My DIY home automation project
fatcat
Post by fatcat »
See my recently finished project on home automation:
Key features:
1. Heating control - IRC (individual room control)
2. Appliance/lights control - using X10
3. Weather forecast - downloaded from net
4. Irrigation
5. CCTV - camera + intercom at door
6. remote access - web remote access
7. controled with 15'' LCD touchscreen located in hallway
All i did myself (design,construction and software)
It's based on VIA EPIA SP13000G Mini ITX running WIN XP
OK now important bit: see it live
[youtube]http://uk.youtube.com/watch?v=2gnSvP6idAU[/youtube]
www.smart-house.cz
Richard
Post by Richard »
Look verry cool and neat. well done fatcat.
Do you have an (english) website wich provides more info about the project?
Richard
Snelvuur
Post by Snelvuur »
@fatcat: what did you use to do the individual heating? Is it normal radiators?
fatcat
Post by fatcat »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Richard</i>
<br />Look verry cool and neat. well done fatcat.
Richard
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Richard, sorry english site is not ready yet.
however good News is that i'm working on :)
www.smart-house.cz
fatcat
Post by fatcat »
<br />@fatcat: what did you use to do the individual heating? Is it normal radiators?
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Erik, it's like classic heating system (water boiler in the basement,
water pipes to each room, and water radiators) the difference is that valves are located on the pipe in the basement (as you can see in the movie)
Then there are thermometers in each room and each radiator can be turned on/off with valves attached to each radiator
it's very effective for example if you need rapidly increase temperature in one room, you can redirect throught valves all available heat power (12KW in my case) to one singe radiator which allows to raise temperature by 4 degrees in 20minutes or so.
also it's pretty effective from savings point of view.
www.smart-house.cz
Snelvuur
Post by Snelvuur »
in my case i have central heating (city heating) and i cant change 1 single radiator. You have the good part, you have different pipes to different radiators. (i dont see that often in .nl)
fatcat
Post by fatcat »
<br />in my case i have central heating (city heating) and i cant change 1 single radiator. You have the good part, you have different pipes to different radiators. (i dont see that often in .nl)
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">i would say that even with central heating you can have IRC.
Only thing what you have to do is replace "radiator thermostats"
attached directly to radiator (it's really easy, you don't need plumber)
And you can replace them with RF controled radiator thermostats
such Honeywell HR20 or wired TWA danfoss (there are tons of these on the market)
www.smart-house.cz
Snelvuur
Post by Snelvuur »
Yes, but none of them easily controlled by the computer. no open source stuff etc.
Dowser
Post by Dowser »
Isn't that a challenge rather than a problem? :)
//Markus
Snelvuur
Post by Snelvuur »
Challenges comes with time consumption, and having time is a challenge, making it is a problem :)
Dowser
Post by Dowser »
An all to common problem...
//Markus
