Here you can find a modification from a SS13A to 433Mhz
http://www.domotica.famschenk.eu/SS13A.html
Ed
Modify SS13A to 433Mhz
- Jeroen Bartels
Re: Modify SS13A to 433Mhz
Hey Ed,
Does it also improve the range of transmission? I use some ss13a in my house but more than 5 meter away from the receiver is impossible.
Best regards,
Jeroen
Best regards,
Jeroen
**Jeroen**
Hello Jeroen,
Yes the range is must wider than the original transmitter.
The range is also depending on the Arial
But there is also a down side to it the batt life is much shorter
Then the original 315 Mhz transmitter.
Ed
Ps.
If you like you can pick up my test version before you modify yours
Ed
Ps.
- Jeroen Bartels
- Jeroen Bartels
TUUT TUUT
