMiele login: .... root" - and "Password: ... t20e0ar2"... nearly at the beginning of the file.
The user/password covers telnet and ftp!
I have an own time server with a DCF77 clock. I added <ip of my server> pool.ntp.org to /etc/hosts, because I coud not configure a ntp server other than the servers in the list of the web tools of the gateway...
I think, there are many other things to do...
regards
Thor
Snelvuur wrote:well i tried to login, but it just hangs. But you say you updated to 4.0.1 and then did a tcpdump, i actually had to send mine in to miele to get it updated. How did you update?
*got in though now*
Thor_h
Re: miele@home
Postby John » Wed Aug 15, 2012 9:59 pm
labium wrote:well , miele is the only manufaturer in europe which makes kitchen apps domoticable, when i get time the next years i like to make a plugin for homeseer
Labium, any progress on the script? Or do you have it working an other manner?
John
John
PreviousNext
Return to Home Automation Projects
