Hi there,
I have a CM11A computer interface, but it has an automatic event programmed into it.
The problem is that i'm using a Windows 7 machine so i can't get Activehome (to programm the cm11a) to work.
Is there another option so i can flash my CM11a?
Cause i don't need the events that are stored in the CM11a
I'm using homeseer 24/7 to control everything.
How to reset CM11A
Re: How to reset CM11A
You could use heyu, although this requires Linux. 'heyu erase' would erase the EEPROM of the CM11.
Unfortunatly i don't use linux
Isn't there another option for windows?
If there isn't i will have to install a linux pc.
Tnx
Tnx
with the correct version (pro/ultimate if i'm correct) of w7 tou're able to run a virtual wxp version
** edwin **
I have ultimate so I will search google for that.
Tnx
Tnx
