I would like to introduce a new open source home automation system called 'Domoticz', and there is no better day to launch it on Christmas day
It's almost finished, the one thing missing is the Event system (When a switch is pressed, and it's dark, turn on light 1/2/3), but i will implement this as soon as possible.
Everything else should work as expected!
The Domoticz system exists of two parts:
1. A light weight deamon (windows , unix (Raspberry Pi)
2. A web based frontend
And of course it is possible to use it offline on the iPhone/iPad (and possible Android) by creating a shortcut on your homescreen.
Required Hardware:
RFXCOM transceiver (for example the 433,92 Mhz)
All hardware supported by RFXCOM should work with the system, including temperature, rain and weather sensors.
It is also possible to reshare your sensors, or to use someone else his/her sensors.
All information can be found on:
http://www.domoticz.com
if there are people wishing to participate in the project, please
With kind regards, and Merry Christmas!
Rob
