Homebrand MS13E problem
Postby Julian » Thu Apr 16, 2009 4:00 pm
I have a problem when setting up a number (Elekhomica) MS13E2 private label programs.
A setting for day / night, I can not select option 3 and 4. Do this more often done on a Marmitek MS13 and no problem here.
I press unit off, then on long house. MS13 below shows the current code. Release and Press three times on house, last pressed. The green LED goes out and fires a long red light at the third time .....
I see nothing, 100x already done and no success. Did it 4! units attempted ...
Julian
Postby Antoon » Thu Apr 16, 2009 4:52 pm
I have 16 MS13E and all without problems.
Elekhomica also occur, so seems very strong that you now have 4 defective.
Manual is in the lid and if I do it too.
He should be at rest before you start programming.
- Antoon
<h6>
Antoon
Postby Andro » Thu Apr 16, 2009 7:13 pm
took a while before I 'm also had. You should print fairly quickly. First right and then immediately left. If everything is ok then the green LED on.
Andro
Postby Julian » Thu Apr 16, 2009 8:19 pm
Green led the like are accustomed to, and I know that the setup is good, do not just point at 3 or 4. Option 1 and 2 are no problem ....
If I for the third time on house / click on the red light more fires, while extinguishing the red and green. Setting is unfortunately not changed ..
Julian
Postby Julian » Thu Apr 16, 2009 8:29 pm
When I look at this PDF
http://www.keene.co.uk/pages/downloads/ ... MS13Ei.pdf
I think I have a very old version
The red LED blinks once if the MS13E is set to detect motion at all times.
The red LED blinks twice if the MS13E is set to detect motion only when its dark.
Julian
Postby Wim2008 » Thu Jul 29, 2010 6:09 pm
I recently had problems with a few MS13E motion that I use at home.
The motion I had been working well until I start this month with various other materials X10 got. Because of this, I wanted the house and unit code change.
I did this using the manual which was supplied to the motion.
I noticed that if I brought in a house-code which is always a higher indicated by the LED. This also happens with the unit code.
Example: I'm house-A code inserted, after checking I see that the LED 2x fire. So a B.
If I brought in a unit-code, this was indicated by the LED 2.
Whatever I try I can not A1 as a house and unit code insertion motion. The LED indicates when checking a B and a 2 at.
In HomeSeer I can not find the code A1. Not the variations thereof B2 or A2 or B1.
Is there anyone who knows this problem and has solved this problem now?
Does anyone know how the factory settingscan be set into the motion?
Mvgr Wim :) :wink:
Wim2008
Re: Huismerk MS13E probleem
Postby drmacchi » Thu Jul 29, 2010 7:40 pm
Please English. Thanks Boys :)
drmacchi
Re: Homebrand MS13E problem
Postby Bwired » Thu Jul 29, 2010 7:49 pm
Please guys English.
if a topic slipped trough in Dutch then please continue in English
Translated the stuff with google now
Postby Wim2008 » Thu Jul 29, 2010 7:55 pm
Thanks for your help.
Wim2008
Postby drmacchi » Thu Jul 29, 2010 8:13 pm
Pull out batteries for a few hours and then try to setup it as usual. I had to do this some time ago with a ms13
drmacchi
Postby Wim2008 » Fri Jul 30, 2010 4:19 pm
Thanks for your advice.
I had done that by one module, but there nothing changing.
If I put in A, I become B in the module.
If I put in 1, I got 2 in the module.
B.R. Wim :) :wink:
Wim2008
Postby drmacchi » Fri Jul 30, 2010 4:26 pm
So if you
address : input 27 times , it should go to A
number : input 99 times (is it the max. ?) , it should go to 1
May be it's a stupid way or it will work 8)
drmacchi
Postby Wim2008 » Fri Jul 30, 2010 6:16 pm
Results:
Max for adress is 17. By 17 the led stays red and by the next pressing the led is flashing for a short time.
Max for number is also 17. By 17 the led stays red and by the next pressing the led is flashing.
Adress and number aren't changed.
B.R. Wim :) :wink:
Wim2008
Postby drmacchi » Fri Jul 30, 2010 9:35 pm
I found this :
These little beasties (Motion Detectors) come in two forms - standard and the E version. The newer E version stores the programmed House and Unit codes in EEProm - so removing the batteries will not deprogramme the House/Unit settings - you will have to reprogramme if you have one of those.
http://board.homeseer.com/showthread.php?t=111416
If you can not reprogram and have warranty anymore, i have and idea : if you use Homeseer, you could set a VIRTUAL DEVICE that works like a shadow of a the real ms13
ex. REAL = B7 , VIRTUAL = A12 : if B7 is on , then A12 is on ............. and so on !
Cheers
Lorenzo
drmacchi
Postby Peterpc » Sat Jul 31, 2010 12:29 pm
if you want to program housecode a, you have to push the button once and keep it pushed untill you see the led confirming housecode a by blinking once.
Peter
http://www.pcgsm.nl/
Peterpc
Next
Return to X10, A10 Xanura Marmitek Forum
